Manhattan Kansas area Racers and Bashers!
#3721
#3722
Go Huggie-Bear! ....
Sorry KSU fans.....damn good season though.
Just wait until next year, KSU may have a bigger hand in on KUs returning starters! ()
#3723
CRAP !!!
I decided to pull the servo, guess it is a good thing I did.
Eric, do you have that gear that is broken in the pics?
Close-up
I think the baja is off-line until I can find parts
question is ... do I replace the servo with a 5755 or do I repair the HPI 10 ?
Metal gear set is $40 + s/h and the hitec is $85, will check on the plastic gears, but this thing is not fun to get out so I am not too sure I want to mess with this problem on a regular basis
Close-up
#3724
I have the plastic gear repair set, but that must have been the gear that stripped on mine too since it is the only one missing from the bag.
I just got the plastic gear set and I think it was only like $8-10.
#3726
hurray for night owls
or morning owls now I see LOL
was the gear set at the lhs or ordered?
#3727
I got mine from tower
#3728
there are 3 repair replacement parts for the HPI 10 str servo ...
stock 80573 $6 bucks
conversion 80584 $25
full metal upgrade 80599 $40
Have either of you had to get back into the servo and replace more than 1 time?
I knew Eric had to repair his, I had forgotten you killed yours too David
#3729
I only did mine once so far 2 hard runs ago. Ill probably go full metal the next time
#3730
#3732
I still have Slashes to get muddy
... but it is going to be windy and only about 60 today
I am off Friday the 2nd, maybe I will have parts installed by then. It is going to be a nice week, maybe an early evening play time is in order
#3733
R/C Tech Elite Member
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
Dustin I need 2 of both of these..
ASC3438 - Team Associated Locknuts, Aluminum Axle 8-32 (3)
ASC31251 - Team Associated Factory Team Shock Shaft, Gold, 0.26 (Associated TC5)
#3734
I might be able to turn the gear 180 and make it work .. I'll give it a go this morning real quick and report back
#3735
Or, you can just have some of mine, since I have 20 of them.
