Go Back   R/C Tech Forums > International Forums > Manila Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-19-2008, 10:24 PM   #16
rectifier512's Avatar
Post
FOR ALL NOVAK FANS!!!
SPEEDOS FOR SALE:
NOVAK GT7 (W/ ORIGINAL CAPACITOR) - 3.5K
NOVAK FUSION (DUAL PROFILE ESC) - 2.5K
SOME MORE....
FUTABA FP-R122JE AM RECEIVER (2 PCS.) - 500/EA
FUTABA TX 2ER (STICK) - 5OO
09273161250 (MKTI/ QC)
WRATH
XRAY / KO PROPO / MUCHMORE / FUTABA / PROTOFORM
rectifier512 is offline   Reply With Quote
Old 02-19-2008, 10:27 PM   #17
Default for sale plane engine and futaba s3001 servo
*OS MAX 46sf used 3.5k
*25 thunder tiger engine for PHP2,000
*4 servo(3 futaba s3001 and 1 generic servo) for php1,500 sold
09287751101
buy-sell-thread-19feb08-rc-related-stuffs-only-image000.jpg   buy-sell-thread-19feb08-rc-related-stuffs-only-image001.jpg
torogi is offline   Reply With Quote
Old 02-19-2008, 10:37 PM   #18
miniracer's Avatar
Default fs:servos
for sale, items in great condition
futaba 9451 high speed digital servo 2.5k
sanwa erg-vrx high speed servo(blue anodized case) 2.8k
prices are negotiable
09209209674
miniracer is offline   Reply With Quote
Old 02-19-2008, 10:43 PM   #19
Send a message via Yahoo to joji_say
FOR SALE:
TAMIYA MINI COOPER M03 (BNEW) P7,000
- assembled
- ball bearings
- TRF shocks
- alum wheel nut
- alum rear arm
- alum rear hub
- alum c-hub
- stabs
- with esc/motor
- painted body (red)
- box and manual
TEAM TRINITY BRUSH BUTCHER P3,500
- slightly use
- with slave motor
- box and manual
NOVAK FLATLINE DISCHARGER P500
- bnew
- box and manual
NOVAK BRUSHLESS MOTOR 13.5 P3,000
- slightly use
- 27T
KO PROPO HELIOS EX-10 WITH SPEKTRUM MODULE P11,500
- slightly use
- box and manual
SPEEDMIND TRANSMITTER BAG P600
- for m11
HUDY TOOLS 12 pcs P6,000
- SOLD AS SET
- socket driver 5.0mm
- socket driver 1/4" (6.35mm)
- socket driver 3/8" (9.525mm)
- socket driver 4.5mm
- socket driver 5.5mm
- socket driver 11/32" (8.731mm)
- socket driver 8.0mm
- ball allen wrench 2.5mm
- ball allen wrench 2.0mm
- allen wrench .093 (3/32")
- allen wrench .063 (1/16")
- allen wrench 0.50
TEAM ASSOCIATED TC5 KIT P12,000
- fresh
- alum center pulley mount
- ITF upper deck
- alum spool
- spare parts belt, front/rear suspension arms
- white front belt
- RPM ball caps
- box and manual
MUCHMORE ALUM TRAY P1,000
- bnew
- screw tray
TEAM LOSI MICRO-T P3,500
- almost new
- RTR
- no batts
EAGLE RACING BATTERY COOLING STAND P800
- bnew
- box and manual
CALL/TEXT 0917-5295252
joji_say is online now   Reply With Quote
Old 02-19-2008, 10:46 PM   #20
westproof's Avatar
Trader Rating: 31 (97%+)
I will take orders starting Feb 18 up to March 5 2008
cheap price good quality giant rc airplane,boat,nitro engine,gasoline engine
All of our products comply with international quality standards
Check our accesories and engine parts for DL50
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=54
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=67
Arriving SOON
Imax B5 charger 3,200
Imax B6 charger 3,900
IMAX B8 charger 6,300
