Help on my ESC M230CR
Help on my ESC (futaba MC230CR)
Mga RC experts help naman po:
I just installed a futaba mc230 esc sa stadium raider ko and i have certain questions re this kasi japanese ung manual na binigay sa akin eh. Anyway, here are my questions:
1. Does the esc also beeps (beeping sound with LED) when my RC Batt drains out?
2. How do i properly set-up its functions?
Here's how i do it:
a. turn on both transmitter and car power
b. press the button of the esc at neutral
c. press the button of esc at high throttle
d. press the button of esc at high brake
Thankyou thankyou
Here's how i do it:
Thankyou thankyou
Answer to your question...
Here are the answers to your questions...
1. NO. the ESC only beeps when it detects a loss of signal from the transmitter such as when your transmitter loses power or if you turn it off by mistake...
2. To set up the ESC to your radio transmitter:
-set all throttle trims and subtrims to neutral.
-turn on Transmitter and ESC.
-press SETUP button on ESC for 3 seconds or more.
-pull trigger of Transmitter then press SETUP
-push trigger of Transmitter then press SETUP
To engage Forward/Brake only function:
-push SETUP button while turning ESC power on
To engage Forward/Reverse function again:
-same as above...
-same as above...
