Go Back   R/C Tech Forums > International Forums > Manila Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-07-2009, 02:33 PM   #12781
aquila's Avatar
Default futaba
im looking for futaba stick type 6chnnel conquest radio.... old school...
pls pm offer.. sana po meron kayo
0927-295-8663
http://static.rcgroups.com/forums/attachments/4/1/5/1/7/a621809-201-DCP_2572.JPG?d=1129844760[/url]
aquila is offline   Reply With Quote
Old 11-07-2009, 03:04 PM   #12782
cool's Avatar
Default Perfect for your TREX 600
Pasingit lang po.....thanks.
NEW STOCK - Fresh from Hongkong
ZIPPY Flightmax 5000mAh 6S1P 25C 22.2v php6100
contact 0919-3064964
meet up in bacoor or alabang
>freya90 webra.91 gy601 >freya90 os.91 ds760 >raptor90 os.91 c-spec g-lock
>k3d cf webra 55-p5 ds760 >t600esp ds760 >t500esp miniG >t450s cf gy401
>extra300s .46 >pitts epp >edge 540 epp >yak54 epp
>vortex scratch built >coroplast 22b kraum scratch built
>jr12x/pcm9x http://carl-heli.blogspot.com/
cool is offline   Reply With Quote
Old 11-07-2009, 04:50 PM   #12783
Send a message via AIM to GopedAsia Send a message via Yahoo to GopedAsia
Hyperion Chargers now available.
Call me 023343016
Duo3 and 0606i AC/DC with the correct XH tabs are now available.
New G3 lipos for the efreaks out there. 5C charging capable
Of course we still have the bulletproof
Cellpro 4S, Multi4 and 10S
Align Trex600E
Maxum CF 26cc
Telink Sukhoi
Hyperion Yak10e
Kyosho Sunstorm 1000
China Gaser 26cc Boat
JR DSX9 2.4GHZ
Spektrum DX2 2.4GHZ
GopedAsia is offline   Reply With Quote
Old 11-07-2009, 05:29 PM   #12784
gab3r7's Avatar
Default LF: cheap lipo chargers.. budget 1.5k..
Tamiya mesh rims- 400 pesos
-no cracks
-w/ raidal tires 90%
yokomo mesh rims - 400 pesos
-no cracks
-w/yok radials
Evo 7 shell -1.5k with free Yokomo Slide Master set Rims w/slicks
-no cracks
-minor scratches
-with s13 wings
-side mirrors
-tow hooks (front&rear)
-muffler
-painted blue with stripes
-very fresh
Aluminum dampers - 800pesos
-transparent oil casing
-metal finish
-with medium yellow springs
-with oil
wings & canards -250 pesos
-low wing mounts
-sti decals
-pair of canards
hybrid wing -400 pesos
-high gt wing mounts painted silver
-wings painted black
Contact me @ 09274488015
For sure buyers txt me, for inquiries just pm me here im always online thanks
meet ups:
-la salle taft, mcdo taft
-TIR kapitolyo
-edsa central, edsa shaw station mrt
gab3r7 is offline   Reply With Quote
Old 11-07-2009, 06:03 PM   #12785
Default Parts for sale
ram99 is offline   Reply With Quote
Old 11-07-2009, 08:27 PM   #12786
westproof's Avatar
Trader Rating: 31 (97%+)
Pls. visit our website
Magic hand rc airplane
www.alphamodel.ucoz.com
Magic hand airplane
new itemswww.cyclonetoy.com
for inquire Globe 09164306651
sun cell 09239392366
Other Item for Sale http://www.rctech.net/forum/6367085-post11918.html
ENGINE
New DLE55 55CC Gasoline Engine Arriving Soon Reserve 2 pc
YAK54 26-40cc Gas Airplane In Stock 13,500.00
http://www.sdshobby.com/yak54-26 40c...lane-p-55.html
Length: 1690mm (66.5in)
Wingspan: 1850mm (73 in)
Wing area: 65dm2 (1007 sq in)
Engine: 140~180 4C
26-40cc gas
Weight: 4.2-5.0kg (9.1-11 lbs)
Radio:4ch-6ch
Goldwingrc Yak 54 87'' 50cc ARF Almost Ready To Fly Arrving soon Reserve
