HK Talk Version 1.0
#257
Regional Moderator
haha...got another thing in my mind...(lots to think lately)
y does novarossi make REX and TOP engine when they have MOVAROSSI already? like the engines are like the same but the colors are different and the names isnt the same...
like novarossi have the RS12, REX have the RT12, and TOP have the TT12..the are all the same!!
#258
Originally posted by fai
DTM: You've got lots of batt. already! No need to buy/try any new cells!! Save some money for your new Micro RS4!!
Anyone have any recommendation on what grease to run on the front and back gear diffs? I will run the car stock first! The front one-way is soooo damn expensive. Typical HPI marketing policy!
#259
Re: Impulse
Originally posted by stik
Fai:
How popular is Serpent Impulse in HK? I'm looking for GPM front universal joints for my Impulse. Do you know where i can get them in HK ?
Fai:
However, their motor heatsinks are ok.... no moving parts!
#260
Originally posted by Mars
dtm, I don't think the cruves are reasonable. For e.g., Powers won't have same voltage as Sanyo3000 in the first quarter of run; capacity diff between sanyo2400 and and 3000 should not be that small; votalge of 2400 in the first quarter should not be that low...
#262
ernestf- Sounds good. One thing I really don't like about the Sanyo 3000s is the way they lose a lot of capacity after only a few months.
Have you run your micro yet? Does it have too way steering or not enough? I need to determine what grease to put in the diffs
#263
dtm, i tested run mine few days ago. the tires is the major problem. it dont provide grip at all.
i use front one way and front univ shaft to avoid building all these plastic parts.
i will test run the car again this week with a 6V pack. will let u know the result later on.
#264
Regional Moderator
Stik: DTM is right!! Think about it!! Impulse is not as popular as V1R and MTX2 in HK.
DTM: You finally got your Viper!! How about #5000 grease oil??
Ernestf: Long time no "talk" with you, have fun with your Micro!!
#265
GPM Parts
Fai:
Thanks for the insight, Popularity dictates parts availabity or the lacks of it. I'm trying to find a soution to my dogbone problems. Here V1R and Impulse share equal market along with the MTX2.
DTM:
I appreciate the input. I have no experience with GPM products and its only them who have the option for Impulse. It's that bad huh? ...
Fafa:
Thanks for the info. I'll think about it because I'm not really going down to HongKong and I was hoping there would be an online shop buy from.
DTM:
Fafa:
