Go Back   R/C Tech Forums > International Forums > Malaysian R/C Racers
Old 04-05-2011, 07:34 AM   #991
Originally Posted by guinnes.s View Post
Hello wondering if you can help.
my friend Vritra pro does not work unless the sensor cable is unplugged.
changed motor and sensor cable but no luck. Any ideas? Thanx
Hello guinnes.s,
I think the sensor board is not working. The only solution is to have it sent back to Hobby Haven and get a new one, at a cost, ofcourse. But you would be able to get a MK2 and pls remember to bring along your program card as the MK2 will only work with the MK2 program card.
Happy RCing.
mikecan8 is offline   Reply With Quote
Old 04-06-2011, 08:47 PM   #992
Hy guys, I just bought Orca MK2 esc. Anyone have a good setup for this esc? Im running TRF416X and LRP X12 10.5T motor with oo(0) insert. Our local track has 45-50meters longstraight and has technical infield. Pls give me some advised with this esc.
mizah is offline   Reply With Quote
Old 04-06-2011, 10:17 PM   #993
Hello mizah,
The LRP X12 motor is a very fast motor, but its also one of the hotter ones out there. I would suggest you do a few check before using it with the MK2 ESC. It has been noticed by a few users that the sensor on the X12 may not be working prematurely and it may cause the current to back fire and fry the ESC. Hence we would advice that you do the following test to ensure that the motor's sensor is working properly.
You have to first turn all timing and turbo timing to '0' and run the motor on the bench, in the car ofcourse, and see if the motor is running smoothly and then slowly add timing to it to make sure that the motor will run with jitters/stutters and then you can add the normal timing on it. If you can try the same thing after you get some temperature into motor to see if it has the stutter.
The setting for a track of about 40-50m is quite big and with a technical infield would be a tough one to set. None the less, I will try my best and most importantly try to take the motor's temp every 2-3min to ensure that the setting is not too hot for the motor.
Timing 30Deg
Turbo Delay 0
Turbo Timing 50-52Deg
Turbo Interval 5/6
PWM 32/64K
Punch 8
Let me know if you have any problems. Hope the setting helps.
Happy RCing.
Old 04-15-2011, 08:41 PM   #994
StartingGrid's Avatar
mike..PM me price for 2packs of orca 60c 5500mah..
StartingGrid is offline   Reply With Quote
Old 04-18-2011, 12:45 AM   #995
JimmyMac's Avatar
Do the Orca 5500 60c 7.4v packs have humps on the bottom or are they flat?
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 04-18-2011, 04:37 AM   #996
Hello JimmyMac,
Nope, the ORCA Infinite 5500 60C does not have humps at the bottom. They are flat bottom.
Happy RCing.
Old 04-18-2011, 07:49 PM   #997
JimmyMac's Avatar
Thanks, just what I wanted to hear. I'm getting back into racing again, so I'm gonna buy this pack. I guess I'll run Orca packs, 17.5 motor, and ESC... Muh hahahaha
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
Old 04-19-2011, 12:40 AM   #998
Hello JimmyMac,
Thanks for your support and I am quite sure you would find the INFINITE 5500 60Cs to be the best bang for the buck batteries around.
Happy RCing.
Old 04-19-2011, 09:07 AM   #999
Originally Posted by mikecan8 View Post
Hello JimmyMac,
Happy RCing.
deal of the year right? pm me the price pls or sms 0122161411
Kimikewl is offline   Reply With Quote
Old 04-19-2011, 09:50 AM   #1000
aqeel200's Avatar
hi mike, PM me for your best price of
a) 2 x ORCA infinite 5500mah 60C
b) 4 x ORCA infinite 5500mAH 60C
c) 6 x ORCA infinite 5500mAH 60C
This is for personal use. Thinking of changing brand. If price is good, i might go for c.
thanks.
1 LST2/Z.30R S3/DX3S-fully modded, 2 LST2/ZR.30 S2/DX3S-full mod
3 E-LST2/MMonster+Neu 1515 2200kv/DX3S-full mod, 4. HPI Savage Flux/MMM+2200kv/DX3S - BP HD full mod 5.SWORKZ EVO S350 upgraded M12 6. SWORKZ EVO S350 upgraded MT4 7.Agama Evo R4,RB engine,DX4S - full option. 8. Sworkz S350T Truggy upgraded MT4.
aqeel200 is offline   Reply With Quote
Old 04-19-2011, 11:25 AM   #1001
thanks.
Hello aqeel200,
I think the price of 2X Infinite 5500 60C is already at its best. Therefore 4 X Infinite 5500 60C is 2 X the price of 2X Infinite 5500 60C and 6 X Infinite 5500 60C is 3X the price of 2 X of Infinite 5500 60C.
I think if you have been shopping around, it is the best bang for the buck in terms of performance and pricing. Therefore I do not think there is anymore better price than BEST price.
Thanks for your inquiry.
Happy RCing.
p.s. For availability, please contact Hobby Haven.
Old 04-19-2011, 12:55 PM   #1002
Trader Rating: 32 (100%+)
Hello aqeel200,
Happy RCing.
Hmmm,... maybe if you order a 40' long container of Infinite 5500 60C, then only can get lower price
On serious note,... yup, in term of pricing & performance, the pricing of 2x Infinite 5500 60C is the best in the market, at least at this moment.
Sorry to 'kay-poh', I am commenting only as a happy customer.
hobbs is offline   Reply With Quote
Old 04-19-2011, 09:58 PM   #1003
aqeel200's Avatar
Hello aqeel200,
Happy RCing.
what is rhe price of 2 unit as 'its already at its best price'. i hv no idea?
some LHS when contated at diff times will gv diff prices for the same product. I see this happening alot. sadly, even an OKU (visible) who wanted to go into RC hobby is not spared and taken advantage of (maximum) - sorry, this was made known to me by the OKU friend. I introduce RC to him.
if u can PM me what would be the 'best selling price' as claimed, i would appreciate it as it would be a good guidance/indicator. there has to be a good balance of making profits with returning customers as opposed to what my OKU friend encountered - paying rm850 for something that is sold around rm400-rm450.
appreciate the guidance
Old 04-20-2011, 12:08 AM   #1004
aqeel200's Avatar
called hobby heaven.
customer service and explanation is very good. price and justification is good. warranty coverage explanation is acceptable. too bad the lhs that con my OKU friend isn't like that. I have booked 6 units of ORCA battery. will pick it up this evening or tomorrow.
apologize to all readers for being so cautious and little reserve (due to some bad experience) as i see this hobby encourage good friendship and family involvement(for me as opposed to golf or any other solo or unhealthy hobbies that does not involve family). even my 6 year old has been fun racing 1/8MTs/SC with the big boys at our regular weekly spot. again I apologize for the cautious perceptions. If all is good, I will definitely frequent hobby heaven for my family RC supply.
cheers
Old 04-20-2011, 12:01 PM   #1005
Hello hobbs,
Thank you for concurring with me and ORCA. As I mentioned, this is a very rare deal and I must say I am delighted that most users that I have been able to interact with are all very happy about the product, that to ORCA is the most important as ORCA has always pride itself with the quality of our products. The price, is a very big bonus and it is our way of saying a big thank you to all racers/users which has always stood by ORCA and ORCA did not disappoint and have proven that it can be up there with the rest.
Happy RCing.
Ko EX-1 UR C_Suzuki Radio and Electronics 219 04-06-2012 12:36 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
SEO by vBSEO 3.5.0
