Truggy and buggy engine compatability
HI all,
I'm still new to the 1:8 Buggy scene, and am thinking of replacing the ori Kyosho GS21R with a .28 Truggy engine. Will it be a drop in? I just wanna have fun, no intentions to join any competition....yet
Hahaha...yeah, that's why I thought of going for a lower gear ratio, and just get a baseline model. What concerns me now is the engine height. It might put off the balance.....BTW, your Hyper 7 still for sale ah? Ekekekeke
U r using pullstart engine right ???
Normally should not be any problem with the engine height if u r using starterbox.. If u use pullstart then the pullstart backplate might touch the chassis a litter bit...
I tried Hyper 7 with original spur and clutch bell with .28...No problem at all provided all the gear mesh is in good order.. DO not used Alum clutch with .28 or else u will go broke coz it will not last u long...Used normal carbon clutch with .9 spring..
Which truggy engine u wanna put in with??
My 2 cents
Cheers
My 2 cents
Cheers
GS XUT
I have a GS XUT truggy and was previously running a Werks .21 engine in it. I recenly changed it to the werks .28 engine without changing anything at all. It works perfectly fine. The engine is generally the same dimensions, i didnt even change the engine mounting. Even the meshing was still correct. Truggy so far running fine, and in fact i think the .28 makes the truggy more responsive.
CJ
CJ
My 2 cents
Cheers
My 2 cents
Cheers
Yeah I'm using a pull start, and it seems that a .28 pullstart engine has potential mounting risks. I'm thinking of the LRP .28 going for RM699 at HPC. Or maybe find a good 2nd hand one Thanks for giving the heads up!
If u have intention to use pullstart engine, then it might have slight problem but I think u should use the bumpstart engine which use starterbox. Get the LRP Spec3 truggy engine. U will get insane power and to some extend, u will unable to control it..kekekekekekekekekekekekeke
I am using it on my truggy and still with loads of power..
Cheers
Cheers
Trader Rating: 45 (98%+)
Cheers
Cheers
razor, that LRP .28 really fast n power..........hear n follow what my sifu told.....
me no sifu ler...me also beginner and at learning stage also lorrrrr...
However, for buggy, any .28 will be too much.. Maybe u can try out Mach .28which is price reasonable...
My 2 cents
My 2 cents
