Go Back   R/C Tech Forums > International Forums > Manila Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-03-2009, 03:32 PM   #12721
westproof's Avatar
Trader Rating: 31 (97%+)
Pls. visit our website
Magic hand rc airplane
www.alphamodel.ucoz.com
Magic hand airplane
new itemswww.cyclonetoy.com
for inquire Globe 09164306651
sun cell 09239392366
Other Item for Sale http://www.rctech.net/forum/6367085-post11918.html
ENGINE
New DLE55 55CC Gasoline Engine Arriving Soon Reserve 1 pc
Goldwingrc Yak 54 87'' 50cc ARF Almost Ready To Fly Arrving soon Reserve
SPECIFICATIONS
Wing Span:87"(2210mm)
Wing Area:1423sq in(91.8sq dm)
Length:81"(2060mm)
WEIGHT: 15.9-17lbs(7200-7700g)
ENGINE:45-60cc gas
RADIO:4CH/6S
Features:
1,Latest structure
2,Light weight construction and high structural strength
3,Super quality
4,Complete with accessories
5,Easy installation
6,Low wing loading easy to flying
7,Excellent aerobatics and 3D performance
8, Ball linkage control system
9,Advanced PU wheels
10,Anodized 6061 aluminum landing gear
11,Two pieces removable wings and stabs
12Carbon Fiber wing tube
13Anodized Aluminum tail wheel assembly
14Anodized aluminum Long servo arms included
15Fixed ring inside cowling for easy build
30% magichand YAK54 87in 50-60cc RC Gas Airplane Arriving Soon
Length: 1919mm(75.6in)
Wingspan: 2210mm (87in)
Wing area: 87.4dm2(1354sq in)
Engine 50-60cc gas
Weight: 7.3-7.7kg (16-17 lbs)
Radio: 4ch-6ch
Key Features:
• Great aerodynamic designed for 3D and precision aerobatics
• Strong Light Weight Construction
• Professionally covered
• Large control surfaces double beveled for maximum throw
• Cowl with cowl ring
• Fuselage is set up for canister/pipe installation
• Complete hardware included
• Painted aluminum landing gear
• Removable wings and stabs
• Laser cut engine mounting templates and mounting place indicated
Yak 55 26cc RC Model Plane ARF Arriving Soon
PECIFICATIONS:
WING SPAN:71"(1800mm)
LENGTH:67"(1700mm)
WING AREA:1030sq in(66.5sq dm)
FLYING WEIGHT:9.2-10.6lbs(4200g-4200g)
ENGINE:.90-.120(2C) .120(4C) 26-32cc gas
RADIO:4CH/5S
FEATURES:
1,Latest lightweight construction
2,Highest Qulaity
3,Complete accessories
4,Easy installation
5,Low wing loading easy to flying.
6,Excellent aerobatics and 3D performance
7,Powered by electric nitro and gasoline
8,Advanced PU wheels
9.Aerofoil tailplane
10.Canopy and cowling with shockproof silicon rubber blanket
11.Two pieces removable wings with fitted nylon bolts
12.C.F. wing tube
Yak 55 50cc Fire color scheme ARF Plane Arriving Soon Reserve
Wing Span----86.6in/2200mm;
Wing Area----94sq.dm;
Fuselage Length----85.5in/2172mm;
Flying Weight:7300----7700g;
Radio----6Channels 6Servos;
Engine----50CC
New DLE30 30cc gasoline engine Sold Out Arriving soon
SERVO
Hitec HS-7955TG Servo 3,600 4pcs 2PCS avail.
Hitec HS-65MG Mighty Feather 1,350 2 pcs avail.
Hitec 7985MG 3,000 new stock
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 4.8-6.0 Volt Peak to Peak Square Wave
Operating Voltage Range: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C (-68F to +140F)
Operating Speed (4.8V): 0.16sec/60° at no load
Operating Speed (6.0V): 0.13sec/60° at no load
Stall Torque (4.8V): 144oz/in. (10.4kg.cm)
Stall Torque (6.0V): 172oz/in. (12.4kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Idle Current Drain (4.8V): 3mA at stop
Idle Current Drain (6.0V): 3mA at stop
Current Drain (4.8V): 200mA/idle and 2.0 amps at lock/stall
Current Drain (6.0V): 240mA/idle and 3.0 amps at lock/stall
Dead Band Width: 2usec
Motor Type: Coreless Carbon Brush
Potentiometer Drive: 6 Slider Indirect Drive
Bearing Type: Dual Ball Bearing MR106
Gear Type: 3 Metal, 1 Metal Karbonite Gear
Tower Pro Servo 9G micro servo 350.00
3 pcs avail.
