Go Back   R/C Tech Forums > International Forums > Malaysian R/C Racers
Old 04-01-2011, 10:26 PM   #1
Elwyn Lee's Avatar
Default ORCA BL Championship 2011 (1st Round)
Dear racers,
We are pleased to announce the 1st round of ORCA BL Championship 2011
Date: 17th April 2011 (Sunday)
Venue: Planet Speedway
Class: 1/10th Touring Car
Entry Fees:
RM40.00 for Open Class (Turbo-Timing)
RM50.00 for Stock Class (Zero-Timing)
R & R
Open Class
1. Open motor, any brand of brushless 17.5T motor is allowed
2. In order to be eligible to race in open class, racers are required to use at least one of the following items from ORCA, preferbly all : -
a) ORCA electronics speed controller
b) ORCA batteries
c) ORCA motor
3. Total Minimum Weight allowed – 1420g (Including transponder or personal transponder)
4. Any brand of tires are allowed. Must be rubber based. Both Slick and Grooved allowed.
- Only 1 set of tires allowed throughout the whole race, except for A Main finalist which entitled to use 1 more set
5. Any brand of battery type & capacity is permitted
- Limited to only 6 cells Ni-Cd/Ni-MH or 2 cell Lipo
6. Any Brand of Brushless ESC are permitted, however NO REVERSE function is allowed during RACE
Stock Class (Zero-timing Class)
1. Handout ORCA RX-2 17.5T Motor
- Will be handed out on the race day and to be returned to the organiser after the race on the same day. Failure to do so will incur penalty charges.
- Motor cannot be disassembled or tampered in any manner
2. Total Minimum Weight allowed – 1420g (Including transponder or personal transponder)
3. Any brand of tires are allowed. Must be rubber based. Both Slick and Grooved allowed.
4. Any brand of battery type & capacity is permitted
5. Any Brand of Brushless ESC are permitted, provided it has the ROAR initiated Blinking Zero Timing Indicator . (Pls refer to the bottom for the list of approved ESCs)
- However NO REVERSE function is allowed during RACE
6. Body Shell: any types of 1/10th Touring Body (190mm) are allowed.
7. Wheels and Tires: Open to all types of Wheels and Rubber Tires.
8. The race will be run in normal touring class race format.
9. For racers do not have any esc which can clearly indicate "Zero-Timing", we can provide loan unit of ORCA 6X esc, please inform us earlier as the quantity is limited.
Qualifying : 3 Heats
Finals :
- A Main: 3 rounds
- B Main: 2 rounds
- C Main: 1 round
APPROVED ESC LIST FOR ZERO TIMING INDICATOR:
BRAND * MODEL * SOFTWARE VERSION
1) CASTLE CREATIONS MAMBA MAX PRO 1.26 Must be indicated by Zero Timing indicator
2) KO PROPO VFS-1 BMC 1.5 Must be indicated by Zero Timing indicator
3) LOSI 1/10th Xcelorin Brushless ESC Must be indicated by Zero Timing indicator
4) LRP SXX STOCK SPEC Must be indicated by Zero Timing indicator
5) SPEED PASSION GT-LPF 2.0 ESC 508 Must be indicated by Zero Timing indicator
6) SPEED PASSION GT-PRO 2.0 ESC 508 Must be indicated by Zero Timing indicator
7) NOVAK GTB Spektrum
8) NOVAK GTB
9) TEKIN RS Version 212 Must be indicated by Zero Timing indicator
10) TEKIN RS PRO Version 212 Must be indicated by Zero Timing indicator
11) ORCA VRITRA TC PRO SPEC Must be indicated by Zero Timing indicator
12) ORCA VRITRA VC4 PRO Must be indicated by Zero Timing indicator
13) ORCA Q 4X
14) ORCA Q 6X
15) Hobbywing XERUN Extreme Stock
16) Hobbywing XERUN 120A
*Zero Timing Indicator is a blinking light that will blink when the ESC is set to have 0 Deg Timing and Turbo Function Turned off.
For ESCs which are not listed above, please contact Hobby Haven to get more information.
Thanks in advance for your kind support.
Hobby Haven Sdn Bhd
Contact: +603-5631 6155 Fax:+603-5621 3962
Email: info@hobbyhaven.com.my, support@hobbyhaven.com.my
http://www.hobyhaven.com.my - http://www.hobby-haven.blogspot.com - http://www.teamyokomo.blogspot.com
Elwyn Lee is offline   Reply With Quote
Old 04-01-2011, 11:28 PM   #2
ahpeq_ong's Avatar
waa.... tekin Version 208...? version 212 cannot ar..? still got blinking light...
http://maxepteam.wordpress.com/
ahpeq_ong is offline   Reply With Quote
Old 04-02-2011, 02:56 AM   #3
cannon's Avatar
Trader Rating: 26 (100%+)
Elwyn
To help you out you have listed the wrong software version for the Tekin ESC. It is version 212 not 208. 208 doesn't conform to the zero timing rules of ROAR. Check the ROAR approved software list. It was set as version 212 back in October 2010
Hope this helps
www.feralbatteries.com ........... new website
www.gensaceaustralia.com ....... the website for high quality Gensace lipos
cannon is offline   Reply With Quote
Old 04-02-2011, 05:57 AM   #4
tommi's Avatar
Any restrictions on version of ESC firmware for Hobbywing users in zero timing class? If so, how do the organizers check them?
