Evolution Raceway
#631
Well as long as you had a good time
I think if we gear properly and prep the motor (sprayed with CO2) and easy throttle finger. Thermal problems should be low. Of course if you run a Novak speedo you have a better chance of thermaling. They seem to have a lower set point for temp. I run a Sphere TC they have a higher thermal set point. I plan on using Novak motors in mod so I can install a heat sink ring and install 2 fans on the motor. Should help with thermal issues.
#632
FYI guys,
The ROAR electric Paved Nationals will be held down in Jonesboro, Arkansas June, 18 thru 22. I have raced at this track a couple of times this year. It is really a nice place. Even if you do not think you will make the A main it is still a great chance to meet some of the top racers in our country and the world contenders. Plus the racing action alone should make anyone want to go.
There is a thread in the on road forum that is stuck to the top. Check it out.
#636
New two speed parts for the MTX4 http://www.mugenseiki.com/menueefi.htm click on "What's New" tab
New spur gears made out of a tougher material
4mm balls instead of 3mm in 2 speed
New part numbers:
T0279 1st. Spur 58T
T0280 1st. Spur 59T
T0281 1st. Spur 60T
T0282 2nd. Spur 52T
T0283 2nd. Spur 53T
T0284 2nd. Spur 54T
TO285 2 Speed Shoes
TO286 Screws, Springs, 4mm Balls, and Set Screws
New part numbers:
T0279 1st. Spur 58T
T0280 1st. Spur 59T
T0281 1st. Spur 60T
T0282 2nd. Spur 52T
T0283 2nd. Spur 53T
T0284 2nd. Spur 54T
TO285 2 Speed Shoes
#639
Hey guys, i sure wish i still had my TC car! But, iam gonna try to get a car very soon. Its sounds a whole lots of fun! Do we have to have a Personal Transponder? Or does the track have house transponders? Will there be a Mod Rubber class for the RC Pro Series?
P.S. Chris, i found a building for the Carpet season if you havnt found 1 already. Its the ex FREDS store in my town.
#641
Personal transponders are required if you want to be counted for scoring. We do not have loaners. You can run without one if you choose, however we will not be able to count you.
I'll check on running a mod electric class for the pro series. Should not be a problem. It would be great if we can do this. Let me check.
Also, I'll add the mod guys to the Super GT series points IF they continue to show.
Hope I answered all the questions.
evo
evo
#644
So how does the schedule work for the RC Pro Series?
#645
Here's the sign up sheet and time schedule. It's listed in the lower right hand side.
http://nitroonroad.rcprosites.com/si...ate/2008-06-14