SPECIFICATIONS
Wing Span:87"(2210mm)
Wing Area:1423sq in(91.8sq dm)
Length:81"(2060mm)
WEIGHT: 15.9-17lbs(7200-7700g)
ENGINE:45-60cc gas
RADIO:4CH/6S
Features:
1,Latest structure
2,Light weight construction and high structural strength
3,Super quality
4,Complete with accessories
5,Easy installation
6,Low wing loading easy to flying
7,Excellent aerobatics and 3D performance
8, Ball linkage control system
9,Advanced PU wheels
10,Anodized 6061 aluminum landing gear
11,Two pieces removable wings and stabs
12Carbon Fiber wing tube
13Anodized Aluminum tail wheel assembly
14Anodized aluminum Long servo arms included
15Fixed ring inside cowling for easy build
30% magichand YAK54 87in 50-60cc RC Gas Airplane Arriving Soon
Length: 1919mm(75.6in)
Wingspan: 2210mm (87in)
Wing area: 87.4dm2(1354sq in)
Engine 50-60cc gas
Weight: 7.3-7.7kg (16-17 lbs)
Radio: 4ch-6ch
Key Features:
• Great aerodynamic designed for 3D and precision aerobatics
• Strong Light Weight Construction
• Professionally covered
• Large control surfaces double beveled for maximum throw
• Cowl with cowl ring
• Fuselage is set up for canister/pipe installation
• Complete hardware included
• Painted aluminum landing gear
• Removable wings and stabs
• Laser cut engine mounting templates and mounting place indicated
Yak 55 26cc RC Model Plane ARF Arriving Soon
PECIFICATIONS:
WING SPAN:71"(1800mm)
LENGTH:67"(1700mm)
WING AREA:1030sq in(66.5sq dm)
FLYING WEIGHT:9.2-10.6lbs(4200g-4200g)
ENGINE:.90-.120(2C) .120(4C) 26-32cc gas
RADIO:4CH/5S
FEATURES:
1,Latest lightweight construction
2,Highest Qulaity
3,Complete accessories
4,Easy installation
5,Low wing loading easy to flying.
6,Excellent aerobatics and 3D performance
7,Powered by electric nitro and gasoline
8,Advanced PU wheels
9.Aerofoil tailplane
10.Canopy and cowling with shockproof silicon rubber blanket
11.Two pieces removable wings with fitted nylon bolts
12.C.F. wing tube
Yak 55 50cc Fire color scheme ARF Plane Arriving Soon Reserve
Wing Span----86.6in/2200mm;
Wing Area----94sq.dm;
Fuselage Length----85.5in/2172mm;
Flying Weight:7300----7700g;
Radio----6Channels 6Servos;
Engine----50CC
New DLE30 30cc gasoline engine [B[/b] Arriving soon Reserve 1 pc
SERVO
Hitec HS-7955TG Servo 3,600 4pcs 2PCS avail.
Hitec HS-65MG Mighty Feather 1,350 2 pcs avail.
Hitec 7985MG 3,000 new stock
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 4.8-6.0 Volt Peak to Peak Square Wave
Operating Voltage Range: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C (-68F to +140F)
Operating Speed (4.8V): 0.16sec/60° at no load
Operating Speed (6.0V): 0.13sec/60° at no load
Stall Torque (4.8V): 144oz/in. (10.4kg.cm)
Stall Torque (6.0V): 172oz/in. (12.4kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Idle Current Drain (4.8V): 3mA at stop
Idle Current Drain (6.0V): 3mA at stop
Current Drain (4.8V): 200mA/idle and 2.0 amps at lock/stall
Current Drain (6.0V): 240mA/idle and 3.0 amps at lock/stall
Dead Band Width: 2usec
Motor Type: Coreless Carbon Brush
Potentiometer Drive: 6 Slider Indirect Drive
Bearing Type: Dual Ball Bearing MR106
Gear Type: 3 Metal, 1 Metal Karbonite Gear
Tower Pro Servo 9G micro servo 350.00
3 pcs avail.
