V2 endbells-YES absolutely! Allow bearings in stock motors and hybrid stock motors too.Competitive ROAR legal stock motors are high maintenence little pieces of crap for a class that is not supposed to be horsepower intensive.If you make it so you can leave the motor in the car all day and never touch it you can spend your time on setup and driving-the purpose of the class.
Mod class-wind limits DON'T WORK! It just pushes everything to the edge-like stock class is now.The beauty of mod class is that if you need more power it doesn't take an act of god and a bucket full of money to get it.Leave the motors open and put the mod class on rubber tires so that you will make more power than you can use before it's hard to make enough.
19 turn-again,leave it open to "19 single" as the only rule or it will be just like stock where it requires so much money and experience to keep up that a great number of people won't want to mess with it.
Longer races-Absolutely not-it will just start the battery war all over again.If you open up the rules for making power and leave the races at 5 min. high voltage batteries aren't an issue any more.
Here's a qoute from another forum on this same topic-
I like the idea of 19 turn and that's about all the rules. It makes it simple and then people can't say well he's to wide or he is running a longer chassis instead of saying I had a bad day and I'll get them next time.
When is everybody going to figure out that more rules are NOT THE ANSWER.If you want better(more fun)racing and bigger turnouts you need to start throwing rules out-not making more.
