Malaysia Large Scales Hobby (News and updated)
Discussion anything, tips , trick , Help regarding 1/5 and above are here
product and news all will updated here
i will make some simple briefing. who just going to start on large scales hobby.
Choosing the your right Large Scale
Precaution
Troubleshooting
Engine can't start
Engine running troubleshooting
Engine die when full brake apply
============UPDATED=SOON==================
- No doubt of cause a need Big Daddy Car !!
- Part available is the most important !!
- Built Quality Also yours main concern !! Make Sure it is durable enough to take beating !!
- The best is choose ur car with Good o' Brand carburetor it could save u alot of headache tuning (Walbro is recommended "make in japan" )
- Customer Service are very important also
- So 5th scales car normally are expensive than smaller scales. but in long run it will save u alot of money.. take ur times choosing what suit you. walking hobbyshop check alot of review around the internet before you throw urs $$$ in to it
Precaution
- Make sure you have all urs battery charges before going to run the beast !! it will break even medium rock if accident (not to mentions if hit people)
- Drive it responsible it is really dangerous !! play in wide open area.
- 3rd channel picokillswitch were recommended . in case run away you can still switch of the plug using your radio
- Do not smoking when refuel or starting ur baja.. it will cause serious damages even fatalities due explosion because it got gas.
- Do not let kids plays this is seriously not a toys.
Troubleshooting
Engine can't start
- carburetor out of fuel : Prime the Carburetor
- Carburetor Failure : change new carb or service it
- No spark : check the spark plug by remove it and touch the exhaust make sure got spark
- ignition Failure : if you feel (shocked) when holding the Rubber there when pullstart check the cable or change new ignition system
- Engine flooding : De-flood by plug and turn outside down pull few times let the engine outside down for 1days .
- Piston ring failure : this normally happen few years later. Just change the piston Ring
- Screw in (lean it abit) the L speed needle/Or the idle level screw that located lower part at the caburator (biggest screw)
RCM BAJA Ver2
NOW RCM BAJA Ver2 Available in the market !
RCM BAJA VER 2 ARRIVAL !!
SPEC
1. 30.5CC engine
2. 33KG metal gear steering servo
3. 13KG metal throttle servo
4. alloy gear differential cover
5. Heavy Duty Rim , beadlock and tyre
6. 2.4GHz transmitter with LCD screen
7. 6V3000 RX batt
8. Monster Tune Pipe
9. Alloy Roll cage , alloy lower rails
10. High flow air filter
11. alloy front bulk head
12. HD CVD drive shaft
13. Enclosed alloy clutch
14. alloy rear hub carrier set
15. new throttle linkage set
16. upgrade clutch bell
17. Front rear sway bar set
18. 6MM VCC HD SHOCK
19. Walbro carburetor (original from japan)
20. 8000 RPM Clutch SET
21. All tools given FOC for who every started into large scales hobby
and the price is very reasonable
FROM the picture very ONG liaw.. hahaha
feel free to call / sms 016 860 7710 for future information
SPEC
1. 30.5CC engine
7. 6V3000 RX batt
perhaps this will help you.
Original post
http://www.rctech.net/forum/malaysia...ml#post8004673
Good to know we have Large scale Malaysia Service center in Malaysia.
We have produced all 1:5 rc bajas completely according to RCM's special requirement and also we do concern on customer's needs for Malaysia market, the RCM's R&D team has already join in our factory R&D department to design and develop rc hobby products together, that make our customer satisfaction guaranty. Together we are improving our baja's to ultimate machine, and bullet proofs our product.
RCMOD also act as our service center in Malaysia too.
If you have any plan to purchase 1:5 rc bajas or have any problem need Professional techinical support, please feel free to contact Fei by:
Tel: 016 860 7710
MSN: [email][email protected]
Yahoo Messenger: [email][email protected]
Feel free to have a free test drive at RCMOD, they are always ready for you.
Tel: 016 860 7710
SPEC
1. 30.5CC engine
7. 6V3000 RX batt
feel free to call / sms 016 860 7710 begin_of_the_skype_highlighting**************016 860 7710******end_of_the_skype_highlighting begin_of_the_skype_highlighting**************016 860 7710******end_of_the_skype_highlighting for future information
SPEC
1. 30.5CC engine
7. 6V3000 RX batt
The enclosed clutch cover not yet arrive ah bro?
talking about 1/5 scale. do we have a set of tools like we have for the 1/10. that is Hudy all in one solution too. which includes.
1. steering
2. tweak
3. chamber
4. toe
yes teekuang the enclose clutch cover arrival i week ago.. sory i forgot to update we have silver colour and orange i will updated the picture once i arrival my kedai ~
mting2003 : welcome to big daddy club
Toh WL : sonner or later and yes it will come
Fox : haha.. thanks bro so... have u decide which baja you want to go ?
New arrival
billet Clutch Bell enclose holder
(note: standard part come with RCM BAJA Ver2 only)
( available purchase separately )
Is a MUST UPGRADE FOR ALL BAJA
For reduce the sand and dust goes in to your clutch bell.. also beef up ur clutch cover.. also add bling on ur BAJA
sooner or later ($_$) also come... ah fei will b the pioneer for 1/5 scale in m'sia. those who play cucuk2 with u... then u buy over their shops...
another thing, dun forget the "skid plate". this is to minimize chassis wear. same like de 1/8 buggy.
