Cheap Servo Review Thread
Hi Guys, I have no intention to disrupt anyone's business here, but I'm sure these cheap servos are more tempting than ever before so I believe they will still sell very well
Anyway, I got a TowerPro 995 about 3 months ago, and It still works fine.
Pros
1. Cheap! Can get below RM80
2. It lasts for 3 months of 1:8 Buggy offroad action!
3. True to spec sheet
Cons
1. Overshoot problem. *by 3 degrees, and takes 3 to 4 modulations to get into position. DO NOT USE AS THROTTLE SERVO AND ON AEROPLANES
2. After a few days of bashing with it, it emits some kind of high pitched electronic noise at standstill. Problem still persists
Hopefully some of you guys could do a mini review on your cheap servos too! I'm tempted to try those Bluebirds and Hextroniks
Pros
Cons
meaning it overshoots, then undershoots, then overshoots, then undershoots before getting into the correct position Well, it is what it's worth Which is RM80
Pros
Cons
Pros
Cons
Hektronix HXT12K Analogue
Pros
2. Faster than TowerPro 995
3. Much more quiet and smoother than TowerPro 995
Cons
1. Overshoot problem.(same as TowerPro 995, if not worse) *by 3 degrees, and takes 3 to 4 modulations to get into position. DO NOT USE AS THROTTLE SERVO AND ON AEROPLANES
Pros
Cons
Pros
Cons
Pros
Cons
p/s:not work properly on my old Sanwa M8 radio, but work perfectly on my Futaba 3pk..!!
much more better then those branded but plastic servo
the tip to lenghten the lifespan this brand of servo is to
1 ) turn your transmitter before your reciever
2 ) any kind of ajustment to be made wtih the reciever battery in off position
3 ) do some homework,check the metal gearing inside the casing
4 ) No HRS mode
but if this servo start to glitch,not centering when u switch it on
just throw it away ( after u salvage the usable parts ) and buy new one
what do u aspect for this RM50 metal gear analog servo ?
want to use it for 10 years kaaaaa?
4 ) No HRS mode
*triple post, problematic server
*double post
I'm using MG995 for my throttle and steering, i've been using these servos for 9 months now, Many people say it is an analog servo, but hey, if you look at it's circuit board and hum noise, it's clearly indicate that it is a digital. in order to make it a better servo, you'll have to glue the motor to it's housing, this is to prevent the motor slip inside it's housing which may cause motor wires to break. I also replaced it's motor brushes to thicker brush with carbon in the tip, which i took from larger motor. the stock one are so thin that will worn out faster. amazingly after the brush mod, the torque is stronger and the overshoot problem gone . However, the gears seem rough, so i put some Penn Lube, any fishing tackle shop selling this http://www.pennfishingstore.com/penn-reel-grease.html , gears are much more quiter and smooth. I still got few of these servos, lying around which i bought as spares, next time i do this mod, i'll snap some pics.
Regards,
Tee Kuang
Regards,
Tee Kuang
Yeah! I know how frustrating it is sometimes to convince people that this is a digital servo! It's got 'DiGi' printed on it Thumbs up for the rectified overshoot problem!!!!!! I'll give your mod a try....as for the brushes, i have yet to actually see them. I'll open up the servos this weekend BTW teekuang tailo, what's the speed of this servo? I believe it's plus .20 sec at 6V
aiya.... abang Razor
don't compare rc airplane wit r1/8 rc offroad buggy laa
tapi betul ke towerpro MG995 tu digital ?
can buy la if like that
Ya betol lah bro! Memang digital, but the processor yg TowerPro guna kurenggggggg sikit....that's why overshoot problem. Or, like teekuang has said, it might be the brushes
