ULTIMATE DRIFT TIRES
ETO NA ANG PINOY SOLUTION!!! COURTESY OF YOURS TRULY.
get caps of your WD40 (notice it is 65mm) or the cap of your used engine degreaser (also it is 65mm). Note that your tires are 64mm, (rubbers) CUT THE CAPS in HALF, DREMEL THE MIDDLE WHERE you can fit the tire wrench, NOW FIT IT ON YOUR INSTALLED TIRES. If you have an old tire, its better, or old wheels, better, just CA it or turbo glue it on the tires.
SEE PIC. attached.
got to race...and temporarily forget the mess we're in...
