Is EP in ?
#196
i think it's de normal version lorr.... not ssg....
Originally posted by horniez
BLACK carbon fibre???
new type of carbon fibre?
#197
tat was wat i was think also,...but dun wan 2 comment as i'm not 100% sure.wait give wrong info kana bullets all over...hahahah
#198
okie dokie...
*machine gun rattle* *bang* *bang* *bang* *bang* *bang* *bang* *bang* *bang* *bang* *bang* *bang*
hahahahaha....
btw, SSG stands for silver surface graphite, issit?
hahahahaha....
#199
something like tat...
#200
ask u ah... are the options for the SSG shock towers (front & rear) the same as compared to the normal carbon fibre???
& the size, the same as well???
#201
just use bomb larr... easier that way.. don waste time....
yup. .... ssg = silver surface graphite....
okie dokie...
hahahahaha....
okie dokie...
hahahahaha....
#202
Team Much More is from Korea:
Team Much More are releasing their brand new state-of-the-art charger in November. The Cell Master is the perfect battery management unit for Charging and discharging all Ni-MH & NiCD cells. The Cell Master has exclusive functions including all latest technology of current chargers.
Main Features
• DC 11-15V input
• 1-8cells, 0-10A charge, 0-10A discharge
• Cycle(1-3times), Latest data display
• Peak sensitivity 3mV/cell - 20mV/cell
• Auto start timer charge(countdown)
• Peak charge(5 memories), CTX charge(3steps charge, 3memories)
• Auto re-peak(0-5)
• Trickle(on/off)
• Flex charge(off~9steps)
• Temp. sensor included
• Temp. start(for cold batteries), Temp. cutoff
• Renaming for CTX charge
• 3 melody
• Temp. controlled cooling dual fans
• Neon blue backlit LCD
• Easy key operations
• Input and output protection against overloads, reverse polarity and short circuits,low or high input voltage, low battery temperature.
Source: Team Much More
Main Features
• DC 11-15V input
• Auto re-peak(0-5)
• Trickle(on/off)
• 3 melody
#204
hmmm... dun understand quite a few on the features...
#205
if i'm not wrong,i think the SSG shock towers r slightly different...
#206
tuning-options wise, which one have more? or both the same?
#207
Originally posted by InitialD
200 mm bodies look downright ugly on EP cars. That I can tell you for sure Whatever it is, stick to 190 mm please...
Lemans bodyshell on touring cars look super horribly ugly as well but you like...... so nevermind.......
#208
#209
if not mistaken, the ssg has one more pin hole for ur shocks...... and the degree might be slightly different....
enjoy....
enjoy....
#210
which idiot doing so???
