thanks... I was thinking of getting a new body...would the ferrari 360 be a better racing body? I also wanted to put in lights, but the nsx's light buckets are too close to the tires and rub sometimes under cornering forces.
yes... the 360 modena is very good for racing, it has good top speed and has the widest wheel base to my knowledge.
... but, personally i still think that the CLK is the most stable between the NSX, 360 and the CLK
GIRBAUD:
pwedeng pwede and AA batts for the micro RS4, if you have the stock kit it comes with a 4cell holder that will accept either AAA or AA batts...
we use either a 5 cell or 6 cell battery pack. some still use AA's but we solder them together. some use the 2/3A which are aslo soldered together to form a pack
For me, the CLK really handles really really well. I have no idea bout the other cars coz i've only owned a clk body. The only problem with the CLK is that if your car has lot of roll at the back, the tires sometimes rub on the fenders, but other than that, there's no problem with it. The side skirts of the CLK also help alot coz it would sometimes stop your car from traction-rolling.
Originally posted by newbie1 meron ako AA batteries 7 cell ni-mh 1300 mah 8.4 volts. ang speed control ko ay futaba MC230CR. Pwede kaya sa micro rs4? thanks
in principle, yes, 'cause the amp draw is not that high...