CHARGER
iMax B8 Multifunctional Balance Charger[b] 3,750.00 in stock/B]
iMax B6 Digital Multifunctional Balance Charger 3,250 w/ P.S 3,750 combo 3 pcs avail.
Accesories
Volts Monitor TM (DC 3.7-20V LCD VOLTMETER 1,750.00.00
Opto Gas Engine Kill Switch 1,500
ALUMINUM SPINNER for dle55 3.5" 1,350.00 Sold out arriving soon
3 BLADE aluminum Spinner 3.5" 1,100.00
ALUMINUM SPINNER 3" 1,100.00 ship
Hawk model Propeller
23x8 = 950.00
22x10 = 1.200.00
18x8 = 650.00
14x8 = 550.00
Ignition use Mini Tachometer 1,000 ship Free Y connector
BAttery Nihm/lipo
1.2V 4600mAh Ni-MH Battery 300.00 each 4pcs avail.
Max Power Lipo For Transmitter Spektrum/Futaba/JR radio 1,350.00
Maxforce 11.1v 2200mah 20c 1,450.00
MAX FORCE 20C/3500MAH/7.4V Lipo Battery for rc car 2,250.00
Weight:183 g
http://www.cyclonetoy.com/list_1.asp?id=1216
Heavy duty servo cable 300mm 100.00 ea.
Heavy duty servo cable 600mm 150.00 ea.
5 amp Power supply for B6 and B5 850.00 ship
Brandnew in box intelellect 7.2 volts 3,500 mah nicd stick pack 1,100 ship
Hitec HS-85MG Metal Gear Micro 1,200 ea. 2 pcs stock only
L: 29mm x W: 13mm x H: 30mm (1.14" x 0.51" x 1.18")
Transit: 0.16 sec/60° (4.8V) 0.14 sec/60° (6.0V)
Torque @ 4.8V: 3.0 kg-cm, (41.66 oz-in)
@ 6.0V: 3.5 kg-cm, (48.6 oz-in)
Weight: 21.9g (0.77oz)
T plug connector 3 pcs set male and female 200.00
Program card 450.00
http://www.cyclonetoy.com/list_1.asp?id=122
Telemetry Combo Pack 2,800,000
Key Features
* Monitors temperature to maximize performance and eliminate costly rebuilds
* Battery voltage display prevents runaway crashes
* RPM display shows top-end speed
* Quality of signal monitors RF link strength
* Lap Counter/Timer helps analyze results of performance tweaks
engine head for savage .25 1,000
Hot Bodies UFO Wheels
for the HPI Savage Truck. 2,300 reprice/B][/color]
Edge540 28% DLE55 55CC
Spektrum DX7
www.cyclonetoy.com
Supplier and Distributor of Rc Hobby
westproof is online now   Reply With Quote
Old 11-03-2009, 04:16 PM   #12722
CARakter's Avatar
Anybody know where I can get new A123 cells? I need 2 pcs.
Directions to t-Pond: (copy paste) http://www.rctech.net/forum/4332481-post1607.html
CARakter is offline   Reply With Quote
Old 11-03-2009, 09:59 PM   #12723
Arrow RC STUFF FOR SALE.
FOR SALE.
CASH ONLY, NO TRADES/SWAPS.
PICK UP ONLY. UNABLE TO SHIP.
1.0) B/N 540 SIZE KINGPOWER(SAME MANUFACTURER OF CASTLE MOTORS) 3000KV SENSORLESS
BRUSHLESS MOTOR. SAME MOTOR LEADS/4MM BULLET CONNECTORS, CAN CONFIGURATION AND
ENDBELL RETAINING SCREWS AS CASTLE MOTORS.----------------------------------------------------P2,300.
2.0) B/N TEAM POWERS 540 SIZE 4300KV SENSORLESS BRUSHLESS MOTOR WITH 3.5MM BULLET
CONNECTOR MOTOR LEADS.--------------------------------------------------------------------------P2,300.
