TAMIYA MALAYSIA - Support & Discussion Centre
#376
Arrived!
TA05 VDF!!
Castrol Honda CIVIC VTi - FF03
TA05 VDF!!
#377
#379
Arriving Next Week!!!
TA05-VDF - TA05VDF
The Ultimate Counter Steering Drift Machine!!
This machine adopts a front mid-ship motor layout (motor within wheelbase) for optimum balance which is essential to drift driving. The upper frame features vertically mounted carbon plates which improve chassis rigidity while also providing enough flexibility during drifting. The parallel geometry steering system provides this machine with excellent control of counter steering.The especially designed battery holder is adjustable and is compatible with Ni-Cd, Ni-MH, LIPO & LF batteries. Glass tape can also be used to secure the battery.
Features TA05 bulkheads, short reversible suspension arms, TRF416 uprights. 37Tfront and rear pulleys and 18T center pulley are driven by new-length drive belts. Belt tensioner is also equipped.
Adjustable battery holder enables attachment of Tamiya Ni-Cd, Ni-MH, LIPO and LF battery packs (battery packs can also be secured with glass tape). R/C units are placed centrally on the chassis for optimized balance.
A wide variety of TA-05 option parts can be equipped on this drift chassis
Specs & Features
1/10 R/C assembly model kit.
Front: Ball Diff., Rear: Spool Diff.
Carbon chassis 2mm thick.
Front and rear universal shafts.
Aluminum hex hubs.
TRF Dampers (Case: Fluorine Coated, Shaft coating: Normal)
Short reversible suspension arms.
Uprights feature 1050 ball bearing specifications.
TA05 Front and rear bulkheads.
Body, tires, wheels, motor, ESC, 2ch transmitter, not included.
You will be surprised with the pricing!!!
TA05-VDF - TA05VDF
Specs & Features
Aluminum hex hubs.
#380
vipboys,
Body is currently out of stock
#381
Akudou,
It does come with a 37T pulley.
#382
Arriving this week....
M05 Stabilizer Set
Two front stabilizer rods (Soft and Hard)included.
Two rear stabilizer rods (Soft and Hard)included.
Can be used with M-05 and M-05Ra chassis
TRF 416 Lipo convertion kit
- as used at the Worlds
Specs & Features
New conversion set enables you to set up your TRF416X to use mainstream high-output batteries.
2.25mm lower and 2.0mm carbon fiber upper decks ensure high chassis durability.
Set includes:
2.25mm carbon fiber lower deck x1
2.0mm carbon fiber upper deck x1
Aluminum spacer x2
3mm aluminum lock nut x2
Battery mount (3 types)
Aluminum battery post x2
Aluminum servo mount x1
M05 Stabilizer Set
Specs & Features
Set includes:
Aluminum spacer x2
#383
did u notice, the pic are missing?
#384
toh,
eh...I can see the pix
#386
OCY,
Do you have toe block 1C or C in stock ? Been to yr shop a couple of times but didn't managed to get it. How much ?
Tks.
PS. Toe Block for TA05.
Tks.
#387
#389