CHARGER
iMax B8 Multifunctional Balance Charger[b] 3,750.00 in stock/B]
iMax B6 Digital Multifunctional Balance Charger 3,250 w/ P.S 3,750 combo 3 pcs avail.
Accesories
Volts Monitor TM (DC 3.7-20V LCD VOLTMETER 1,750.00.00
Opto Gas Engine Kill Switch 1,500
ALUMINUM SPINNER for dle55 3.5" 1,350.00 Sold out arriving soon
3 BLADE aluminum Spinner 3.5" 1,100.00
ALUMINUM SPINNER 3" 1,100.00 ship
Hawk model Propeller
23x8 = 950.00
22x10 = 1.200.00
18x8 = 650.00
14x8 = 550.00
Ignition use Mini Tachometer 1,000 ship Free Y connector
BAttery Nihm/lipo
1.2V 4600mAh Ni-MH Battery 300.00 each 4pcs avail.
Max Power Lipo For Transmitter Spektrum/Futaba/JR radio 1,350.00
Maxforce 11.1v 2200mah 20c 1,450.00
MAX FORCE 20C/3500MAH/7.4V Lipo Battery for rc car 2,250.00
Weight:183 g
http://www.cyclonetoy.com/list_1.asp?id=1216
Heavy duty servo cable 300mm 100.00 ea.
Heavy duty servo cable 600mm 150.00 ea.
5 amp Power supply for B6 and B5 850.00 ship
Brandnew in box intelellect 7.2 volts 3,500 mah nicd stick pack 1,100 ship
Hitec HS-85MG Metal Gear Micro 1,200 ea. 2 pcs stock only
L: 29mm x W: 13mm x H: 30mm (1.14" x 0.51" x 1.18")
Transit: 0.16 sec/60° (4.8V) 0.14 sec/60° (6.0V)
Torque @ 4.8V: 3.0 kg-cm, (41.66 oz-in)
@ 6.0V: 3.5 kg-cm, (48.6 oz-in)
Weight: 21.9g (0.77oz)
T plug connector 3 pcs set male and female 200.00
Program card 450.00
http://www.cyclonetoy.com/list_1.asp?id=122
Telemetry Combo Pack 2,800,000
Key Features
* Monitors temperature to maximize performance and eliminate costly rebuilds
* Battery voltage display prevents runaway crashes
* RPM display shows top-end speed
* Quality of signal monitors RF link strength
* Lap Counter/Timer helps analyze results of performance tweaks
engine head for savage .25 1,000
Hot Bodies UFO Wheels
for the HPI Savage Truck. 2,300 reprice/B][/color]
Edge540 28% DLE55 55CC
Spektrum DX7
www.cyclonetoy.com
Supplier and Distributor of Rc Hobby
westproof is offline   Reply With Quote
Old 11-07-2009, 11:34 PM   #12787
Default LF: Futaba 2Er / Mj 2Phka
looking for BNEW futaba 2ER or futaba MJ 2phka
brand new or fresh(must be really really fresh!).
sana yung complete with servos, crystals and receiver.
budget for BNEW 2er = 2k
budget for BNEW futaba mj = 2.5k
for second hand, please tell me your price.
for other controllers, just contact me. preferably in the 2k-3k range.
0927 240 8443
las pinas, manila, taft, alabang area
mcloving163 is offline   Reply With Quote
Old 11-08-2009, 01:06 AM   #12788
Default selling
Originally Posted by noobstick View Post
for sale mga sirs,
sanwa m11 2.4 ghz TX with RX
kit includes box manuals everything when bought brand new.
protective film still intact.
included after market steering wheel with foam grip for superb looks and function.
with nicad battery pack.
selling for 9k
still in prestine condition, just gathering dust at home
FREE FUTABA s9404 high torque high speed servo. metal gears
call or text me at 09228236833
Attachment 518082
still available!
pwede po trade:
3pk
4pk
dx3r
ill add cash if need be..
noobstick is offline   Reply With Quote
Old 11-08-2009, 02:26 AM   #12789
VooDooPH's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to VooDooPH
Team Petiks Racing - Sarap pumetiks!
VooDooPH is offline   Reply With Quote
Old 11-08-2009, 02:30 AM   #12790
Default For Sale TT01e kit with Full Electronics!!
