Go Back   R/C Tech Forums > International Forums > Malaysian R/C Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-24-2007, 07:21 PM   #196
Faiq-X4's Avatar
Originally Posted by PintuJamban View Post
ramai lak pelanggan kedai kupi ni ye....
kupi tongkat ali satu....iyor maya karin yang antor ayor tu ye.
pelanggan dah ramai, tuan kedai lak takde
ado ko mayo karin kat kedai kupi ni? kalau ada aku pon nak oder satu
Faiq-X4 is offline   Reply With Quote
Old 10-24-2007, 07:29 PM   #197
Lipan Bara's Avatar
Originally Posted by pullstart View Post
... pasal map takleh tolong la... tp apa kata ko datang amik aku kat nilai pastu kita pi KR sama2
Lipan Bara is offline   Reply With Quote
Old 10-24-2007, 07:32 PM   #198
Lipan Bara's Avatar
Originally Posted by azhar View Post
tokeh kedai kena cirit beret sebab banyak makan ketupat, lemang,rendang dan macam2 lagi.....
Dia gi ajor kucinnye main gitar ngan betoingan man kidal
Old 10-24-2007, 07:40 PM   #199
PintuJamban's Avatar
tokey kedai tengah praktis agaknya kat track TT....
maya karin keja part time kat kedai kupi ni...kalau ko nak aku oderkan ayor cabaid....nanti maya antor
Azmi Hisham
PintuJamban is offline   Reply With Quote
Old 10-24-2007, 08:32 PM   #200
doc56's Avatar
alo...mike turon ke tak utk 4/11 ni...
No Race No Life
Horsepower is how hard you hit the wall
Torque is how far you take the wall with you
doc56 is offline   Reply With Quote
Old 10-24-2007, 09:11 PM   #201
terpaksa la aku turun sebab ada ahli khariah aku dari ipoh join race ni....meramaikan lauk
Azmi Hisham
Old 10-24-2007, 09:19 PM   #202
Minta tumpang lalu tuan kedai.
Dear M-Chassis runners
Due to request to extend number of participants for M-Chassis, the committee is requesting your feedback on the coming MNC M-Chassis racing. The race is proposed as follows:
General
1) Registration fee: RM 60
2) Maximum entry: 25 pax
3) Days of racing: 2 days.
4) Stepladder competition is proposed for the race.
5) Motor: Tamiya Sportune or equivalent
6) Tyre: Only ONE SET of Rubber tyre allowed throughout competition. Tyres will be tagged.
7) Body shell : Open
8) Chassis: Front or Rear 2 Wheel drives
9) Pinion: Only Pinion 18 for Tamiya brand car. Other cas pls consult MNC technical committee.
10) Battery: Stickpack battery only. Max 4300 Mah.
Step Ladder Competition
* Drivers are divided into 2 qualifying groups. Each group will consist of 12 or 13 drivers. Qualifying round is 10 minutes. After heats completed drivers will be ranked based on best time.
* Top 2 drivers will advance straight to the 40 minutes final on the 2nd day while the rest will fight for the remaining 8 places in the final in a stepladder competition.
* For the stepladder competition:
- Drivers from position 3 to 6 will advance direct to the semi-final.
- Drivers from position 7 to 10 will advance direct to the quarter-final.
- The remaining 15 will fight for places in quarterfinal. We call this round, 1st round.
* 2 heats of 10 minutes run will be allocated for 1st rd. Based on POINTS (points from both heats will be added) 10 drivers will advance to the quarter-final. There will be 14 drivers for quarter-final.
* 2 heats of 10 minutes run will be allocated for quarter-final. Based on POINTS (points from both heats will be added) 10 drivers will advance the semi-final. There will be 14 drivers for semi-final.
* 2 heats of 10 minutes run will be allocated for semi-final. Based POINTS (points from both heats will be added) only 8 drivers will advance to the final. There will 10 drivers for the final. The final is a 40 minutes run (DEPENDING ON WEATHER CONDITION)
Points during stepladder competition
1st Place : 12
2nd Place : 10
3rd Place : 8
4th Place : 7
5th Place : 6
6th Place : 5
7th Place : 4
8th Place : 3
9th Place : 2
10th Place : 1
bgdesmoulin is offline   Reply With Quote
Old 10-24-2007, 09:24 PM   #203
MTX3-B's Avatar
hallelujah...eureka!!!
baguih macam ni format racing baru untuk m-chassis....
keep up the good work big guy...semoga pelumba pelumba m-chassis dapat memberi sokongan padu dalam menjayakan race tu nanti...
kaki kaki m-chassis, apa lagi...jom race....
MTX3-B is offline   Reply With Quote
Old 10-24-2007, 09:34 PM   #204
pullstart's Avatar
Motonica, NT1, ABC Genetic
JIDM, RB
GRP ,Cheetah
pullstart is offline   Reply With Quote
Old 10-24-2007, 10:10 PM   #205
frame_pinjam's Avatar
ape!!!1 lasindah cape...kuotle pulok....
kepada pintu..ko mintak ampun kat aku cepat..tak kalo..taknak pit ko...
frame_pinjam is offline   Reply With Quote
Old 10-24-2007, 11:12 PM   #206
maing cw pulokkk...parhookkk kena kali ni...doh nok wak guanerrr....
ampunnnnn ye.....nanti aku tolong kilat keta ko
Azmi Hisham
Old 10-25-2007, 01:49 AM   #207
Lipan Bara's Avatar
Alamak bro lame x dgr cete mane ngilang
Old 10-25-2007, 01:58 AM   #208
MTX3-B's Avatar
ada...aku masih ada lagi...lama tak turun track sejak mnc july yang lalu...kesibukan kerja, masa terhad, urusan peribadi, dll.....biasalah...
aku dengak hang dah semakin terror dengan m chassis naa?
focus aku sekarang setakat m chassis jelah...mudah and affordable...kalau organiser kasik pakai LIPO battery lagi mudah...dah tak larat dah nak maintain IB batt...satu demi satu cell dah mati...
bila nak berentap dgn geng aku?
Old 10-25-2007, 02:05 AM   #209
rcabj's Avatar
aku pun nak jugak....kupinya aku tak nak, keep the change...
SANWA-40.435mHz , 2.4G .
idm evo4 , 2617
O ' DONNEL 16%
KYOSHO RRR EVO2 , ALTIS
BLacK cRoW RaCiNg TeaM
rcabj is offline   Reply With Quote
Old 10-25-2007, 02:39 AM   #210
Faiq-X4's Avatar
ni ada secret setting ke ni?
nak jugak? kena tanye En. Pintu... leh keep the change ke idak?
Forum Jump
HPI Savage Kopi Thiam. firegarden777 Singapore R/C Racers 366 12-31-2008 04:06 PM
Team Kopi AO Singapore R/C Racers 1172 05-01-2003 06:22 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