Tower pro Servo mg995 950.00
Tower pro Servo mg945 950.00
11.1V 2200mah 20C Li-Polymer Battery 1.750
11.1V 1600mah 8C Gun-TypTransmitterLipo 1,600
11.1V 1500mah 15C Li-Polymer 1,600
7.4V 2200mah 20C Li-Polymer Battery 1,550
7.4V 3500mah 25C battery 2,800.00
NEW
Wing Span: 69.2in/1760mm
Wing Area: 960sq in/62sq dm
Flying Weight: 10.0lbs/4570g (Fiberglass)
Fuselage Length: 66.2in/1684mm
Engine Required: 2C 0.90 cu in ; 4C 1.20 cu in
Radio Required: 4 Channels, 5 Servos
You can visit our website
www.cyclonetoy.com www.cheapricequalityrc.zoomshare.com
30% YAK 54 50 CC 85" WING SPAN P 22,500 / combo DL 50cc = P35,500 in stock
Carbon fiber tube
fiber glass cowl
with 22x 10 wood prop
30% EDGE 540 50 CC 85" WING SPAN P 20,500 / combo DL50cc = P=31,500 in stock low price carbon fiber boom
fiber glass cowl
with 22 x 10 propeller
U-BEC = P 600.00 in stock
> Input voltage: 11.1V/18V
> Output: 5.0V/6.0V
> Current capability: 3A
> Size(mm): 20X30X7
Rx-Regulator - P 600.00 in stock
> Use only2-cell(7.4V)
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
spark plug dl 50 = 460 each 4 pcs in stock
Call or text.cell no. 09158884491 / 045 8660458 look for alvin
Email: alphagolf221@yahoo.com[
Edge540 28% DLE55 55CC
Spektrum DX7
www.alphamodel.ucoz.com
www.cyclonetoy.com
Supplier and Distributor of Rc Hobby
westproof is offline   Reply With Quote
Old 02-19-2008, 10:51 PM   #21
politpot's Avatar
for sale GS STORM SUT
current parts
-sh .28 engine (good condition, perfect for bashing)
-fioroni option team clutch 6 point
-fioroni option team dual chamber pipe
-fioroni option team chassis (black)
-carbon fiber radio tray
-titanium shock tower
-crime fighter mounted on ofna dish wheel
-new engine mount
extras
-1 dogbone
-kyosho brake pads, (still new, nasa plastic pa)
-extra fioroni option team chassis (blue) and the original chassis
-engine mount
-new lower arm
-also the original plastic parts
this kit is converted to pro kit...perfect for racing...already won at qc track...
selling for 11k....
txt or call 09163737814/09294399525
pls indicate ur rctech and real name when txting...thanks po...
buy-sell-thread-19feb08-rc-related-stuffs-only-111.jpg   buy-sell-thread-19feb08-rc-related-stuffs-only-222.jpg
politpot is offline   Reply With Quote
Old 02-19-2008, 11:00 PM   #22
deore's Avatar
Trader Rating: 19 (95%+)
Default FOR SALE:
sold
deore is online now   Reply With Quote
Old 02-19-2008, 11:34 PM   #23
putok's Avatar
Trader Rating: 17 (100%+)
FOR SALE:
ASSORTED AM 27MHZ RADIO W/ RECEIVER & XTAL
HPI TF3 w/ kyosho perfex receiver(27.045) - php1.4k
HPI TF3 w/ futaba FP-R102JE receiver(27.255) - php1.5k
Futaba S3003 SERVO - php500
B/NEW ARROW SHARK FLYING DRAGON GAS BOAT - php36k
-Semi rtr (still sealed in box)
-JZ 260M unleaded gas engine pullstart
-steel tuned pipe
-complete hardwares like trim tabs,turn pins, rudder, strut
-octura 3/16 x 478 propeller
-no electronics
-w/ manual, boat stand
- pictures below is the same as the one for sale except the cover is blue.
txt / call 0920-9093580.