1) TT01E kit W/ COMPLETE ELECTRONICS!!3,500 only NEG![/b]>
1 month old tt01e kit (includes some scratches of course)used eh.
Stock parts
Ball Bearing transmission
Just broken in silver can motor
Tamiya teu101bk esc (1week old)
Tamiya rx
Tamiya tsu01 servo or futaba s3003
Adjustables steering arms
Upper deck support
Subaru impreza wheels and tires
ARTR nato tx,body nalang ang kulang tatakbo na! Pics to follow :-)
2) BNEW TT01 Mercedes AMG wheels and tires 450 php only
3)Zap PRORACER Subaru Impreza RTR!! CHEAP!!!Very Good Condition! 1,500php nalang para mabilis!!!! TO 1,200 NALANG!!!!
2ch am radio, steering and throttle trim, esc/receiver combo,propotional servo steering, DIY head/tailight,
foglamp and neon led, battery pack charger!!! 2weeks old only :-)
4) 5 days old Tamiya radial rims and type d drift tires (4pcs) 550 php only!
PICS
http://s740.photobucket.com/albums/xx41/bentoy101/
RFS Too many Kits already. . . :-)
Text/call me 09235753444 david :-) or pm me..thanks rctech!! :-)
I can ship if needed...:-) Thank you and Godbless:-)
bentoy101 is offline   Reply With Quote
Old 11-08-2009, 04:14 AM   #12791
Default FOR SALE
HotBodies 2pc Vented Disc Brake Rotor for Savage with Brake pads, fitted but never used nor tested, technicaly bnew 200pesos
HPI 75026 R40 one way front differential (bnew) 300pesos
HOTBODIES Cyclone D4 parts (sold as package) 500pesos
61422 Front Suspension Arm Set
61442 Rear Shock Tower Graphite
61426 Front Hub Carrier
61425 Rear Hub Carrier
HPI 93462 Titanium turnbuckle M3x24mm 2pcs purple 200pesos
HPI R40 Stock Chassis aluminum (purple bnew)
HPI R40 Upgraded/Lightweight/Thick Aluminum Chassis (Silver/bnew) both for 600pesos
SpeedMind Titanium Screws (5packs of 10pcs) 2sets of 3x6mm, 3x15mm, 3x18mm, 3x20mm.. 250pesos
Tamiya Aluminum Heatsink for 540type motor silver, used but not abuse 200pesos
KYOSHO Super10 Chrome Mesh Rims for Front/Narrow (pair) bnew 300pesos
Fuel Line Selector(s) 2pcs used 250pesos
Fuel Line Filters 2pcs Bnew 250pesos
Hirobo Tail Blades (white plastic OEM) bnew 200pesos
Master Airscrew Nylon Propeller 6x11 150each
Futaba battery for reciever 4.8V (Red) that comes with my 9Z WC.... good condition never used... 500pesos
Various Hirobo Parts for Shuttle.. Main Mast are the "hardened type" G-Parts series, sets of drag bolts and button bolts, G-Parts SE wash out control arm.. 300pesos for the package..
