Go Back   R/C Tech Forums > International Forums > Manila Racers
Old 11-10-2013, 11:24 PM   #31396
LilsTamiya's Avatar
JPR Touring Car Challenge - Nov. 23, 2013
Get ready for the final leg of the 2013 JPR Touring Car Challenge on November 23, 2013 at JP Raceway!
It’s time to put your driving skills to the ultimate test.
1st Entry - 1,500 with 1 set of ride tires
2nd Entry - 200
3rd Entry - 100
4th entry - 50
*400 if F1 Only
CLASSES AS FOLLOWS:
Stock Touring class
Chassis - Open
Motor - Tamiya Johnson and Mabuchi only
ESC - Open
Tire - Ride RE36
Body - Open
Battery - 6 cells Sub-C NiCd, NiMH. or Lipo 2 cells 7.4v.
Weight- No weight limit
Veterans may join this class but maximum fdr will be 6.0 and weight limit of 1600g
17.5 Blinky Class
Chassis - Open
ESC - Any brushless ESC with NO boost function or with blinky mode.
Motor - Any 17.5T or Tamiya 18T Motor TBLM
Tire - Ride RE36
Weight - 1400g
13.5T Open Class
Chassis - Open
ESC - Open
Motor - Any 13.5T
Tire - Ride RE36
Weight - 1400g
F1 Class
Chassis - open
ESC - open
Motor - Silvercan only
Tire - Rubber (foam tires not allowed)
Body - open
RACE SCHEDULE
Please note that we will STRICTLY follow the race schedule below. Make sure that your cars have passed inspection and ready at the track at least 2mins BEFORE the start of your heat.
ADDITIONAL RULES/GUIDELINES FOR ALL TOURING CLASSES:
1) Only the prescribed Ride Racing RE36 Pre-Mounted Tires (No.26006) will be allowed for this race. Tires of each participant will need to be submitted to the race director/officials on race day prior to race start for proper tagging/marking.
2) Race tires can only be purchased on race day at the track venue. A specified time slot will be allotted prior to start of the race for tire purchase, tagging and registration (so be early at the track. Note that you need to break-in new tires to achieve its optimal performance). Additional Ride Racing RE36 Pre-Mounted Tires can be purchased on race day at the track venue for a discounted price of 1200 php only.
3) One set of tires per class is not required. For those who are joining multiple classes, the racer can opt to use only one set of Ride Racing Tires for all touring classes, as long as they are properly marked by the race director/officials.
4) Bodies must conform to the roof, wing specifications with the use of the on-site body jig at the track.
5) Bodies, Tires and Weight will be inspected before each round of racing. Any violation will disqualify a racer from running that round. Note we do pre-run inspections vs. post-run!
RACE FORMAT FOR BOTH TOURING AND F1 CLASSES:
1) 3 Rounds of Qualifying – Each run will be 5 minutes. After each round, racers will be ranked and assigned points corresponding to their overall finish within their respective classes (1st=1 Pt, 2nd=2 Pts, 3rd=3 Pts, etc..). Points from the best 2 out of 3 rounds will be counted and added up. This will then be used to seed the mains using the lowest aggregate/total scores result as basis. In case of a tie in points, best run/time will be used to determine the tie break.
2) Triple Mains/Finals – Each run will be 5 minutes. Best two runs to count, scores of these rounds will be added up (1st Place = 1pt, 2nd Place = 2pts, and so on …) and lowest point total will be used to determine the winners of each class. In case of a tie in points, best run/time will be used to determine the tie break.
OTHER GUIDELINES & INFO:
1) TRACK LAYOUT: The current layout will be used for the 2013 JPR TOURING CAR CHALLENGE. This will give everyone ample time to practice and setup your cars.
2) PRACTICE TIME: Open Practice on race day will be from 10:00am to 12:30pm ONLY. At 12:30pm, the track will be closed and practice runs will no longer be allowed. Practice in between heats and breaks will also not be allowed. So please break-in your tires during 10:00am – 12:30am only.
4) TURN MARSHALLING: Just like all our big races, we will be requiring turn marshalling for this race! Looking forward to your cooperation as always.
5) ROUGH/UNSPORTSMAN LIKE DRIVING will not be tolerated. Penalties will be applied.
WHAT'S UP FOR GRABS???
1.) The first ever JPR TOURING CAR CHALLENGE TITLE IS ON THE LINE!
2.) Trophies for all A-Main Podium Finishers for each class.
3.) Trophies for the B-Main Champions
Lil’s Hobby Center: SM Megamall, Bldg. A Basement (02)633-6358
Lil’s Hobby Center: Glorietta 2, 3rd Floor Ayala Center Makati (02)819-1646
Lil’s Hobby Center: 15 West Drive, Brgy Kapitolyo, Pasig City (02)633-3442
www.facebook.com/lilshobbycenter
LilsTamiya is offline   Reply With Quote
Old 11-20-2013, 07:54 PM   #31397
mikeygar's Avatar
Trader Rating: 14 (100%+)
look at that sexy motor mount!!!
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 11-20-2013, 07:54 PM   #31398
mikeygar's Avatar
Old 11-21-2013, 01:47 AM   #31399
geromeling's Avatar
same as xray. hehe.
maganda yung black verson...
TRF418 - TRF417X - TRF416X - TB04 - TA06 - TA05V2 - TA05 - TT01E - M04 - F104W
geromeling is offline   Reply With Quote
Old 11-21-2013, 08:34 AM   #31400
mikeygar's Avatar
Originally Posted by geromeling View Post
same as xray. hehe.
spur gear layshaft holder, single sided na lang din... kawawa nanaman paypal ko!!!