tommi is offline   Reply With Quote
Old 04-02-2011, 06:31 AM   #5
1/10 ZERO TIMING CLASS
Name/Car/ESC/Freq/PT No/Team
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1/10 OPEN CLASS (Turbo Timing)
Name/Car/Freq/PT/Team or State
1. Michael Lo / Mi4CX / 2.4 / PT****** / Team ORCA
2. Max Teo / Mi4CX / 2.4 / PT****** / KL
3. Lim EuKeong / Mi4CX / 40MHZ / PT****** / KL
4. Leonard Pong / Mi4CX / 2.4 / PT****** / KL
5. Leonard Ong / Mi4LP / 2.4 / PT****** / KL
6. Simon Yew / T3'10 / 2.4 / PT****** / KL
7. Jackie Siow / T3'11 / 2.4 / PT****** / Team ORCA
8. Siow WoonFong / Sakura '0' / 2.4 / PT****** / Team ORCA
9. Azri Amri / Yok BD5WX / 2.4 / PT****** / Team ORCA
10.
mikecan8 is offline   Reply With Quote
Old 04-02-2011, 08:21 AM   #6
mike_lim12's Avatar
1.mike_lim / Sakura Zero / 2,4 /????pt
2.
3.
4.
5.
6.
7.
8.
9.
10.
10.
TEAM MAX EP
SURIKARN 6500 70C.
SAKURA X1,XRAY T3 11
HOBBYWING zerun 2.1 120A,ORCA MK2
DUALSKY 10.5T,5.5T,ORCA 17.5T,YOKOMO SS 48T
mike_lim12 is offline   Reply With Quote
Old 04-02-2011, 08:36 AM   #7
Hello tommi,
If I can remember correctly I think HW's zero timing software should be 508? I will double check on it. Further to this the organizer will be doing random checks to see what the software version is. We have all the softwares for all the brands of ESCs, including Tekin, HW, SP and etc.
Hope the above helps. We would always uphold fairness in a race and we would do our best to curb anyone from doing anything that would not be fair to the others.
Happy RCing.
Old 04-02-2011, 08:45 AM   #8
2.
3.
4.
5.
6.
7.
8.
9.
10.
10. Shem / Top Photon / 2.4 / PT****** / KL
Old 04-02-2011, 12:33 PM   #9
ahpeq_ong's Avatar
2.ahpeq_ong / Sakura Zero / 2.4 / ????pt
3.
4.
5.
6.
7.
8.
9.
10.
Old 04-02-2011, 08:56 PM   #10
flyradio's Avatar
1.mike_lim / Sakura Zero / 2.4 /????pt
3.flyradio / 416x / 2.4 / ????pt / KL
4.
5.
6.
7.
8.
9.
10.
I'm racing for Max EP team
I'm driving for Team Associated TC 6.1 | Tamiya M05 pro | Tamiya DB01R
Saya suka makan mee kung fu
flyradio is offline   Reply With Quote
Old 04-03-2011, 05:31 PM   #11
shahrin's Avatar
Aisey.....the date of this race clashes with the Segamat race lar.
Didn't you guys planned it for 24th earlier?
shahrin is offline   Reply With Quote
Old 04-03-2011, 05:34 PM   #12
Default hai
4.
5.
6.
7.
8.
9.
10.
11.rizal/416x/2.4/kl
oyang786 is offline   Reply With Quote
Old 04-03-2011, 08:07 PM   #13
Send a message via AIM to mohdazmiyusop
Hi all,
LRP SPX Brushless Super Reverse (80400) without blinking LED esc can be use for ORCA BL 17.5t zero timing category?
Thank you for confirmation.
Regards.
RC TOURING/BUGGY/DRIFT....SEMUA MAU!
mohdazmiyusop is offline   Reply With Quote
Old 04-03-2011, 09:58 PM   #14
miepeaty grt's Avatar
Post
4.jon/bd5wr/2.4/no pt/eplk
5.nasrul/416x/no pt/epkl
6.jamal/416x/no pt/epkl
7.
8.
9.
10.
12.adam/t3'11/2.4/epkl
13.miepeaty/t3'11/epkl
sponser by poket sendiri...maybank,cimb,hongleong bank
miepeaty grt is offline   Reply With Quote
Old 04-03-2011, 10:04 PM   #15
7. Masirin / X Ray T3 2011/ 9227535 / Sel
8.
9.
10.
Masirin is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 22663 Today 06:23 AM
ORCA BL Championship Round 2 @ SS19 Planet Speedway on 8th August 2010 jychow Malaysian R/C Racers 94 08-08-2010 10:34 AM
SEO by vBSEO 3.5.0