Hirobo Blade Holder and Shuttle Vertical Fin.. Used..see the pics, sold as is.. 200pesos
Hirobo Carbon Fiber Boom Support for Eagle WC or .60size heli 300pesos
KSJ Competition 2pcs Muffler for .30size heli 2K
Hirobo Glow Plug Extension for Shuttle ZX/ZXX, Genuine Hirobo/slightly used 250 pesos
KYOSHO Cessna 182 Skylane at KYOSHO Trainer 40 18K for the package
Both Ready to Fly na.. both kit individually equipped with 3003 servos, Futaba Reciever, O.S. 40FX Engine, Proppeller, with battery reciever at voltage indicator.. and they do share one radio.. yes isang "RADIO" lang for both plane and it is a Futaba SkySport.. yung trainer were flewn in Sta. Rosa Laguna siguro for 10hrs while yung cessna ay hindi pa napalipad both in good condition and no defects whatever.. SOLD AS SET LANG PO.. DI PUWEDE BREAK YUNG PACKAGE
No Reservations.. Priority to those who can get the items first.... please indicate your rctech handle when texting para di nakakalito.. lowered na yung price at last price na po.. sobrang baba na at bentang palugi na kaya please.. minimum po sana ng 500pesos worth for meet ups para po di lugi sa pamasahe.. or you can pick up the items near R.Papa station LRT line 1 Thanks po and God bless
09238817827
45caliber is offline   Reply With Quote
Old 11-08-2009, 04:58 AM   #12792
FOR SALE:
OS 50SX-H Ringed Hyper Heli Engine w/ Pipe - 4.5k
new rear and front bearings
Futaba GY401 Heading Hold Gyro - 3.5k
Futaba S9254 Digital Servo - 2.5k (only used twice)
Futaba GY401 Heading Hold Gyro - Futaba S9254 Digital Servo Combo - 5.5k
freebie: will include spare gears set
Futaba S3001 Standard Servo - 300 (6 pcs avail)
Funkey Fiberglass 600mm Main Rotor Blades - 1.2k
PICTURES, PICTURES and PICTURES:
09052893824
Items in Cebu City
mE_bytes is offline   Reply With Quote
Old 11-08-2009, 06:39 AM   #12793
Default KO PROPO HELIOS TRANSMITTER!!!!!!!!!!!
FOR SALE!!!!!!!!!!!!!!!
WITH KO PROPO CARRYING CASE!!!!!!!!!!!
WITH ADJUSTABLE STEERING ANGLE!!!!!!!
27.045 FREQUENCY!!!!!!!!!!!
CALL OR TEXT 09233140287 FOR YOUR OFFERS!!!!!!!!!!!!!!!!!!!!!
GPXJOE is offline   Reply With Quote
Old 11-08-2009, 07:21 AM   #12794
skuter-race-ta's Avatar
Default baja 5b
Originally Posted by bnj26 View Post
mga sirs baka meron kayong kilala na nag bebenta ng 2ndhand hpi baja rtr please pm me or e-mail me at bnj_atilam@yahoo.com thanks asap....
sir pm me your budget baka sakali lang ma kursunadahan ko yung budget nyo hehehe,sariwang sariwa po yung baja ko at hop-up na rin.....
skuter-race-ta is offline   Reply With Quote
Old 11-08-2009, 07:43 AM   #12795
Default CASTER RACING ELECTRIC BUGGY AND TRUGGY
CASTER RACING 1/8 electric Buggy and Truggy
EX-1 ELECTRIC BUGGY
EX-1 race roller - php 9,800
EX-1 race kit RTR with 2.4 ghz radio - php 19,500
EX-1 pro kit - php 18,800 - new stocks coming soon
- pro kits come unassembled with an unpainted body and is the hopped up version of the sports kit.
this is the EX-1 Pro kit
Here is the review of the EX-1 Sports Roller Buggy
http://www.casterracing.com/download...portroller.pdf
F8T ELECTRIC TRUGGY
F8T race roller - php 10,800
F8T race roller RTR with 2.4 ghz radio - php 20,500
F8T pro kit - php 19,800 - new stocks coming soon
all race rollers come 95% pre assembled and could come with
an 80 amp hobbywing esc along with a 2000 kv motor for the buggy or
an 1880 kv motor for the truggy.
for reference on the kit varieties, please check http://casterracing.com
or click this link http://casterracingph.multiply.com/ or http://www.girljpg.cn/
ex-1 buggy video - http://www.youtube.com/watch?v=fwKS946fnm8
f8t truggy video - http://www.youtube.com/watch?v=JjVHbbCeW70
pickup at fort boni area, pasig bayan area, trinoma area, or any with near
proximity from the said areas. shipping could be arranged too.
send me a pm if u have a lot of questions, or you could reach me
at 0917-8463429.
...and yes, parts are available too.
thank you.
octopus prime is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
Forum Jump
Non RC Related Stuffs on Sale stik Singapore R/C Racers 2340 Yesterday 06:35 PM
Non RC's Stuffs Buy and Sell Spider-silver Indonesia Racing 12 08-01-2006 10:43 PM
Non RC Related stuffs Hobby Peoples Hong Kong Racing 14 12-25-2004 05:30 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
