IMAX B6 BATTERY CHARGER WITH POWER SUPPLY ADAPTOR
Trader Rating: 36 (97%+)
IMAX B6 BATTERY CHARGER WITH POWER SUPPLY ADAPTOR...RM160 NEW WIT POSLAJU..
Description:
Imax B6:
This is for a rapid charger/discharger for all kind of battery of RC hobby, with built in balancer for lipo battery. Battery that can be charged by this charger,Lipo / Li-ion / LiFe / NiMh / NiCad / Pb / Lead Acid
LCD Display
Power Input: DC 11 - 18Volt
Circuit power : Max. 50W
Charge current range : 0.1~5.0A
Current drain for balancing Li-po : 300mAh/cell
NiCd/NiMh battery cell count : 1~15cell
Li-ion/Polymer cell count : 1~6series
Pb battery voltage : 2v to 50v
Weight : 450g
Dimensions : 137 X 87 X 33mm
AC POWER 12v 5A:
This power supply is identical in specifications and performance to the power supply that originally came with your monitor,
This is a high quality digital power supply for your LCD Monitor.
This adapter will protect your valuable LCD Screen from both spikes and dips in power, and will shut itself down if the power becomes unstable. It is then reset by being unplugged and re-plugged in. It is vastly superior to cheap look alike adapters,
Short circuit protection on all outputs
Over power protection
100% Burn-In tested at full load
Rated for 60,000 hours use
CCB-723:
Able to charge 2S * 3 or 3S * 2 simultaneously, so that you can save the charging time
Compitable with all B6 chargers
Fit for battery packs: 2*3S packs and 3*2S packs
Compatible Balancer or Balance charger model: B6, B6+, HB6, 620B, 630B, 680B, 680B+, 106B, 106B+
Weight: 8g
Packing Content:
100% Brand New
1x iMAX B6 Battery Balance Charger (with accessories)
1 x 12v 5A Adapter
1 x Power Cable
1 x Plug Adaptor to suit your Country
SMS/CALL ZAIDI 013-4244734/ 012-6297960
Description:
Imax B6:
LCD Display
Weight : 450g
AC POWER 12v 5A:
CCB-723:
Weight: 8g
Packing Content:
100% Brand New
1 x 12v 5A Adapter
1 x Power Cable
