News @ Mini Z Element
#61
#62
#63
#64
#65
#66
Dear All Racer,
Coming Up next MMC Round 10 @ Mini-Z Element.
Date & Time.
Race10 Mini Z Element 26-10-2013 11am
Kyosho Malaysia Mini Z Malaysia Cup 2014
Every participants have chance to win a Lucky Draw & cash voucher. Don’t Miss it.
Rules And Regulations.
(Update Feb 2014)
NEW! Weight handicap system for stock class
Racer who get the A main 1st, 2nd winning cars minimum weight specification then carry until end of the season.
Maximum weight handicap attributed to winning cars will be 30 grams.
Example:
Racer X race result :
1st Race
Position: A Main 1st
Minimum weight: 170 grams (+5 grams for next race)
2nd Race
Position: A Main 5
Minimum weight: 175 grams
3rd Race
Position: A Main 3
Minimum weight: 175 grams (+5 grams for next race)
And so on until minimum weight specification reached 200 grams (170 grams + 30 grams).
No further extra weight will be add to the following race.
Car Specification
Chassis
- Open to all 1/27 on road cars, i.e. Kyosho Mini Z MR01, MR015, MR02, MR03, MA010, MA015, MA020, Firelap, Iwaver and X-mod.
Body Shell
- Kyosho, Gogo lap, TRP and Firelap Body shell are allowed.
- Pan Car and Lemans body are not allowed in both stock and modified class.
- Judges reserve the right to disqualify a body for excessive material removal.
- All windscreens must be remaining secure in the body shell.
- Lexan Body are not allowed
- Lexan window and Lexan wing are allowed
Motor
Stock Class
- PNWC Official 70 Turns Stock Motor for Stock Class
- Silver and carbon brush allowed to change.
- Motor must run with original motor can, original magnet and original armature. No ball bearing modification to the Motor can.
Open Class
- Brush and brushless are allowerd. Any modification to the motor are allowed
Wheel
- Unlimited.
PCB Board
- Only original Kyosho, Atomic, Firelap or X-mod PCB boards are allowed. FET upgrade is allowed. External Turbo is allowed.
- Gyro are allowed in both class
Battery
- Car must be powered by four AAA size batteries. No more, No less.
- Batteries must be Alkaline, NiMH, or NiCd.
- No other type of battery is allowed. / For example: Lithium Polymer batteries are not allowed.
- Extra Capacitor is allowed.
Tyre
- Any Brand: Rubber Tyre only on RCP. Silicone tyre only on Carpet.
- No foam tires allowed.
- No traction compounds allowed on tires, or race surface.
- Tire warmers are allowed / Tires only cleaned with a 70% alcohol solution.
WEIGHT, WIDTH & HEIGHT
- Minimum weight (170g)
- Max wheel base (98mm)
- Max car length (180mm)
- Max car width (80mm)
- Max car height with wings (45mm)
Transmitter
- Any brand transmitter.
Lap counting system
- Robitronic transponder system
- Race organizer will on the lap counting system 1 hour for testing. Driver are encourage to test and make sure the transponder is place in the correct matter.
- In our pass experience, miss lap is due to driver handle the transponder not correct. Miss lap is responsible by the racer.
- Race organizer final result is the final result.
Marshal
- Drivers are responsible and compulsory to be a marshal when the other groups or mains is in racing. For example A main drivers need to be B Main marshal when B main is racing or vice versa. Penalty will be imposed for drivers who fail to be a marshal.
Race Detail
Mains Grouping
- Main will be justified by the qualifying hits on the race day.
Pre Qualifying
- Pre Qualifying 5 Minutes, Single BEST lap times will use for qualifying grouping.
Qualifying Hits
- 3 x 5 minutes qualifying time, starting grid position to determine by the qualifying hits.
- There will be three qualifying runs for each class.
- Each run will last 5 minutes.
- No change group during qualifying
Race Format
- A Main
3 x 10 minutes final.
- 2 best final result will recorded at point system.
- B and C Main
2 x 10 minutes final
- 1 best final result will recorded at point system.
- Point system is according to following
1st 1p
2nd 2p
3rd 3p and so on
Lowest point racer win
- If there is same point occur between drivers, driver who get the best result in the best 2 final will be the champion.
- Example:
Driver A best 2 results are 1st and 3rd. Total point is 4.
Driver B best 2 results are 2nd and 2nd. Total point is 4.
Driver A best lap is 52 laps 10.00.00 for 3 races
Driver B best result is 52 laps 10.01.000 for 3 races
- Champion goes to driver A because Driver A have the best result.
