Hay guys, check this out. below is the spec for mad truck nitro version.
here the video link.
http://www.henglongtoys.net/eng/3250-2.html
Produce name : 1:10 scale hand pulled/starter
engine 4WD cross-country racing car
Certificate : RTTE
chargeing time: 2-3 hours(tool box the starter)
equipped with(tool box in the ignition) 1.2 V 1800 MAH. NICD battery
for ignition.
Cover color : red and blue
Features:
15/18 power engine , 2 speed automatic transmission , 4 wheels drive all
time ,front /rear wheel driven all setup differential gear.the mode of
professional screw thread adjustable hydraulic pressure shock absorber. 3
mm aluminum alloy chassis.
Full ball bearings used through the car. Positioning independence
adjustable full wheel. Antiskid and abrasion proof rubber tire. Differential
box comes with high strength and abrasion proof alloy steel gear. Steering
servo rudder machine used metal gear. 3 channels liquid crystal digital
shown controller.
Frequency : 27.195/27.145/27.225/27.095
products size : 37*34*15 cm
Color box size : 57*26*33.5 cm.
HOW MUCH DO YOU THINK?
