01-07-2008, 02:02 AM
RC Drift Tech Thread
hello guys !
lets share our drift setting here..
First i would like to ask anybody that can teach me how to set my machine.
im using 415msx..
Fulltime RC drifter..
01-09-2008, 02:35 AM
aiyoo.....man...i told u already...
chamber
front = 1
rear = 1.5
bearing
one way=front
spool=rear
springs
soft front and rear
itu ajer kot...
betulkn aku kalo aku salah yer cucu man!
BEST REGARDS
YeahJamal..
__________________________________
“ Man can believe the impossible,
but can never believe the improbable ”
i am powered by :
S400 / ARD R2 / TopToys CG60 BL ESC / SP 11.5 t / Sanwa M8 DSM /
Sanwa #ERG-VR / LRP Pulsar 2
01-09-2008, 04:55 AM
my setting plak... hehe
chamber 0
spring front soft, back med
erm.. last time i use one way at the front.. but i dun kinda like it in the end coz u tend to power slide more making the drift dun look graceful.. just my 2 cent..
my chassis : Xray T1 Evo 2
p/s: Gud Luck 4 ur exams Navs...
01-09-2008, 06:58 AM
thank you tok yeah.. lol
thx to intruxion for sharing ur setting..
back to you tok yeah..
ratio 5.7 tu cam mane nak buat??
01-09-2008, 07:06 AM
Originally Posted by
navz
meh sini i setting......esok turun MJG...
01-09-2008, 07:30 AM
Aiseh......
Why most people keep calling wheel geometry as Chamber? it's Camber la...
-Futaba 3PK 2.4GHz.
-GS Racing CL-1 Buggy.
01-09-2008, 07:44 AM
semut api
bleh ke??
bukan kene ade spur n pinion yg lain ke ??
camber
front = 1
rear = 1.5
cam ne nak buat ? teach me ..
01-09-2008, 11:22 AM
a ah.. kene spur pinion lain kan? ada cara kira.. tapi me oso not sure.. sifu2 sekalian, info bit bout ratio thingy.. thx
01-09-2008, 11:45 AM
navz
u pakai msx ? ada manual?
formula
spur gear
102T bahagi pinion
39T pastu kali dengan internal ratio
2.187
5.72
TAMIYA : (1986 Boomerang & Falcon )Ta04pro TB-02 TB evoIII TRF414m2
TRF415 TRF415MSX DF-02 M03L TT-01D
HPI : Sprint RS4racer2 RS43+NSR5 Savage21 Hyper7
Powered by Mabuchi :)
01-09-2008, 04:51 PM
oh i see.. trf415msx internal ratio is 2.187 ...
now i know how to kira.. thx to kreator1
01-09-2008, 05:02 PM
Ok, just found my Fall 1999 RC Touring cars mag. Start educating those who don't know!
Tire Circumference; (Tyre diameter)mm x 3.142 = Xmm
Transmission ratio
Dual Belt cars = devide the number of teeth on the diff pulley by the number of teeth on the layshaft pulley
Gearbox cars = devide the number of teeth on the diff gears by the number of teeth on the transmission's top gear (the internal gear that shares it's axle with the spur gear)
eg; 32 diff puley, 15 tooth pinion 32/15: 2.13
Now, Rollout formulae
(tyre circumference)/((spur/pinion) x (transmission Ratio)) = Rollout
Rollout = distance with each revolution of the motor's armature
Mod motors (below 13T)= Start with 25mm rollout
STock motors (3+ to 20T) = Start with 30mm rollout
Hope this helps ;p
Regards,
Aaron
01-09-2008, 05:03 PM
Just a quick note. Informaton on gear ratios are almost irrelevent, partly because you don't calculate the output of the motor itself (torque curve, RPM at best efficiency, etc). ANd normally I'll just ignore the formulae to calculate the overall gear ratio. So probably you should just try trial and error, see which best suits the track or your driving style.
01-09-2008, 07:40 PM
oh my god
how am i going to do all of this calculation..
thx for the tips..
it was a big help..
(im feeling so stupid)
01-09-2008, 08:07 PM
navz
oh my god
thx for the tips..
it was a big help..
I'll update it again, since the transmission layout these days are different
01-09-2008, 11:12 PM
sry,what is transmission layout ??
