10.5T Turbo Timing Ratio at glenmarie??
may i know the suitable ratio for 10.5T Turbo timing at glenmarie track? These are my details about my car
1. XRAY T3 2011, Internal ratio 1.9
2. ESC - Hobbywing Xerun 120A v2.1
3. Motor - 10.5T Orca
4. TX & RX - M11x with 451R
5. Battery - maxpower pro series 6200mah 65C
team orion 6500mah 90C
Please help this newbie...huhu
technically ratio from 7.25 to 8.40 for 48p type spur sedap main utk 10.5t turbo. it may depends on your driving type (pick-up or top).
ko nak mkn meh aku tlg suapkan
I think you have a very tough question there. The Hobby Wing rep. will be able to answer you on the ESC setup when paired to the HW motor, while the ORCA rep. can only answer about the motor setting when it is paired to ORCA ESC.
Its not impossible to get a setting with your combo, but it will be harder to achieve the optimal setting as each ESC brand are set using their own in house motor and vise versa. To get the HW ESC to work on ORCA motor would take some trial and error. For me, I would +1.5notch on the motor when paired to ORCA Vritra MK2.1 ESC with a ratio ranging from 6.1-8.4, depending on the feel and character you like from the combination. The motor temp after a good pack of 6000mah battery, 8-10min run at night should be about 50+deg C.
Hope this helps. Happy RCing.