Fees
- RM30 per class including track fees.
- RM5 for transponder rental for who do not have personal transponder.
Result
- There will be 11 races in 2014. The best 6 results will be chosen to calculate position.
Point System
1st - 25 point
2nd - 20 point
3rd - 16 point
4th - 13 point
5th - 11 point
6th - 10 point
7th - 9 point
8th - 8 point
9th - 7 point
10th - 6 point
11th - 5 point
12th - 4 point
13th - 3 point
14th - 2 point
15th - 1 point
Top qualifier (Qualifying A Main 1st)
1 point
Note:
Due to limited pit stop place in Mini Z Dynasty, Mini Z Element and One Mini Z. Participants are encouraged to well organize the pit stop area.
Any loss, broken or stolen item are not responsible by Mini Z Dynasty, Mini Z Element and One Mini Z.
Rules will be update from time to time.
Organized by:
MINI Z DYNASTY
MINI Z ELEMENT
ONE MINI Z
Sponsor by:
ATOMIC
PN RACING
Management reserves the right to change and update the rules and regulation without prior notice.
For update info please refer :
https://www.facebook.com/malaysiaminizcup
Date & Time.
(Update Feb 2014)
Example:
1st Race
2nd Race
Position: A Main 5
3rd Race
Position: A Main 3
Car Specification
Chassis
Body Shell
Motor
Stock Class
Open Class
Wheel
- Unlimited.
PCB Board
Battery
Tyre
Transmitter
Lap counting system
Marshal
Race Detail
Mains Grouping
Pre Qualifying
Qualifying Hits
Race Format
- A Main
- B and C Main
1st 1p
2nd 2p
3rd 3p and so on
- Example:
Fees
Result
Point System
1st - 25 point
2nd - 20 point
3rd - 16 point
4th - 13 point
5th - 11 point
6th - 10 point
7th - 9 point
8th - 8 point
9th - 7 point
10th - 6 point
11th - 5 point
12th - 4 point
13th - 3 point
14th - 2 point
15th - 1 point
1 point
Note:
Organized by:
MINI Z DYNASTY
MINI Z ELEMENT
ONE MINI Z
Sponsor by:
ATOMIC
PN RACING
#67
Update PNWC 2014 Singapore 10th anniversary.
Please check it out below some photo during day practice, qualify & final race day.
https://www.facebook.com/minizsg
We appreciated MiniZ SG , PN Racing to organized high quality race event !!
And so much of fun , complementary gifts , lucky draw limited item from Pn Racing.
and the important thing we share , we learn , we race , and we Mini Z.
#68
Dear All Racer ,
Malaysia Mini-Z Cup is back in action, This round we will split 1st half and 2nd half of year 2015. At 1st half, we will start the race on open class.
This time, open class are open to all 1/27th chassis, all type of motor and all type of battery including lipo, life and other. Body shell also open to laxen body shell.
Let's rock and roll.
Malaysia Mini-Z Cup 2015 Open Class
Date:
Race 1 31-01-2015 Mini-Z Element Reschedule to 7th/Feb/2015
Race 2 07-03-2015 Mini Z Dynasty
Race 3 04-04-2015 Mini-Z Element
Race 4 09-05-2015 Mini Z Dynasty
Race 5 30-05-2015 Mini-Z Element
Fees
RM40 per class including track fees.
Organizers
Mini Z Dynasty
Mini-Z Element
Rules and Regulations. 2015v02012015
Race Format
Pre Qualifying
Each run will last 5 Minutes, Single BEST lap times will use for qualifying grouping.
Qualifying
Starting grid position to determine by the qualifying heats.
There will THREE (3) qualifying runs for each class.
Main will be justified by the qualifying heats.
A Main
2 best final results will recorded at point system.
B and C Main
Ranking system
1st Place – 1 Point
2nd Place – 2 Point
3rd Place – 3 Point ... and so on
Ranking determined by lowest point:
Example:
Driver A best 2 results are 1st and 3rd. 4 pts (1+3) awarded.
Driver B best 2 results are 2nd and 2nd. 4 pts (2+2) awarded.
Champion goes to driver A because Driver A hold the best result.
Point
Point Scoring System
The top fifteen (15) finishers in each race score points towards Malaysia Mini-Z Cup, according to the following scale:
1st - 25 point
2nd - 20 point
3rd - 16 point
4th - 13 point
5th - 11 point
6th - 10 point
7th - 9 point
8th - 8 point
9th - 7 point
10th - 6 point
11th - 5 points
12th - 4 point
13th - 3 point
14th - 2 point
15th - 1 point
Top qualifier (TQ) - 1 point
Result
There will be 5 races. Final ranking will be determined by the best 4 of 5 races result.
