Go Back   R/C Tech Forums > International Forums > Manila Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-10-2006, 05:28 AM   #1681
Blackwrench™'s Avatar
Originally Posted by nitrodrift
blackwrench,
please text (09218040007) me what time yung gathering. kung morning malabo, afternoon pwede pero around 3pm na.. coming straight from work. monday tuesday off ko kasi...
bro how can i get hold of those tommi tires? are they for sale? kasi currently using aerosol caps, and di pa maganda pagkakatabas
order kayo kay sir tommi. ng tommi tires. nag txt na ako pero wala reply. php100 4pcs. custom made sainyo kung gusto nyo 26mm or 24mm. pero pwede pa ata wider 30mm for nitro.
nolitolits,
cge next time bro.
nitro drift,
bka until hapon ako dun.
Mukhang Masama panahon ah. mukhang uulan pa ata sa saturday.
pero laro parin ako sa lower levels if it rains. see you DRIFTERS!
www.philippinercdrifters.org
DRIFT RELIGION
Blackwrench™ is offline   Reply With Quote
Old 05-10-2006, 08:25 PM   #1682
vlozity's Avatar
Originally Posted by Blackwrench™
order kayo kay sir tommi. ng tommi tires. nag txt na ako pero wala reply. php100 4pcs. custom made sainyo kung gusto nyo 26mm or 24mm. pero pwede pa ata wider 30mm for nitro. >8 snip 8<
still no response from Tommi ... must be very busy or on vaction.
btw, i just sms you
http://philippinercdrifters.org + http://driftercentral.com
Drifters >>> HPI Pro-D • TA03F-S <<+>> Super Crawler >>> ClodBuster custom
vlozity is offline   Reply With Quote
Old 05-10-2006, 09:53 PM   #1683
rcdy's Avatar
guys, can anyone give me drifting setup for my tc4?
TeamXray, TeamAssociated, Esky, Tamiya
rcdy is offline   Reply With Quote
Old 05-10-2006, 10:57 PM   #1684
Default drift setup
guys curious lng ko sa mga drift set-up nyo. post nyo naman drift set-up nyo
mauna na ako.
driver:Blackwrench
cars: TT-01 Body: LEVIN, ALTEZZA
-mabuchi motor
-MC10 ESC
-LOCK rear diffs
-Tommi tires
-damper shocks
-stock springs
DRIFT RELIGION
Old 05-10-2006, 11:04 PM   #1685
try,
-soft suspension (so, medyo itaas mo ung height nung car para hindi tumama)
400wt to 500wt oil
-rear sway bars only. soft or medium
-LOCK rear diff OR front and rear diffs. never front diff only.
-tub chassis
-toe-out rear
-2 degree camber on all four wheels
-PVC tires
-27t motor
this set-up wil help but, its still depends on your drifting style.
DRIFT RELIGION
Old 05-10-2006, 11:10 PM   #1686
driver:bene323
car: ta04 chassis, nissan fairlady-z/350z jgtc body or mazda Fd3s rx7 body
-mabuchi stock 540 motor
-mc230 esc
-damper shocks
-PVC tires/tommi specials
-all stock
-full bb
-geared to the max
car: HPI rs4 SS, body mazda 6 or dodge stratus HPI bodies
-stock 1 hp engine
-hi torque servos
-OS glow plug
-stock suspension
-leaking exhaust
-semi tuned engine (medyo may topak pa)
bene323 is offline   Reply With Quote
Old 05-10-2006, 11:34 PM   #1687
-stock 1 hp engine
-hi torque servos
-OS glow plug
-stock suspension
-leaking exhaust
he he he. ayos yan ah. May FD rx-7 ka bro? san mo nakuha?
dala ko gasket, tignan ko kung kasya sa engine mo.
nitrodrift,
punta ka ba sa sat?
nu engine gamit mo sa prime 12 mo?
DRIFT RELIGION
Old 05-10-2006, 11:58 PM   #1688
uy salamat pre! tignan naten kung maayos! pero sa exhaust mismo ata nanggagaling yung leak, yung rx-7 na body sa speedzone action hobbies ko nabili, meron din ata silang hachi roku, 190mm pang tamiya and other electics!
sa nitro ko walang ok na body eh! hindi na kasi proportional yung mga 200mm bodies na nasakin! hehehe
Old 05-11-2006, 01:35 AM   #1689
bene323,
parang di ata leak yan kung sa exhaust ang labas. natural na may lumalabas na oil sa exhaust end. lubricating oil un para sa sleeves. magkano ung '86 body? meron pa ba?
DRIFT RELIGION
Old 05-11-2006, 02:07 AM   #1690
Z-man's Avatar
Driver: Z-man
Ride: Yokomo CGM
0deg toe/camber front 3deg toe/0deg camber rear
front oneway, rear ball diff
rubber/pvc tires
nissan r34
Z-man is offline   Reply With Quote
Old 05-11-2006, 05:13 AM   #1691
hi to all drifters.... im new in dis kind of stuff. nabuo ko na rc ko. ready na for drift.
pdi ba ako sumali sa inyo ,mag laro sa ps1 dis coming saturday morning?
by d way, dalin ko rin ung tc3 ko, may prob ako dun eh, bka matulungan nyo ako. tnx guys!
drifters is offline   Reply With Quote
Old 05-11-2006, 07:22 AM   #1692
drifters,
sure bro. everyone is a newbie. join the fun.
DRIFT RELIGION
Old 05-11-2006, 07:27 AM   #1693
kalentong's Avatar
Send a message via Yahoo to kalentong
Driver: Kalentong
Chassis: TT01
Body: Ford Escort
Motor: Mabuchi 540 27t (silvercan)
ESC: TEU-101BK (stock)
Tires: orange PVC
Spur/Pinion: 61t/22t
Suspension: stock
Camber: 0
Toe: 0
kalentong is offline   Reply With Quote
Old 05-11-2006, 07:51 AM   #1694
Registered User
nolitolits's Avatar
Default Drifts Spec
Driver: nolitolits
Chassis: TT01-D
Body: RX-7
Motor: Atlas Force 23t
ESC: Novak GT7
Tires: Tomi Tires
Spur/Pinion: 4got basta Final gear ratio ko 6.03:1 ata
Suspension: Stock Dampers Med Spring sa front, Soft sa likod
Camber: 0 deg. F/R
Toe: 0 deg.F/R
Differential: stock lng
nolitolits is offline   Reply With Quote
Old 05-11-2006, 10:18 AM   #1695
Tommi Makkinen's Avatar
Trader Rating: 9 (80%+)
Guys, im just waiting my shipment of the PVC pipes. so pls bear with me...
anyone who wants to order my Tommi Tires Mk2, pls post here... (no PM) para i know who wants it...
indicate your codename, how many sets you want (4pcs per set), and what width you prefer...
ex: Blackwrench (3sets) (1set 24mm, 2sets 26mm)
price for 1 set (24 and 26 mm) is still PHP100 each (wala muna price increase hehehehe).
custom widths (such as the 30mm for nitro rears) are ok but i will charge an additional PHP50 as customizing charge...
i will also post rin here when i get my PVC shipment para alam na ninyo when to get the tires...
salamat sa mga drifters who like my tires. i appreciate this talaga...
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Forum Jump
simplify the F/S F/T section? meaN1 R/C Tech Site Forum 3 07-01-2007 04:59 AM
DIY section wog....supraman R/C Tech Site Forum 2 02-15-2007 07:07 AM
Penang Section!!! detomaso_runn Malaysian R/C Racers 3 12-21-2006 07:59 AM
Web Links section futureal R/C Tech Site Forum 5 09-19-2001 05:30 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
