Go Back   R/C Tech Forums > Company/Manufacturer Forums > MaxAmps Support Forum
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-28-2009, 12:31 PM   #1
JAM MaxAmps's Avatar
Arrow New 4S 5250 60C Hard cased pack!!!
http://www.maxamps.com/proddetail.ph...48-Pack&cat=59
MaxAmps.com presents the ultimate 1/8-scale hard case racing pack. As you racers know, the most important factor for your batteries is voltage under load. This LiPo pack boasts a 60C rating for all your amp hungry racing setups. It will maintain higher voltage under load than any other LiPo battery pack on the market. Plus, you'll have no problem getting plenty of run time with 5250mah of capacity.
Perfect fit for any 1/8 scale electric vehicle that runs a single 4S pack including the Losi 8ight-E, Associated RC8-E, SC8-E and more!
- Hard Outer Case
- 5250mah Capacity
- 14.8 Volts
- 47mm X 139mm X 39mm
- 60C - 4660 surge watts(315 amps)
- 504 grams
- Water-sealed for all-weather protection
- Comes standard with Hyperion taps
- Comes standard with 12awg Deans Ultra wire
- Highest performance in the industry
- Twice the capacity of NiMH for the same weight
- Plug and Play for any charger/balancer/vehicle
- We add the connectors and balancing taps for you
- Money Back Guarantee
- Normally ships within 24-48 hours
- Exceeds safety standards of the IATA
- Built today with factory fresh cells
- Can be recharged unlimited times per day
- Copper Tab Cells for lower resistance
Jason
MaxAmps Marketing Manager
jason@maxamps.com
www.NitroKillers.com www.MaxAmps.com *Team Terribles Sponsor/Member* Caster Driver
JAM MaxAmps is offline   Reply With Quote
Old 07-29-2009, 02:01 PM   #2
jdsrace1's Avatar
Wow 60C is there no end. Is that true 60C or burst 60C. Because if it is burst then it is really a 30C battery or am I wrong.
jdsrace1 is offline   Reply With Quote
Old 07-29-2009, 02:04 PM   #3
Read here it's all explained: http://www.maxamps.com/lipo-care.php
Jason
Jason
jason@maxamps.com
Old 07-31-2009, 08:45 PM   #4
ShibbyUTD's Avatar
Location: Green Bay, Wisconsin ; University of Minnesota
nice
Associated-Tekno RC8 / Team Tekin RX8 1900kv
Traxxas Slash / Velineon Brushless 3500kv
LiveRC Raceway Green Bay / Dirt Heaven / Northern Hobbies
~Thanks for the great forums RC Tech moderators~
ShibbyUTD is offline   Reply With Quote
Old 08-21-2009, 08:59 PM   #5
i bought one of these but in a non hard case format. im excited to try it out on my soon to be built rc8e, but i hope the hard case wasn't necessary for casual racing and bashing.
GT_legends_csl is offline   Reply With Quote
Old 08-22-2009, 07:20 AM   #6
Not unless you race ROAR races. Otherwise you'll be just fine.
Jason
Jason
jason@maxamps.com
Old 08-22-2009, 10:21 AM   #7
Cain's Avatar
Trader Rating: 34 (100%+)
in general if you wanted to compare a constant C rate to a surge rate, do you just double the constant one?
Very nice pack!
Academy GV2 Pro 1/10 Scale Brushless Buggy
Academy STR4 Pro II 1/10 Scale Brushless Sedan
Ofna Hyper 9E 1/8 Scale Brushless Buggy
Old 08-30-2009, 07:24 PM   #8
Jason
So,it is a burst rating?So what would the C rating actually be if Max Amps rated their packs by constant C,like pretty much all other reputable companies? Does the 30C figure that jdsrace1 posted sound about right?
harry697 is offline   Reply With Quote
Old 08-31-2009, 06:42 AM   #9
Yes it's a 30C pack it's still the same old 5250 cells just a different way to rate them.
Jason
Jason
jason@maxamps.com
Old 09-03-2009, 10:36 AM   #10
Jason,
im lovin this pack! one little concern though. the first time i ran it full through (roughly 25-30mins) 3 of the cells were at 3.6-3.7 range, but one little guy was at 3.3. is there cause for concern being that off balance? when i went to store the pack after the drive it balanced out no problemo to 3.9 across the board (whatever the hyperion balance charger have set for store mode)
i just hope i dont have a limp cell.
thanks!
Old 09-03-2009, 01:56 PM   #11
yzracer758's Avatar
ROAR Legal??
Hot Bodies | HPI Racing | Team Tekin | Diggity Designs | AKA | Thunder Designs
Hot Bodies Ve8
Hot Bodies D4 WCE
yzracer758 is offline   Reply With Quote
Old 09-04-2009, 06:45 AM   #12
Jason,
thanks!
That little voltage difference shouldn't be an issue. Anything over .5 volts out is when there might be a bad cell. The Hyperion's won't charge a pack if a cell gets that far away from the others.
Originally Posted by yzracer758 View Post
ROAR Legal??
No the 5250 cased pack is not ROAR approved and there are no plans at this time to have it ROAR approved.
Jason
Jason
jason@maxamps.com
Old 09-09-2009, 07:45 PM   #13
Jason
If it is not ROAR approved,then why is the price so high?I remember a post awhile back that claimed MA didn't go the ROAR approved route because it would raise the price of the packs drastically.
Old 09-10-2009, 05:39 AM   #14
I guess I don't see what your talking about it's $10.00 more for the cased compared to the non cased. Makes sense to me charge a few dollars more seeing there is another part on the pack. Simple enough.
-J
Jason
jason@maxamps.com
Old 09-10-2009, 07:09 AM   #15
Cain's Avatar
I think he may be figuring the overall price of the pack should be lower than what it currently is based on the fact that ROAR approvals don't have to be done and have that cost built in from what he understands.
The pack in question though is priced about the same as the Thunder Power 5000mah 4S 40C pack, so I don't think its way out there in price. At the higher end of price, sure, but its not way out there in my opinion.
I do hope though in the future that if ROAR rules really take off for 1/8 electric that the pack or a future pack is submitted for ROAR approval.
Jason, will maxamps be looking to do a hardcased 1S lipo for 1/12 scale? Similar to SMCs 4000mah 1S?
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
