Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
Tamiya TT01 Drift Spec Setting >
Old 07-06-2006, 04:11 PM
maxspeedracer's Avatar
Default Tamiya TT01 Drift Spec Setting
Tolong tolong minta tolong , sesiapa faham Tamiya TT01 Drift Spec Setting. sila bagi saya informasinya . terima kasih.
maxspeedracer is offline
Old 07-06-2006, 11:26 PM
CheeYong's Avatar
maxspeedracer,
at your service sir. How can I help you?
Drifting depends very heavily on tires. For the TT01D, the tires are softer on the inside and harder on the outside therefore you adjust your camber to determine the traction level required for drifting.
Cheers,
Chee Yong
CheeYong is offline
Old 07-07-2006, 12:13 AM
marcus1358's Avatar
hi dude, with the standard settings.. its very easy to drift.. just need lots of practice, you need quite alot of skills to drift with tamiya drift tyres.. just full throttle, tap your brake, then push your throttle again, then counter steer
marcus1358 is offline
Old 07-07-2006, 12:19 AM
Toh WL's Avatar
Here is a simpler explaination of drifting which can assist you.
Toh WL is offline
Old 07-07-2006, 12:37 AM
choon meng's Avatar
try to put all over 4wheel with o degree camber.
rear ride hight more then front.
if posible, buy a front 1 way.
lastly is more practice loh!
choon meng is offline
Old 07-07-2006, 05:22 AM
thank you every "dai go "
actually i need to know
front chamber :
rear chamber :
front toe in :
rear toe in :
front shock oil :
rear shock oil :
front shock spring :
rear shock spring :
front shock piston hole :
rear shock piston hole :
Old 07-07-2006, 07:22 PM
yow
yow's Avatar
front chamber :-2
rear chamber :0
front toe in : no nit to adjust
rear toe in : no nit to adjust
front shock oil :soft
rear shock oil :hard
front shock spring :red
rear shock spring :blue or yellow(blue is better)
front shock piston hole :2
rear shock piston hole :2
front chamber :-2
rear chamber :0
this is my drift car setting..hope can help u
yow is offline
Old 07-08-2006, 09:22 PM
dude, come join our new rc drift forum..HERE
thanks
mirage3 is offline
Old 07-10-2006, 08:25 PM
front chamber :-1
rear chamber :-1
front toe in : 0
rear toe in : -1
front shock oil : 400
rear shock oil : 400
front shock spring : std tamiya silver springs
rear shock spring : std tamiya silver springs
front shock piston hole : 2
rear shock piston hole : 3
tyres : yokomo drift rims ZR-DR02
40g weight/timah on the front
35g on the back
ponk is offline
Old 04-08-2011, 06:37 AM
hi good day can someone please advise on what drift gears i must put in my car tt01
granville is offline
