Originally Posted by zapmike
Nate: I love carpet road course, if they can get 2 heats of sedan I'll be there.
Larry: I don't think about trying to compete with you, mere mortals like myself don't aspire to that kind of greatness!!
This whole track idea kinds seems surreal, I know chris always had a good oval turnout, but what's the plan on getting guys out for road course?? It doesn't seem like the prices have come down on 1/10th sedan?? Maybe setting the class specs up early like kevin posted will help. I know u onroad guys are really excited, but any other ideas to get turnout and keep the numbers up? Kinda just musing here...but thought I would share
Mike, The TC class has come down in price in the last few years. As Foam tire car needed a thicker chassis (higher cost) to work well. And foam tires were not as durable a few years ago as they are today. Now comes rubber tire on carpet. The cars need chassis flex to work well with rubber tire. So the cost of the materials have come down some. You still have high dollar cars like Xray, Corally, and Tamiya. But there is a newer breed of cars that work well with rubber tire.
These are the high line cars,
Xray T2 007/008/009
Corally Phi
Tamyia 416
Hotbodies Cyclone WE
The following cars are good rubber tire platforms with a lower cost than the high line cars, (Below $400)
Xray T2R pro
Associated TC5R/TC5
Losi Type-R
Hotbodies Cyclone TC
The cars I have listed are the normal chassis you will find at rubber tire races across the country. Some are more popular than others at different tracks.
The spec sedan class has not been finalized. But, the Cyclone S RTR is on the top of the list. This is a pre-built car with a battery and overnight charger included. They go for around $270
This class would be ran box stock. With only a few minor changes that the driver can make. The car already has ball diffs, oil filled shocks and bearings. We want a class for sedan that someone can walk in and buy and race that day. This car can also be upgraded if the driver wants to run in the 17.5 rubber tire class. I ran one of these in summer of 2007 with great success. This is a really good car on rubber tire.
There are a ton of used cars that would work well with rubber tires. Remember in looking for a rubber tire car.
You want chassis flex in a rubber car, so a 2.0 or 2.5mm chassis is good. Any thicker and that is a foam/carpet chassis.
You may want a spool or a one way. this depends on your driving style some. But a spool will always be easier to drive than a one way in the car.
Some past good rubber tire cars,
Xray T1/FK04/FK05/T2/T2R/T2 007
Losi XXXS
Associated TC3/TC4
HPI Pro4
Corally RDX
Tamiya 414/415/TA04/TA05
Your main concern with an older car is parts availability. You will break a part at some point. This is one reason why a newer car can be a better option.
In years past with rubber tire, tires did not last very long. You had a huge choice in compounds, wheels, and inserts. Now a days rubber tire is much simpler. It is actually easier than off road. You can spend about 35 for a set of rubber tires that will work very well for a month or 2 on carpet. At the track only a couple of compounds will be sold. Jaco blues and greens. So only 2 options to worry about. We may get to a point with the track where only 1 tire choice is needed. This happens at many tracks.
I hope some of this info is helpful. I am sure I am leaving out a car or 2. If anyone wants to add any more go for it. I have raced rubber tire for a number of years now. Both carpet and asphalt. You will find it is a blast to drive.