buy-sell-thread-19feb08-rc-related-stuffs-only-arrow-shark-flying-dragon-unleaded-gas-boat.jpg   buy-sell-thread-19feb08-rc-related-stuffs-only-12312007078-small.jpg
putok is offline   Reply With Quote
Old 02-19-2008, 11:43 PM   #24
r4rosal's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to r4rosal
Default looking for:
looking for the ff. savage part:
#86082 CUP JOINT 6x13x20mm (BLACK/2pcs)
kahit used na basta ok pa.
much better kung b/new
r4rosal is offline   Reply With Quote
Old 02-20-2008, 12:20 AM   #25
porsche boy's Avatar
Default RC stuff for sale
porsche boy is offline   Reply With Quote
Old 02-20-2008, 12:30 AM   #26
VooDooPH's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to VooDooPH
Team Petiks Racing - Sarap pumetiks!
VooDooPH is offline   Reply With Quote
Old 02-20-2008, 12:38 AM   #27
bmmer701's Avatar
team checkpoint charger -7k neg
slighly used with brand new temp probe.
rfs: have two checkpoint
peak orion 4800 lipo - 4kneg
natatangal lang yung parang logo na peak racing dahil sa tape
with lead weights para kasing bigat na niya halos yung 6 sub c
rfs: have 3 4800, then going back to sub c for mod (5cells)
package deal:
10.5k neg if you'll get both.
TA05MS like new 13k
09178134619 or 09228234619
bmmer701 is offline   Reply With Quote
Old 02-20-2008, 01:56 AM   #28
rs550's Avatar
Send a message via AIM to rs550 Send a message via Yahoo to rs550
bro try mo sa action hobbies ...6336358
rs550 is offline   Reply With Quote
Old 02-20-2008, 01:58 AM   #29
Default For Sale
2nd Hand R/C for Sale
1/10 Traxxas 4TEC Nitro Touring Car (Stock)
Specifications:
.15 TRX Pro Engine w/ EZ-Start
2 Speed Transmission
Full Ball Bearing
Stock Manifold & Pipe
Stock Oil-Filled Shocks
BN Futaba S3003 Steering & Throttle Servo
Original Traxxas Body
90% New Exceed Foam Tyres+Rim
w/ Box & Manual
1 Extra Dodge Stratus Body
LS FM Synthesized Receiver & Controller
4 AA Fresh Alkaline Battery for receiver
EZ-Starter w/o Batt.
7K Fixed na po
1:10th Serpent Impulse Pro 4WD R/C Touring Car
Specifications:
.12 OS MaxTR Engine (good for bashing)
Ventilated Disk-Brake
Foam Tyres+Rim
Full Ball Bearing
Electronics:
-Standard Servo (Steering & Throttle)
-12V Starter Box w/o Batt.
-13.8V 10Amp Switching Power Supply for Starter Box
Extra:
-Body
-Used spare parts
-Printed Manual
5K Fixed na po
RFS: upgrade to 1/8 scale off-road R/C
Call or Txt Rodel: +639185072593
rodelgalvan is offline   Reply With Quote
Old 02-20-2008, 02:14 AM   #30
curious mind's Avatar
Novak EVX ESC with 2 titan 550 motors
-Input Voltage: 12 cells (14.4V) to 14cells (16.8V)
-Thermal Shutdown
-19-27 Turns capable
-perfect for EP Monster Truck
-5k package
Team Atlas Battery Heatsink/Jig
-good as new
-2k
Assorted 27t motor
-(tuned for racing preference)
-fresh/mint/fast...
-800 each
Pick up point is makati Pasong tamo or QC (araneta ave) area.
PM lang if intereted
curious mind is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
deore , mE_bytes
Forum Jump
Non RC Related Stuffs on Sale stik Singapore R/C Racers 2340 Yesterday 06:35 PM
Non RC's Stuffs Buy and Sell Spider-silver Indonesia Racing 12 08-01-2006 10:43 PM
Non RC Related stuffs Hobby Peoples Hong Kong Racing 14 12-25-2004 05:30 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