Car Specification
Chassis
Open to all 1/27th chassis including Kyosho Mini-Z MR01, MR015, MR02, MR03, MA010, MA015, MA020, Atomic AMZ, X Power MRX, MRCG and others
Body
Open to all 1/27th bodies
Pan Car and Lemans bodies are not allowed.
Lexan bodies are allowed
Lexan window, lexan roof and lexan wing are allowed
Motor
Brush and brushless are allowed. Any modification to the motor are allowed
Wheel Rims
All brand Plastic and Aluminum rims are allowed.
PCB Board
Open to all ESC and Board
Gyro are allowed
Battery
Open to all batteries, example Lipo, Lion, Nimh and others
Tyre
Any Brand: Rubber tyre only on RCP, silicone tyre only on Carpet.
Weight, width & height
Minimum weight 170g
Max wheel base (A) 98mm
Max car length (B) 180mm
Maximum Car Width (C) 80mm
Max car height with wings (D) 45mm
Lap counter system
Lap counter system will be enabled 1 hour before race for testing. Drivers are encouraged to test and make sure the transponder is place in the correct matter.
Missed lap is responsible by the racer. For advice on your appeal, please contact organizer immediately.
Race organizer holds the final decision on the final result.
Marshal
Drivers are responsible and compulsory to be a marshal when the other groups or mains are racing.
Note
Due to limited pit stop in Mini Z Dynasty and Mini Z Element. Participants are encouraged to well organize the pit stop area.
Any loss, broken or stolen item are not responsible by Mini Z Dynasty and Mini Z Element.
Organized by:
Mini Z Dynasty
Mini-Z Element
Date:
Fees
Organizers
Mini Z Dynasty
Mini-Z Element
Race Format
Pre Qualifying
Qualifying
A Main
B and C Main
Ranking system
1st Place – 1 Point
2nd Place – 2 Point
Example:
Point
1st - 25 point
2nd - 20 point
3rd - 16 point
4th - 13 point
5th - 11 point
6th - 10 point
7th - 9 point
8th - 8 point
9th - 7 point
10th - 6 point
11th - 5 points
12th - 4 point
13th - 3 point
14th - 2 point
15th - 1 point
Result
Car Specification
Chassis
Body
Motor
Wheel Rims
PCB Board
Gyro are allowed
Battery
Tyre
Minimum weight 170g
Lap counter system
Marshal
Note
Organized by:
Mini Z Dynasty
Mini-Z Element
#69
#70
Malaysia Mini-z CUP First Race have reschedule to next week Saturday 7th/Feb
time remain 8pm start.
Kyosho Mini-Z Restock.
MA020 Sports RTR for Drift! ( drift tyres included)
MA020VE Chassis Set (New awd brushless)
MR03VE Chassis Set (Limited Blue Edition)
KOPROPO EX-5 UR ASF
KOPROPO EX-5 UR ASF
#71
Brunei Open MiniZ Championship 2015
Date : 15-16-17 May 2015
Venue : Pusat Belia, Bandar Seri Begawan
Accommodation/hotel:
Pusat Belia - B$10/pax room sharing up to Four
Traders Hotel - usd40 tru agoda
Nearest hotel to venue:
Radison Hotel & Brunei Hotel
Stock class 70t 2wd class
- only Kyosho 2wd Chassis (MR01, MR015, MR02, MR03)
- only PN 70t stock brush motor
- only 4 x AAA size NiMh, NiCd, Alkaline batteries allowed
- Hard plastic body (Kyo-TRP)
Open Class
- Any 1/27th scale 2wd or 4wd chassis allowed
- 4 x NiMh/NiCd/Alkaline or 2cells LiPo 7.4V allowed
- Open motor (Brush or Brushless)
- Hard plastic body or Lexan (No Pan Car body)
AWD stock class
- Kyosho AWD, Atomic AMZ, X-Power IMT, Mini-Q
- Only PN5500Kv, Atomic 5000Kv, Orion 5600Kv, Xpower 5000Kv motors are allowed
-Any 4x AAA NiMh/NiCd/Alkaline or 2cells LiPo 7.4V
- Hard Plastic body (Kyo/TRP) or Lexan body allowed (NO Pan Car body)
Hope to see you all soon and best of luck!
Anyone interested pls contact us , and we will help racer to pre register & race fee need to pay upfront upon pre-register.
Name : No.class : Tshirt.Size:
Open Class
AWD stock class
