VXR Racing
#166
Originally Posted by VXR Racing III
ONLY RM199.00, this is what you get in the current promotion package.
1) Michael Ooi - 012-3682778 - RC Planet
2) Thompson Hong - 016-3091381 - RC Planet
3) Yong - 016-6722151 - Nam Lee Hobby
4) Baharudin - 012-3727722 - RC Planet
5) Emeel - 0192801000 - HPC
6) Ikmal - 0122022502 - HPC
7) Joshua - 012-9789889 - RC Planet
8) Badrul Alias - 013-3305099 - RC Planet
#167
#168
Promo Package Delivery
All,
8 reserved promo package will be send to the RC Planet, HPC and Name Lee today. Kindly collect them from the hobby shops by end of today.
Regards,
VXR Racing
Regards,
VXR Racing
#169
9) Steven Tye 019-3229668 - RC Planet
#170
Guest
VXR Racing released its Piston Power series and Nitro Accessories Series. They include high performance pipes for 1/10 on road, 1/8 off road, Savage and Revo pipes. Many accessories are also part of the release.
For more information, please refer to:
VXR Piston series
VXR Nitro Accessories
Part numbers include:
NPT-1205 X1 1/10 In-Line Tuned Pipe Set - 5mm
NPT-1206 X1 1/10 In-Line Tuned Pipe Set - 6mm
NPM-R250 Burst Tuned Pipe Set for REVO
NPB-R210 Fire R 1/8 Buggy In-Line Tuned Pipe Set (RPM)
NPB-T210 Fire T 1/8 Buggy In-Line Tuned Pipe Set (Torque)
NPM-S250 Rage Tuned Pipe Set for SAVAGE
NEG-1202 .12 Silicone Gasket - 2pcs
NEG-1502 .15 Silicone Gasket - 2pcs
NEG-2102 .21 Silicone Gasket - 2pcs
NEG-P1202 .12 Silicone Gasket (Picco) - 2pcs
NES-1202 .12 Manifold Spring - 2pcs
NES-2102 .21 Manifold Spring - 2pcs
NES-0003 Manifold-Pipe Spring - 3pcs
NEA-1000 Exhaust Stay
NFR-1202 On-Road Air Filter - 2pcs
NFB-2104 1/8 Buggy Air Filter Foam Element (4)
NFB-2105 1/8 Buggy Air Filter Set
NFT-0100T Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Transparent
NFT-0100FG Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Green
NFT-0100FY Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Yellow
NFT-0100FP Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Pink
NFT-0100FR Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Red
NFT-0100FO Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Orange
NFT-0100FB Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Blue
For more information, please visit VXR Web Site at www.VXRracing.com
#171
Originally Posted by tornado
Are ur pipes sanctioned by EFRA ?
Thanks for your interest in VXR Racing products.
As of now, no. It will be in the near future. We are working on that now.
VXR Racing
#172
10) Jeff FE - RC Planet
#173
12 down - 8 to go!
11) Rasik - 016-6722151 - Nam Lee Hobby
12) Rasik2 - 016-6722151 - Nam Lee Hobby
Guys, hurry up for the best deal for the regulator set. 8 to go!
#174
Promo Package Update
13) Ku Chi Siong - 016-2255113 - KC Hobby ENT
14) Patrick Yiu - 012-3831028 - Kindaland
15) Patrick Yiu2 - 012-3831028 - Kindaland
15 down, 5 more to go. Grap yours now!
#175
Location: 99% people download my avatar think she's cute
16) KukuChiawBesar - 0193772090 - KukuChiaw Hobbies
#177
New Product Release - Nitro Buster
VXR Racing is proud to anounce its new product:
CNB-0600 ”Nitro Buster” Spray Cleaner
Net Weight: 600ml
Physical can height: 31.5 cm
Total can weight: 550gm
Features:
1) Removes and clean nitro oil residue, grime, dirt and other contaminants
2) Index Trigger nozzle
3) Easy to use with powerful discharge
4) Plastic friendly
5) Zero residue
6) Will not harm your RC electronics
7) Environment friendly
Applications :
Drive train / transmission components, shocks, bearings, engine, radio tray, clutch, etc. Powerful Cleaner for Nitro-powered R/C Cars for maximum racing performance. Performance cleaning solutions for your winning Nitro R/C cars. Specially formulated to effectively remove and clean nitro oil residue, grime, dirt and other types of contaminants while leaving no residue.
Directions :
Hold can 10-16cm away from the surface to be cleaned. If precision and powerful jet is required, use the supplied extension tube by attaching onto the nozzle. For best results, clean the surface from the top and work down to the bottom in a sweeping motion until all the dirt is removed. NITROBUSTER and brushing may be required to remove stubborn dirt and grime.
#178
Li-po
16) Kuching - Hobby Mart
17) Kuching - Hobby Mart
18) Kuching - Hobby Mart
19) Kuching - Hobby Mart
20) Kuching - Hobby Mart
VXR Racing, All this last five promotion package is book by Hobby Mart (Sarawak, Kuching)
#179
With Hobbymart's committment to the promotion. We have concluded our promotion of the 5A regulator.
Congratulations to Andy Dass who TQ'ed and Won the Malaysian Hobao cup on 1-Jan-2006. Andy's buggy is powered with VXR Racing 5A regulator, VXR Li-Po pack and VXR Fire T buggy 1/8th pipe.
Happy new year to all!
#180
Got a problem with the following,
LRX-0240 - Receiver Packs - Li-Po, 240 mAh, 2S2P, 7.4V
LVR-1000-1A LDO Li-Po Racing Regulator (6.7V) for RX Li-Po
When I plug it all up the MRT MX Pro esc won't work. Set-up light flashes all the time. Have tried resetting esc to tranny but no joy. Not running a switch in receiver pack just plugged straight through the regulator. Remove receiver pack/regulator & all is OK with the ESC
Li-Po battery is fully charged, lights work OK on regulator, cells for car part charged to 3000mah
Spoke to MRT and they are unsure as to the problem
Have run esc with a switched ni-mh receiver pack & the esc is OK with that.
Also using Spektrum receiver
Anyone got any ideas?
update
charged Li-Po @ 8.26v
Reg out put is 6.79v
Tried a Spektrum SR3500 & SR3000
Servo is a Sanwa 141HR
update
