Sorry,
Atomic AD Stock
Atomic Stock R
Atomic T2
Atomic Z2
Atomic Chilli
PN AWD II
PN AWD III
PN AD Stock
PN Animal
PN Xeric
PN 33T
PN35T.... all over 34000rpm to 48000rpm
motor allowed are around 28000rpm to 31000rpm
Jeff Cheong
MINI Z DYNASTY
AO-03A, Block A,
Glenview Business Centre,
Taman Pinggiran Cheras,
Jalan Kuari, 56100 Kuala Lumpur.
Motor control race.
Below are the motor allow
Kyosho X Speed, X Speed AWD, X Speed 2.4, X Speed 2.4 AWD
PN Speedy 05, Speedy 07BB, Speedy 07 II BB. Speedy 07
Atomic Standard, Stock, Stock AWD
Can't remember the motor that I bought. Sticker cabut. Atomic Stock or Atomic Stock AWD rite? Can use.....
If you do not wanna use it, let others enjoy it at a much lower price. In other words sell it....
1. only supports 2.4Ghz PCB as the chassis is design only for it.
Maybe include the traction control unit in Dnano
2. Front A-Arm suspension system not like all other mini-z (similler like PN front A Arm system)
Interchangeble with MR015 and MR02 front off set.
3. Chassis is narrower as theres no need to allocate space for crystal, means the PCB is somewhere above the batteries.
Can put in both MR015 narrow body and MR02 wide body.
4. Front part of chassis is way lower than MR-02 so this will allow new type of bodyshell..but not so sure what to call it (jeff tolong jawab)
Yes, like new type of lemans body shell.
5. If not mistaken all MR-02/MR015 rear parts compitable with MR-03
Hopefully......
6. still uses the same mini-z VR and the small motor to power the steering...
But the servo motor is coreless.
Info from other forums........
Jeff Cheong
MINI Z DYNASTY
AO-03A, Block A,