3.0) B/N 1 PAIR BY ENERGY e.c. 2S 7.4V 5000MAH 35C LIPO BATTERIES. DEANS TYPE PLUG/10
GAUGE HIGH CURRENT LEADS, 175 AMPS CONTINUOUS. SLIM SIZE 137MM X 45MM X 19MM
FITS 140MM LONG BATTERY BOXES. SOLD ONLY AS A PAIR.--------------------------------------------P6,200.
4.0) B/N BY ENERGY e.c. 2S 7.4V 5000MAH 15C LIPO BATTERY. DEANS TYPE PLUG/12 GAUGE
CURRENT LEADS, 75 AMPS CONTINUOUS. MORE CONTINUOUS AMPS/VOLTS THAN 7.2V 3800
MAH NIMH BATTERIES.-------------------------------------------------------------------------------P1,600.
5.0) B/N TOWER PRO MG995 HIGH TORQUE SERVO. .13SEC/60 DEGREES AND 208 OZ/IN. TORQUE
@ 6V. METAL GEARS, 40 X 20 X 36.5MM, WITH SERVO HORNS & MOUNTING HARDWARE. U.S.
PURCHASED
.------------------SOLD OUT, MORE NEXT WEEK-------------------------------------------------.
5.1) 2 PCS. OF THE ABOVE 5.0 .----------------------------------------------------------------------------.
6.0) B/N RC-MONSTER MOTOR MOUNT FOR EP CONVERSION OF CRT.5.----------------------------------P2,200.
PICK UP IS BETWEEN 10A.M.- 4P.M. WORK WEEKDAYS, AT THE OFFICE AT THE EDSA-GREENHILLS
AREA. NO PRIVATE MESSAGES PLEASE. KINDLY INCLUDE FULL NAME OR RCTECH USERNAME WHEN
TEXTING TO DON AT 0927-4776177. THANKS TO RCTECH.NET, MODERATORS & TO ALL FOR BROWSING.
don74 is offline   Reply With Quote
Old 11-03-2009, 11:09 PM   #12724
Mark Flores's Avatar
Trader Rating: 17 (100%+)
Ko Propo Esprit Vantage II Stick Type Transmitter
With Receiver (K301f) and Crystals 40mhz
Like new.
P3,500 only
0918 948 77 39
Mark Flores is offline   Reply With Quote
Old 11-04-2009, 12:43 AM   #12725
Default LOOKING FOR
im looking for KO PROPO FM 27MHz CRYSTAL 1 set for EX10 HELIOS(TX/RX) thx . . . . pls. txt 09291868779 sori guys newbie lng
Last edited by chicha_and_edi; 11-04-2009 at 03:02 AM. Reason: wrong input of cp number
chicha_and_edi is offline   Reply With Quote
Old 11-04-2009, 02:32 AM   #12726
Default For Sale and LOoking For!!
For Sale:
1) 8 days old Tamiya Sport Tuned Motor 400 php only!
2) Bnew Traxxas Female to Tamiya Male Connector 250 php only
3) Bnew tt01 AMG Mercedes wheels and tires (4) 450 php only
4)1 month old Tamiya Sportpack 1700 nicd 500 php only
5) Bnew Teu101bk esc and almost new sport tuned 23t motor combo 1500php Only!!!
6) Almost new Tamiya Radial rims(chrome) and type d drift tires 700php only(4pcs) 5days old only!!
Text or pm me 09235753444 david .Items in cebu..I can ship if needed :-) Thanks rctech and Godbles!!
Looking For
1) TT01 Alloy Shaft 300 lang sana
2) Super Stock Rz motor 400 lang sana
3) Any TT01 Body Shell 600-700 lang sana..:-)
Text or pm me for your offers :-)
bentoy101 is offline   Reply With Quote
Old 11-04-2009, 05:45 AM   #12727
Default looking for a cheap rx/tx
looking for a cheap rx tx..
27 mhz am radio
text me 09179170743
call me 09228011128
800 buget
123takbo is offline   Reply With Quote
Old 11-04-2009, 05:59 AM   #12728
r4rosal's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to r4rosal
27 mhz am radio
text me 09179170743
call me 09228011128
800 buget
pls. check ur PM.
thanks
Wild Willy 2, Tmaxx 2.5, Revo 2.5
r4rosal is offline   Reply With Quote
Old 11-04-2009, 07:03 AM   #12729
Lightbulb LF: BNEW TEU-101BK
looking for an esc. preferably teu-101bk. or other esc's.
