Hobbizone 1:10 TC Gas Race, Titiwangsa KL. 5th June 2004
#46
Originally posted by goodspeed
Ok guy, relax, I went to hobbizone and saw the sample shell, this is the HOLES that I saw:
1. 50mm max hole on front window.
2. 70mm max hole on rear window.
3. both front side window only
4. 15mm max hole for glow starter and
5. one for antenna and
thats it
thats it
#47
Halloo.....geng.....which rules need to follow....i was read the IFMAR rules....for front hole is 60mm maximum....if you all not follow the rules...so why we need....rules for this race.........
ayoo..manyak susah....cam ...ni......fix the correct rules... so everybody will accept it........
If you want make your own rules....please make sure is clear for everbody.....ok...chau...
#48
Originally posted by crashed_1
I rest my case...
I rest my case...
it's because some idiots blabbered "oh like ifmar rules lehdet loh" then the words started spreading lah.. this lah that lah... and started people comparing it with IFMAR and shites... sigh...
wong already cleared it out, simple, numbered. and they are not IFMAR... no point comparing it with IFMAR.. if u don't like the rules, tell the organisers... if u think u can take on the challenge... race on!
#49
Originally posted by AJunkie_02
lehdet also can argue for so long... it's basically rules set by organisers, which incidentally copied and modified from ifmar...easy mah, no need to rewrite mah..
#50
Originally posted by spawn
harlow!! if you care to read the rules in the race form for this race, you will notice that the rules there and the information given by the organiser is different.
#52
And we also argue the rational for being different from IFMAR. Cold climate countries have 60 mm mail cooling hole and no restriction of hole size in the rear of the window. Why do we do silly things such as limiting the hole size to 50 mm while the rear to 70 mm?
I agree that rules are meant to be followed and it is up to us to follow if we want. But of course there must be some rational to it before blindly following the rules. My 2 sen and O P I N I O N.
p/s: Please ignore the above if you disagree with me. Good luck in the race.
#53
here as though like warfare... more like warcraft already... soot here soot there.. no purpose..
#54
I agree with you AJunkie_02...
don't make people...susah..lah ..to cut the body shell..i have to wait...first...let them clear....the information ...who.s know..they can change....rules.....ma.......need to buy...a bodyshell again....he...he..e..
#55
i for one understood the rules in the pdf form...it was very clearly stated.(10mm larger in the front compared to IFMAR, which is good for us, but then it turned out to be the back instead. WTF!!!!) But things got a little fuzzy when Wong asked the organizer and they mentioned something else...which was totally different from the pdf file...
We will abide by the rules, but WHICH ONE???!!!!...the one in the pdf or the one stated here by the organizer thru Wong?....
#56
#57
Do like what spawn suggest loh... Cut at the track. Don't worry. I'll help you cut even though I'm not good at it or hate cutting it !
#58
That's precisely my point, i got a shell already cut according to IFMAR and Hobbyzone's Rules in the pdf form...do i need to buy another shell AGAIN just in case they decide to change again?...
Tell you what... I'll get you another Mazda 6 shell and I'll paint it for you in exchange for your IFMAR shell. Of course plain colour lah... How's that?
#59
Easy what... Do I need to repeat that I AM A FREELOADER?
