Go Back   R/C Tech Forums > International Forums > Malaysian R/C Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-20-2008, 06:53 PM   #31
TeeKuang's Avatar
I'm using stock brake pads and disks for my new Hyper ST pro truggy, i found that the brake is so poor to stop these big wheels, so nervous to bring it to stop.. does anybody know where can I find fiberglass disks? I think with fiber disks with metal pads, they are suppose to perform better.
-Futaba 3PK 2.4GHz.
-GS Racing CL-1 Buggy.
TeeKuang is offline   Reply With Quote
Old 03-20-2008, 08:32 PM   #32
devious17's Avatar
eerrr.....it that just the same ?? stock pads has fiber material glued to it and the disc being metal, fiber disc and metal pads is just the same material accept on different side of the brake system
take the disc and pad off the center and scoure on the tarmac or on sand paper should help. If you slot the disc with dremel I believe it will enhance your braking feel.
My ex GS Truggy didnt have any problem locking all 4 wheels on high speed straights, 13kg servoi and the right tension on the brake linkages.
I dont start a fight but I will end one.
devious17 is offline   Reply With Quote
Old 03-21-2008, 09:20 AM   #33
oriongoh's Avatar
Send a message via Skype™ to oriongoh
Think whatyou really need is to adjust the braking on the braking bar at your servo there if that is what you call it.Like other bros mention a little of sanding is also good.
NITRO-X
OCM Kaos DT-19 EVO
RB WS 7 3
RB C6
DX3R
oriongoh is offline   Reply With Quote
Old 03-21-2008, 07:34 PM   #34
Trader Rating: 5 (86%+)
Hi TeeKuang, other than EPA, have you checked the brake pad itself? There are times when grease and fuel seeps through the centre diff mount and then to the brake pads. Hence, the fibre brake pads absorbs the oils, thus making it less effective. It happened to me before.
But if that's not your case.....it's quite a mystery
razor_clawzz is offline   Reply With Quote
Old 03-21-2008, 09:46 PM   #35
What about your servo? enough torque?
air jordan is offline   Reply With Quote
Old 03-21-2008, 10:21 PM   #36
cbd5336's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Danny Teh View Post
Offroad doesn't have to invest..........that much ! It doesn't makes a big difference.
is that so ke abang DT
RM5++.++ utk 4 batang itu not much ke ?
jangan marah yeeeee abang DT....
why lot of guys i meet are switching to big bore shocker ?
and i'm one of those guys...hahahahaha
LIVE LONG AND PROSPER
cbd5336 is offline   Reply With Quote
Old 03-21-2008, 10:28 PM   #37
devious17's Avatar
that expensive? how much of an improvement does it give?
Old 03-21-2008, 11:28 PM   #38
cbd5336's Avatar
that's why i'm asking
coz what i'm aiming is around RM300
also is super duper ultra cosmos powerfull engine important ?
lot of guys i've meet said that..
as long as the engine can run for the entire race
and can overcome the obsticle ( bumps and jumps )
without flaming out that easily it is good enough
bcoz in order to win the race u must finish the race kan( ayat redenzo )
Old 03-22-2008, 01:52 AM   #39
cbd5336's Avatar
any shock rebuild tip to share ?
Old 03-22-2008, 03:18 AM   #40
What are your problems wihle building a shock? For me, I cut wasted foams and stuff it in the shock caps so the shock membrane does not deform easily.
A new generation of buggies are coming, such as the Hyper 9, 808, New Mugen and a new Kyosho....can't wait to get a new buggy!
Old 03-22-2008, 03:36 AM   #41
cbd5336's Avatar
u sudah pindah brunei maaaa masa tu
so u buy new kit pun tak bule bash di sini
Old 03-22-2008, 05:56 AM   #42
TeeKuang's Avatar
Thanks for repy, Yes, the stock brake pad is fiber (look like asbestos) with some cooper particle glued to it, not satisfied with the braking performance, it's getting worse when it heat up. I'm looking for fiberglass disk, according to hst drivers, the perform alot better than stock one.
The stock disks already slotted and i'm using 12KG servo.
Already done that... extended the brake lever, almost touching spur gear now, and i'm using the hole that is closer to servo.
Yep, no oil or grease..
My local hobby shop said it's normal for Hyper ST, the braking performance poor due to heavy weight and oversized wheels. He recommended me to use 4 disks setup.
-Futaba 3PK 2.4GHz.
Old 03-22-2008, 06:50 PM   #43
oriongoh's Avatar
I was at the track of titiwangsa offroad for warming up of my engine together with a fren hehehe also warming up his JP engine.Was always told that too fast an engine for us beginner is no good but saw what it can really do when i was there warming up the engine.My fren broke the shock tower which seems so impossible to me even made the screw and shock spring crooked.here are the pictures of the broken shock tower and the engine pic.I was told by sifu to always handle our fingers nicely and never ram the engine to the full.
The broken shock tower.(pls don't drink and drive heheheh)
The engine that cause the damage.(sure so damn powerful)
NITRO-X
OCM Kaos DT-19 EVO
RB WS 7 3
RB C6
DX3R
Old 03-22-2008, 07:52 PM   #44
cbd5336's Avatar
titiwangsa track?
nasib baik tak overshoot masuk dalam kedai makan sebelah track tu
OCM KL team sudah start buat preparation for the 2nd round MNL race ke ?
tak bule jadi ni
tell your buddy pakai hyper kepala biru like me la abng oriongoh
then sudah ada more track time/xperience baru
bule switch to that JP kepala biru
shiooook la u all got track with staging near you
Old 03-22-2008, 09:12 PM   #45
devious17's Avatar
That is a new JP! I have never seen anyone break any shock tower .....untill now
Forum Jump
WTT: AcerAspire5315 for RC offroader Eagleman75 Australia For Sale/Trade 4 08-24-2008 04:50 AM
yokomo tc into 4wd offroader TZona Electric Off-Road 6 11-21-2006 08:21 AM
Which mini 1/18 offroader? ProudSavageOwnr Electric Off-Road 12 04-30-2006 04:40 PM
WANTED: Offroader viet_mafia Australia Wanted to Buy 2 02-04-2006 11:30 PM
looking for a nitro offroader! new2r/c Electric Off-Road 2 08-27-2004 04:36 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
