Go Back   R/C Tech Forums > Company/Manufacturer Forums > MaxAmps Support Forum
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-19-2009, 03:59 PM   #1
balistic's Avatar
Trader Rating: 48 (100%+)
Default 1C or 2C charging?
I just got a 4200 SS pack and was reading the instructions and noticed that 1C was recomended unless you had a balancing charger and then you could go 2C.
My question is with the Hyperion charger what is the best rate to charge the battery at? Is there a rate for long life and another for best power?
I have just been plodding along at 1C on all my batteries.
balistic is offline   Reply With Quote
Old 02-19-2009, 06:56 PM   #2
jrr102486's Avatar
Location: The One With The Light Saber, RC Performance and Hobbies Madison WI
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
its just alwyas safe to charge at 1c. i have always done that and i have never had a problem at all. as i "usually" say always safe than sorry!
Josh Riese - Track Director - RC Performance and Hobbies, Madison WI
MIDWEST NITRO SERIES - "KEEPING RACING SIMPLE" - TECHNICAL GUY - www.midwestnitro.com
my sponsors: Maxamps Batteries | Boca Bearings | Upgrade/ rcID | LiveRc | RC Scoring Pro | DNA GRAFFIX - For All Your Paint Needs | Rc Performance and Hobbies | My Loving Fiance
jrr102486 is offline   Reply With Quote
Old 02-20-2009, 06:31 PM   #3
A.C
A.C's Avatar
Send a message via MSN to A.C
i just wana check charge at 1C = to what?
i am using a 4500 5S1P lipo battery 15C. btw 15C = what?
please advice
A.C is offline   Reply With Quote
Old 02-20-2009, 07:09 PM   #4
jrr102486's Avatar
please advice
examples:
2400mah lipo/ charge at 2.4 amps
3200mah lipo/ charge at 3.2 amps
6000mah lipo/ charge at 6.0 amps
so in your case you have a 4500mah lipo. charge at 4.5amps. but just from experience, i have a 60004s2p lipo for my 8th scale. i used to charge it at 6.0 amps before i fried a power supply in doing so. i now charge it at 3.0 amps and i have had no problem since.
your 15c means top burst. the higher the "c" rating you have there the more punch you will have out of your lipo.
josh
Old 02-20-2009, 08:06 PM   #5
A.C
A.C's Avatar
Originally Posted by jrr102486 View Post
examples:
josh
wow josh,
thk for the reply.
really helps alot.
regards
Old 02-20-2009, 08:58 PM   #6
balistic's Avatar
MAH/1000=1C
Old 02-20-2009, 09:02 PM   #7
balistic's Avatar
[quote=jrr102486;5459803]examples:
josh[/QUOTE
What was your power supply rated at? I run a duo charging two 6000s at 1C on a 25A, I have run this on a 15A but I don't like running high duty cycle stuff WFO.
Old 02-20-2009, 10:11 PM   #8
jrr102486's Avatar
[quote=balistic;5460138]
examples:
josh[/QUOTE
it was rated at 20 amps but the capacitors in there were light for a 20 amp. i would have upgraded them to better ones but i couldnt find the right ones.
Old 02-23-2009, 05:48 AM   #9
JAM MaxAmps's Avatar
josh
Actually Josh that's a little flawed. The C rate that is listed on most packs is the constant rate not burst. And C rated doesn't determine how much punch your pack will have. A higher C rate will handle a higher amp draw with out stressing the pack and it'll make for much more efficient use of the power. Yes you will see a stronger start but that is because the pack can handle that surge that much easier. Punch is based on voltage. A pack under a high load that can hold a higher voltage is going to give you better punch than one that drops that voltage.
Jason
Jason
MaxAmps Marketing Manager
jason@maxamps.com
www.NitroKillers.com www.MaxAmps.com *Team Terribles Sponsor/Member* Caster Driver
JAM MaxAmps is offline   Reply With Quote
Old 02-23-2009, 07:35 AM   #10
jrr102486's Avatar
thanx for that jason. i thought i was a little off. also makes a little more sense now as well!
Old 02-23-2009, 10:47 AM   #11
balistic's Avatar
Jason
How about the original question?????????????????? 1C or 2C? and why?
Old 02-23-2009, 12:04 PM   #12
Well the 1C or 2C isn't really a question it's more of if you want to you can do 1C but you can do 2C if you use a balancer while you charge. As far as why because the balancer is a safety device that will shut off a higher voltage cell from the charge current so that it doesn't over charge. Charging at higher rates can cause this to happen the balancer prevents it.
Jason
Jason
jason@maxamps.com
Old 02-23-2009, 02:07 PM   #13
balistic's Avatar
Jason
So you are saying there is no performance advantage or dis-advantage to charging at 2C? as long as the charger has a balancer? or is that just the Hyperion?
If it isn't going to hurt the battery I would like to charge them twice as fast!
Old 02-23-2009, 02:11 PM   #14
No there is no performance change in doing 1C or 2C and by charging at 2C you'll shave 10 to 15 minutes off the charge time. In the long run 1C is better and easier on the packs.
Jason
Jason
jason@maxamps.com
Old 02-27-2009, 07:14 AM   #15
Cain's Avatar
Trader Rating: 34 (100%+)
Jason,
I noticed that seems that C charge rates are going up. seen some packs that can take a 5C charge rate now, if I recall correctly out there in the wild.
Can you explain how much of a degredation in pack life you see usually going from 1C - 2C or more within what the manufacturer states is a safe C Charge rate?
Academy GV2 Pro 1/10 Scale Brushless Buggy
Academy STR4 Pro II 1/10 Scale Brushless Sedan
Ofna Hyper 9E 1/8 Scale Brushless Buggy
Forum Jump
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 18865 11-18-2009 04:00 PM
Thunder Power Rc 40C 5000 Lipo ThunderPowerRC Electric On-Road 432 11-03-2009 10:58 AM
NEW TO ELECTRIC, HELP davidg01234 Electric Off-Road 41 08-03-2009 07:32 AM
Indoor Dirt Racing @ RC Performance in Madison squirrel Wisconsin & Illinois Racing 4856 05-11-2008 05:25 PM
Team Orion 3200mAh Race Spec LiPo Nexus Racing Electric On-Road 1772 03-16-2008 08:52 AM
BEST LIPO CHARGER and LIPO PACKS GSP Electric On-Road 28 06-18-2007 05:48 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
