Originally Posted by irgo
can you show your 15C charger picture ?
where to get maxamps life in indonesia ?
your
MaxAmps Green Series Life 2250
# 2250mah Capacity
# 6.6 Volts
30C Constant(67.5 amps)
# 60C Burst - 890 surge watts(135 amps)
is this Discharge "C" rate for pack's or per cells ?
The 15C charge rate was done by our manufacturer I'm don't have access to a graph of that. Besides the largest charger out right now max's out at 20 amps. It'll be a few years before something bigger comes along.
As for the ratings on the site that is the ratings for the specific pack not a single cell.
Originally Posted by Kingcrab
I'm really interested in this cells as now I'm racing in ISTC modified brushless class. Normally we use 6 cells NiMh with 4.0 or 5 cells with 3.5. Since IFMAR will approve Lipo/Life in next Ifmar world. I have some questions before purchase this LIFE cells.
- Does charging procedure same as LiPO? just different voltage peak limit right? i.e Lipo is 8.4 and how about LiFE? 7.6?
- Should I go for 3.5 with LiFE or 4.5 with LiPO? from my experience Lipo may be damage with those high amp draw from 4.5 motor.
Thanks for your reply.
Yes the sequence is similar but the voltages are different. A 6.6 volt LiFe-Po peaks at 7.2 volts.
As far as what to run with each set-up as long as your geared with in the packs specs both will work.
Jason
