Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
How do you know your bearing needs replacement??? >
Old 09-21-2007, 08:51 PM
catkchun's Avatar
Post How do you know your bearing needs replacement???
Can anyone tell me how do you detect your buggy's bearing needs replacement? If don't change, how will it affect the preformance? Thanks in advance for your feedback
catkchun is offline
Old 09-21-2007, 09:07 PM
cbd5336's Avatar
Trader Rating: 37 (100%+)
heh heh heh
u xperiment to yourself first la bro.....
bash your buggy kaw kaw without servicing/cleaning the bearing
then u will know la the performance will drop from time to time
then suddenly your Hyper 7 seize to move
that time u know la when to change your bearing
jangan marah yeeeee
service time when u took out the bearing try spining it
if not smooth pry open the dust cover and check the condition.
if ok apply bearing grease/lube and install back the seal loo
senang cerita stand by la extra bearing
cbd5336 is offline
Old 09-21-2007, 09:43 PM
devious17's Avatar
Compare used bearing with a new bearing and you would instantly know the difference. When your bearings movement is gritty that is when you need to junk them for new units.
devious17 is offline
Old 09-22-2007, 03:18 AM
nazwenhome's Avatar
Trader Rating: 33 (97%+)
sifus... i heard installing a ceramic bearing to ganti the diff bearing is good?
nazwenhome is offline
Old 09-22-2007, 03:25 AM
tkhoo's Avatar
Trader Rating: 45 (98%+)
Sure ceramic is best...one whole set for a car will cost you >RM300 compare to one normal for RM6
tkhoo is offline
Old 09-22-2007, 03:37 AM
TeeKuang's Avatar
Sorry ah.., i'm here to kepoh again... first of all what bearing? diff bearing or engine bearing? to check it, it's real simple, like bro devious17 said, just use your finger to feel it if it feel gritty or got free play, just replace them. if engine bearing, especially the rear/main bearing, you should disassemble your engine, remove crankshaft and use your finger to feel it as well. If engine bearing is gritty/free play, your crank shaft will scratch with crankcase, render your crankshaft to wear out (permanent damage!). it also stress conrod bushing. if the bearing chipped off, it will scratch your piston/sleeve and make your piston and head pitting like a surface of a moon.
TeeKuang is offline
Old 09-22-2007, 05:10 AM
Danny Teh's Avatar
Personally I think ceramics bearings are out of place..............especially you are just a weekend basher...........
CERAMICS: Brittle................it's smooth but very brittle and totally unsuitable for RC cars..............................as huge crashes might cause the balls to breaking upon impact..........................Normal seal bearing would be good too.
Hard core racers........who wants 0.10 sec might want to use it.............but maintainance is high.........so be prepare to spend $$$
Otherwise keep it simple and clean.........your cost will come down.
Danny Teh is offline
Old 09-22-2007, 05:28 AM
TeeKuang's Avatar
100% agree!
TeeKuang is offline
Old 09-22-2007, 05:29 AM
Danny Teh's Avatar
Engine maintainance......conrod every 4 gallon.............
Bearing: When you hear the Cha kueh tiaw sound, then it's time...........if you don't change...........your engine will never peak..........and under utilise............normal when bearing koyak......................run under rain conditions...........without a proper rain filter......................nitro and water don't mix....................or simply.........................warer and tear................normally after 8 gallons.....................for basher you will notice..................the engine is different
Old 09-22-2007, 05:32 AM
Danny Teh's Avatar
one last one...............if you race.......never......race with the bashing engine............keep bashing engine separate from race engine.............
Old 09-22-2007, 08:51 AM
catkchun's Avatar
is there a diff between bashing/racing engine?
catkchun is offline
Old 09-22-2007, 09:24 AM
Danny Teh's Avatar
Bashing..............you bash tank after tank........non stop........not consistent for race....................flame out, bearing gone, compression weak......etc....
Race engine.........good condition............the positive of all the above..........then your result will be consistent......................that's all..................................
That's all...............
Old 09-22-2007, 06:08 PM
cbd5336's Avatar
u kena ada 2 enjin loooooo
one for weekend bashing use and the other for racing only
itupun if u wanna step up your level
from weekend basher to weekend racer
cbd5336 is offline
Old 09-22-2007, 06:12 PM
cbd5336's Avatar
Master D T
Char Kueh Tiaw sound like how aaaa ?
coz when the plate ( hot Char Kueh Tiaw ) arrive to my table
no sound already looo
asap only ada laaa
cbd5336 is offline
Old 09-22-2007, 06:24 PM
Danny Teh's Avatar
No lah fren.............
When the guy cooking " char kueh tiaw " the wok and utensils sounds............kling kling klak.....klak........
Bearing koyak...............M'sian way.............
