Go Back   R/C Tech Forums > International Forums > Malaysian R/C Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-17-2008, 06:51 PM   #1
oriongoh's Avatar
Send a message via Skype™ to oriongoh
Default Newbies for offroader 1/8
I started this thread cause don't see a thread here beginners can group up and go for bashing hehehehe i'm beginner now mah.Expert are also welcome here to give out advise hehehe need to learn more and more.
NITRO-X
OCM Kaos DT-19 EVO
RB WS 7 3
RB C6
DX3R
oriongoh is offline   Reply With Quote
Old 03-17-2008, 08:29 PM   #2
James khoo's Avatar
Ok,let';s start with shock;
1) Shock oil?
2) Shock piston?
3) Spring?
James khoo is offline   Reply With Quote
Old 03-17-2008, 08:54 PM   #3
devious17's Avatar
setting would depend largely on the track and even then the setting would need slight change throughout the day.However, the change is not as drastic as on-roads.
Also the consistency of the silicone fluid againts temperature.
To add to James's list
4) Tyre
5) Shock, caste, camber angle.
My last setting for HPC track
shock oil 60F / 50R
Diff 5kF / 10kC / 1kR - a little understeer and a little rally style driving to counter.
I dont start a fight but I will end one.
devious17 is offline   Reply With Quote
Old 03-17-2008, 08:55 PM   #4
oriongoh's Avatar
1) Shock oil?
2) Shock piston?
3) Spring?
Hmmmm shock huh currently i'm using 45 and 50 for the oil as for shock piston no idea and spring also no idea it's an ocm original hehehehehe.
NITRO-X
OCM Kaos DT-19 EVO
RB WS 7 3
RB C6
DX3R
Old 03-17-2008, 10:26 PM   #5
James khoo's Avatar
Even the shock piston got lot';s of setting
Example; 1.2mm two hole,1.3mm two hole,1.1mm 3 hole and...............
Just set your buggy till it didn't bottom up badly after landing of jump.
My setting,hold my car at around 2 feet of ground,then drop.change to ticker oil if it bottom up,but the best way is to test it on the track you play.
Cheers
Old 03-17-2008, 10:50 PM   #6
oriongoh's Avatar
Cheers
Didn't know about that yet but will tak notice when i service the shocker again i thought only need to change oil and only ot difference to the oil.Now i need to measure the piston to know what spec it is cause the jump my car currently performing is great.
Thanks for info.
NITRO-X
OCM Kaos DT-19 EVO
RB WS 7 3
RB C6
DX3R
Old 03-17-2008, 10:57 PM   #7
James khoo's Avatar
Hey oriongoh,
You got some killer stuff there!
OCM Kaos DT-19 EVO
AXE Rossi Mamba
RB WS 7 3
M11 Spektrum
Sanwa 13kg
He he he
Old 03-17-2008, 11:07 PM   #8
oriongoh's Avatar
Hey oriongoh,
OCM Kaos DT-19 EVO
AXE Rossi Mamba
RB WS 7 3
M11 Spektrum
Sanwa 13kg
He he he
The car was because i used to own a older version which did very great.
The engine was intro by The hobby shop owner and the rb engine was recomended by a fren saying that it's another step after mamba hehehehe.M11 was recomended by an R/c fren in titiwangsa as for the servo of course it's a set from my transmitter hehehehe.Thinking of getting a lighter transmitter though but $$$$$ not permitting so have to wait loh .
NITRO-X
OCM Kaos DT-19 EVO
RB WS 7 3
RB C6
DX3R
Old 03-17-2008, 11:17 PM   #9
James khoo's Avatar
Yes,The RB is a great engine!my ex RB engine never let me down(S7 sport,S7w version 1)now,i plan is to get this S7w3!
Btw,do check your engine conrod after 3 gallon of nitro.replace if there is any play at rod end.
I service my engine every gallon of play,clean with motor spray outer and inner.
Replace the air filter if dirty!
Old 03-17-2008, 11:18 PM   #10
Regional Moderator
Danny Teh's Avatar
Offroad doesn't have to invest..........that much ! It doesn't makes a big difference.
Essential parts: Tires ( you got to have a variety for wet, dry, sandy, etc )
Once you got the basics, already start racing or bashing.
Air filter foams are important, change them regularly. Try to get a outer filter would be ideal as it will filter away, 60% of dirt, keeping the main filter clean.
Danny Teh is offline   Reply With Quote
Old 03-17-2008, 11:19 PM   #11
James khoo's Avatar
Danny,any tips?
Old 03-17-2008, 11:21 PM   #12
Regional Moderator
Danny Teh's Avatar
huh ! what tips ?
offroad quite standard one............no much to do one !
Old 03-17-2008, 11:24 PM   #13
James khoo's Avatar
Originally Posted by Danny Teh View Post
huh ! what tips ?
Example';
Tire for sandy,hard pack and so on.which brand and tread.
Old 03-17-2008, 11:26 PM   #14
LoBil's Avatar
Send a message via MSN to LoBil
Danny,any tips?
Haha..the tips are more practice on difference layout...
>< ZX1.5R ??? ... :P
>< ABC GENETIC..MINI with Toyota 70' Levin ;)
LoBil is offline   Reply With Quote
Old 03-17-2008, 11:35 PM   #15
oriongoh's Avatar
Hey oriongoh,
OCM Kaos DT-19 EVO
AXE Rossi Mamba
RB WS 7 3
M11 Spektrum
Sanwa 13kg
He he he
I do check them after every race just took the engine apart yesterday but will only check the parts today and put it back together.I had damage clutch and was lucky to have check it yesterday if not will have to replace the springs too.hehehe wonder when we can get a tranparent car hahaha no need open so many things already can see.
NITRO-X
OCM Kaos DT-19 EVO
RB WS 7 3
RB C6
DX3R
Forum Jump
WTT: AcerAspire5315 for RC offroader Eagleman75 Australia For Sale/Trade 4 08-24-2008 04:50 AM
yokomo tc into 4wd offroader TZona Electric Off-Road 6 11-21-2006 08:21 AM
Which mini 1/18 offroader? ProudSavageOwnr Electric Off-Road 12 04-30-2006 04:40 PM
WANTED: Offroader viet_mafia Australia Wanted to Buy 2 02-04-2006 11:30 PM
looking for a nitro offroader! new2r/c Electric Off-Road 2 08-27-2004 04:36 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