budget is 500-800
0927 240 8443
las pinas, manila, taft, alabang area
mcloving163 is offline   Reply With Quote
Old 11-04-2009, 08:51 AM   #12730
RadioControlled's Avatar
RadioControlled is offline   Reply With Quote
Old 11-04-2009, 03:47 PM   #12731
Originally Posted by kawahara View Post
- SERPENT 720 08 VERSION KIT
w/ box and manual
hop ups included
fresh
- NOVAROSSI PLUS2 353 08VERSION .12 ENGINE
w/ box and manual
very good compression
w/ new conrod and bearings
- PROTOFORM DODGE STRATUS BODY
bnew and sealed
- TORNADO FUEL W/ EXCEED FUEL BOTTLE
1/4 lang ang bawas
- TITAN IGNITER
- NOVAROSSI PIPE 2601 W/ MANIFOLD
fresh
sold as set
http://s686.photobucket.com/albums/v...t=IMG_4517.jpg
13k neg
09189239320
bili na
kawahara is offline   Reply With Quote
Old 11-04-2009, 05:48 PM   #12732
Pirty's Avatar
Send a message via Yahoo to Pirty
Looking for DF03, DF03RA, TT-01, TL01......pref RTR....
I need 5 sets...
also 1/8 Buggy, truggy and Monster Truck.
09228224217
09178224217
YAK 54 .25FX - SIG KADET SENIOR - GRAUPNER SP 2300 - FIDGET
SLOWSTICK - KYOSHO 1/6 CLIPPED WING CUB - EFLITE MINI FUNTANA
SANWA RDS8000
Pirty is offline   Reply With Quote
Old 11-04-2009, 05:59 PM   #12733
combatrock's Avatar
Default DNA SLINGSHOT CHASSIS
Originally Posted by combatrock View Post
FOR SALE:
COMPLETE CRAWLER KIT
- DNA SLINGSHOT CHASSIS
- AXIAL Locked Diff Set
- AXIAL TRANS
- AXIAL Alum Hub Carrier
- AXIAL Aluminum Rear Axle Lock-out
- Aluminum Steering Knuckle
- JUNFAC Universal Shaft (stainless steel)
- 3RACING Heavy Duty Bevel Gear Set
- NOVAK ROOSTER CRAWLER EDITION ESC
- HOT BODIES ROVER TIRES
- GMADE Wheels
- HITEC Servo
- GMADE Motor
- TRAXXAS GT Aluminum Shocks
P17K
COMPLETE WITH RADIO AND LIPO BATTERY
QUEZON CITY AREA
0917-8603419
still available
combatrock is offline   Reply With Quote
Old 11-04-2009, 07:45 PM   #12734
VooDooPH's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to VooDooPH
Team Petiks Racing - Sarap pumetiks!
VooDooPH is offline   Reply With Quote
Old 11-04-2009, 08:13 PM   #12735
batang's Avatar
for sale
brand new hyper .21-.28 pull start:800
brand new stock ofna pipe and manifold:800
spare only futaba R152JE 27mhz AM receiver: 1k
http://www3.towerhobbies.com/cgi-bin...&I=LXMRE6&P=ML
slightly used futaba fail safe:1k
http://www3.towerhobbies.com/cgi-bin...&I=LXJDF8&P=ML
brand new HPI roto start back plate system:900
http://www.amainhobbies.com/product_...oducts_id/4429
b-new 1 pc thunder tiger voltage regulator with switch 11v,7.4 v to 6v- 500
b-new side guard for mugen mbx6- 500
b-new mugen 13t clutch bell-800
b-new proline badlands 1/8 buggy wheels free glued- 2k
brand new XUT Dish wheel (4pcs)17mm 1/2 off set (white)-1K
http://www.rctech.net/forum/manila-r...-03062008-008-
brand new pro-line edge 2.2 w/d rims-1k
http://www.amainhobbies.com/product_...oducts_id/2116
brand new hpi dirtbonz tire and rims 2.2 good for mt2-1.6k
some pictures at
page 610
page 625
page 654
txt or call:jason 09165904356
batang is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
westproof
Forum Jump
Non RC Related Stuffs on Sale stik Singapore R/C Racers 2340 Yesterday 06:35 PM
Non RC's Stuffs Buy and Sell Spider-silver Indonesia Racing 12 08-01-2006 10:43 PM
Non RC Related stuffs Hobby Peoples Hong Kong Racing 14 12-25-2004 05:30 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
