KO Propo EX1 UR
KO Propo EX1 UR
Hi,Good news,problem solved!
Anyone who are using this KO propo EX1 UR 2.4 ghz (901 module) remote that facing a module light not light up during power on or need to shake at the module for the red light,please contact me or Mr. Sunny Wong at Sarawak.Just PM.
We rework and do a small modification at your remote so that it will light up once you on the power!Never had an red light not on issue.
Tested at Johor Maxima race,no issue.
P/s: Your module must be blue or pink color PCB.
James
James
James
James
James, I know how to resolve this issues by shaking your modules before the red light appears normal/ glitches.... Change to Sanwa M11X loh. Improves 0.100sec every lap on your M-chassis and solved your over-steer problems, rather that keep turn turtle...
901s module & KO ex-1UR radio
: fail binding with no red light during race.
: shake shake shake....... diu..... shake shake shake... ow... got light.
: u have to switch on the module once the light is on. else the red lite never on again after switch off.
: this one confirm really suck, Car not respond in second on race track.
the problems.
shaking ur radio, 10mins earlier to switch on the radio before ur turn. idiot~ lost respond in second on track.
after adjustment respond.
back to original sharp respond, 3min max waiting for the red light if other ten advance radios on the same time at the driver stand. no more far far away to switch on the radio.
Min problem of the 409s with EX-1UR.
the only problem: wait aprox 3mins to get the red light on the driver stand.
usually within 30sec.
PS: we are willing to help. don't send fail product.
due to this failure....
its a good tip n verry usefull to the ko-propo user.
and also u can open new thread for technical n tip for electronic
equipment.... so that we all can
share new finding n tip regarding this hobby
its good thing also we all know there are electronic genius among us...
so that we all can get knowledge by DIY
this just my suggestion
Hi bro james... why not teach us n share with us all what is ur finding
and I guess after this "rework", my KO warranty will be KOed right?
I have too much the 409S and 901S set for my KO radio. If they are finished, then get the new set radio. that should be within 2 years time.
We here is to settle the connecting point between the radio EX1-UR and 901S module only. After the mod, you will get the respond same as new out of box. No more shaking ur radio & module. I have those module send back from KO Japan, it says NO PROBLEM at all. so we solve the other way witch is nothing to do with the "inside". The warranty? same as the car finish break pad and tyre? change it, that's service. KO is the only radio i can get my KO radio set service in very very good deal.
Mod it, all the same, nothing different when back to ur hand. just don't send fail product(broken wire, broken radio case, fail electronic etc). The best solution is to get the latest "green" module and receiver.
If any knows about JR propo 9ch 9XII & 11ch X-zero from module generation start from PCM-DSM-DSMJ. The solution is there.
