Schumacher EP
Schumacher EP
Schumacher SST Mission with qd-race.com
Features:
- New twin track, ballraced, limited slip ball differentials.
- Now with tungsten carbide balls as standard - Long life super smooth action, with low rotating mass for fast acceleration.
- New variable internal ratio (1.8:1 or 2.1:1) This unique feature allows your gear ratio to be optimized to your motor wind, for both short technical and fast open circuits.
- New rear inboard toe-in options for excellent traction on slippery surfaces.
- Side saddle chassis takes stick and saddle pack cells - your choice.
- New front inboard toe-out options for more front end bite on slippery surfaces.
- New dual belt zero angled transmission - Ultimate efficiency
- New large differential and layshaft pulleys to minimize belt loading without the belt jumping, maximizes belt efficiency.
- Purple alloy motor mount as standard.
- 24 Piece ball bearing set - Ultra low rolling resistance, includes ballraced steering.
- Front and rear anti-roll (sway) bars included.
- New body mounting system - Offers greater body stability.
- Low friction belt tensioner - Accurate belt adjustment.
- Lightweight foam bumper - Weight saving protection.
- Variable wheelbase - Ultimate tuning.
- Purple alloy shock bodies.
- Lightweight alloy differential outputs and 'blade' driveshafts.
- New 'UltraFlex' belts - Latest technology.
- Full 'Speed Secrets' available.
Any enquiry: [email protected] or visit
http://www.qd-race.com
Features:
Rosdi,
Let me know how many your customers will join the Xenon Race on 11st Jan 2004 ASAP.
Originally posted by GNC
Rosdi,
Rosdi,
Schumacher Mi2
Schumacher Mi2 coming soon on Jan' 2004:
K046 Mi2 S1 - RM 950.00 (estimate)
K047 Mi2 Carbon - RM 1250.00 (estimate)
All new 'C' hub suspension system - Improved handling and adjustability to suit any track conditions.
Balanced weight distribution chassis with fully adjustable battery position tray - Total tuneability.
MIP CVD axles with lightweight polymer driveshafts - Ultra low rotating mass.
'Air-Flo' purple alloy motor mount as standard - Ultimate motor cooling.
Purple alloy layshaft mounts and diff mounts as standard offers consistent handling & precise transmission alignment.
Improved limited slip ball differentials, with tungsten carbide balls as standard - Long life & a super smooth action.
Twin Kevlar reinforced belt transmission with lower, adjustable tension high efficiency belts and power rollers to prevent belt skipping.
28 Piece ball bearing set - Ultra low rolling resistance, includes ballraced steering.
Low C of G fully adjustable body mounting system.
Choice of internal ratio (1.8:1 or 2.1:1) This unique feature allows your gear ratio to be optimised to your motor wind, for both technical and fast open circuits.
Purple alloy threaded shocks absorbers - Simple tuning of ride height.
Lightweight alloy differential outputs and 'blade' driveshafts, low rotating mass for fast acceleration.
New improved differential and layshaft pulleys to minimize belt loading without the belt jumping, maximizes belt efficiency.
New front and rear, coloured anti-roll (sway) bars included.
Lightweight 'Rev-Lite' 24mm dish wheels.
Full range of 'Speed Secrets' available.
Kit Requires - Radio, motor, battery, speed control, body, and tyres.
If you need further information, please email or contact with us.
Hihi.
Any of the Schumacher making appearance at Johor Bahru race this Saturday?
Would love to see it in action too...
Originally posted by ruD
Hihi.
Hihi.
Hihi.
Hihi.
Wow..seems like the active racing season is back again!
Let the fun begin!
GNC, would love to try it out. Keep u inform if I can make it to KL on JAN2004.
Let the fun begin!