Old 11-21-2013, 07:18 PM   #31401
geromeling's Avatar
onga noh! parang tamiya ta05. hehe.
Old 11-21-2013, 07:54 PM   #31402
mikeygar's Avatar
TRF419 prototype hahaha!
Old 11-22-2013, 04:24 AM   #31403
geromeling's Avatar
For those joining the race tomorrow, please try to be early.
Qualifying starts at 1pm.
Old 11-22-2013, 07:59 AM   #31404
cocojam's Avatar
Trader Rating: 47 (100%+)
The black BD7 is sexy
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
Old 11-27-2013, 01:20 AM   #31405
Considering the lack of players and races at the track recently, I have decided to adopt a new schedule for jpraceway.
Starting tomorrow, November 27.
Tuesday to Sunday : Open only if races are to be staged and/or if there are more than 5 players who want to use the track.
Please coordinate with Ramil (0921-546-0592)
If there are less than 5 players, whether race or practice, the track cannot open.
To be clear: There needs to be 6 players for the track to be used.
JPRacing is offline   Reply With Quote
Old 11-27-2013, 05:48 PM   #31406
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
bawal na ang secret practice...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-01-2013, 06:00 PM   #31407
LilsTamiya's Avatar
JPR Touring Challenge Nov 23 Race Results
17.5T
1st Gerome Ling
2nd Noel Aldaba
3rd Leo Virtusio
13.5T Boosted
1st Yuichiro Takaya
2nd Gerome Ling
3rd Noel Aldaba
F1
1st Yuichiro Takaya
2nd Noel Aldaba
3rd Jomil dela Cruz
Old 12-03-2013, 07:38 PM   #31408
VooDooPH's Avatar
2013 Futaba Cup and Christmas Party on December 14 (Saturday)
*As always, we will have a raffle after the race.
Track opens at 10AM
Racer starts at 12NN
Stock Touring Class (veterans NOT allowed)
Chassis: TT01/TT01E/TT01D/TT02 only
Motor – Tamiya 540J only (Torque Tuned – not allowed)
ESC - Open
Battery – Open
Tires - Ride or Tamiya Rubber only
Gearing - Open
MINI Class
Chassis - Any
ESC – Any brushed or Tamiya Brushless ESC
Motor – Tamiya 540J, Lightly Tuned motor or 18T Brushless System (Torque Tuned – not allowed)
Battery - Open
Tires – Tamiya and Sweeep only (fabricated tires not allowed)
Body – Any Tamiya Mini bodies only
Maximum pinion of 20T ONLY
Speed Tuned Gears not allowed
F1 Class
Chassis - Open
ESC - Open
Motor - Tamiya 540J, Tamiya Formula tuned 32T (Torque Tuned – not allowed)
Battery - Open
Tires – Rubber (foam tires not allowed)
Body – Any F1 body
Gearing - Open
17.5 Blinky Class
Chassis - Open
Battery - Open
Tire - Ride RE36
13.5T Brushless Class
Chassis - Open
ESC - Open
Motor - Any 13.5T
Battery - Open
Tire - Ride RE36
Race Fee:
1st -600
2nd -200
3rd -100
4th -50
5th -Free
* 5-minute runs for all classes
** Trophies and medals will be given away.
***Racer who wants to be included in the raffle MUST use FUTABA RADIO***
Please write your name below for the pre-registration.
Stock Touring
1)
Mini
1) Gerome
2) Jason
F1
1) Gerome
2) Jason
17.5
1) Gerome
2) Jason
13.5
1) Gerome
2) Jason
Old 12-03-2013, 11:03 PM   #31409
ao97b's Avatar
Race will start at 12nn.
ESC - Open
Battery – Open
Gearing - Open
MINI Class
Chassis - Any
Battery - Open
F1 Class
Chassis - Open
ESC - Open
Battery - Open
Body – Any F1 body
Gearing - Open
17.5 Blinky Class
Chassis - Open
Battery - Open
Tire - Ride RE36
Chassis - Open
ESC - Open
Motor - Any 13.5T
Battery - Open
Tire - Ride RE36
Race Fee:
1st -600
2nd -200
3rd -100
4th -50
5th -Free
Stock Touring
1) Rains
Mini
1) Gerome
2) Jason
F1
1) Gerome
2) Jason
17.5
1) Gerome
2) Jason
3) Rains
13.5
1) Gerome
2) Jason
Let's race!
ao97b is offline   Reply With Quote
Old 12-08-2013, 05:32 AM   #31410
ESC - Open
Battery – Open
Gearing - Open
MINI Class
Chassis - Any
Battery - Open
F1 Class
Chassis - Open
ESC - Open
Battery - Open
Body – Any F1 body
Gearing - Open
17.5 Blinky Class
Chassis - Open
Battery - Open
Tire - Ride RE36
Chassis - Open
ESC - Open
Motor - Any 13.5T
Battery - Open
Tire - Ride RE36
Race Fee:
1st -600
2nd -200
3rd -100
4th -50
5th -Free
Stock Touring
1) Rains
Mini
1) Gerome
2) Jason
F1
1) Gerome
2) Jason
17.5
1) Gerome
2) Jason
3) Rains
4 ) Kim
13.5
1) Gerome
2) Jason
3) Kim
Minami is offline   Reply With Quote
Trade 8th scale off-road for electric touring car nickw R/C Items: Wanted to Buy 0 09-11-2005 03:44 PM
