Go Back   R/C Tech Forums > International Forums > Hong Kong Racing
Old 05-24-2010, 10:11 AM   #1
sizheng's Avatar
Post Welcome to Hobbywing Cup 2010
HOBBYWING CUP EP TOURING CAR OPEN í10,SHANGHAI, CHINA
DATE AND SCHEDULE
2010-06-26 Saturday:
Registration, Free practice runs in the morning
Qualify #1 and #2 in the afternoon
2010-06-27 Sunday:
Qualify #3 and Final
TRACK
Shanghai International RC Arena
No.318 Xin Tong Xin Road, Hong Kou District, Shanghai
CLASSES
1.Open Modify Class (all RC drivers)
2.Stock Class (unsponsored RC drivers)
3.Sport Class (rookies and non podium drivers)
4.Formula Class
Qualifying
-Duration 10 minutes in all classes.
-The best laps and times of the three qualifies will be used to determine the driverís rank of qualify.
Finals
-Duration 10 minutes in all finals
- Finals in A Main will be of ten drivers. The rest of lower Main will consider according to the suitable amount of the drivers (may be 12 or 14 drivers).
-A Main final of Open Modify class and Stock class will be composed of three separate races of the top ten qualified after completion of qualifying. And Sport class and Formula class will be composed of two separate races.
-At the organizerís discretion, the lower finals B Main run one or two times and C, D will run one time only.
- The A Main final positions will be decided by a point system based on ten (10) points for the winner of each final on down to one (1) point for the tenth place finisher in each separate final. The best two (2) out of three (3) finishes will count. In the event of a tied position, the driver with the single highest finishing position in either of the best two (2) finals that counted will be awarded the tie, in the event of a continuing tie, and then the best laps and times from the three finals will be compared. The driver with the fastest laps and time total will be awarded the tie.
Technical Rules
MOST of IFMAR ISTC 1/10 EP Touring Car regulations will be used for this event. The different regulations are as following;
1.Open Modify Class
a)Only two motors can be used during qualifies and finals.
b)No control tyre, but only rubber tyre(width 24mm-26mm) will be allowed.
c)Total weight of the car must be 1350 grams or above.
2.Stock Class
a)Control ESC and Motor will be used during the race. The Hobbywing X-STOCK ESC with STOCK SPEC PROGRAM and Hobbywing 11.5T sensored brushless motor will be handed off when the drivers come to register. No modification allowed on the ESC and motor except the wires and plugs to the battery on the ESC.
b)The Control ESC must be returned to the organizer after the race while the Control motor can be kept by the driver. If the drivers burn or break the ESC or motor during the race, only one new Control ESC and motor can be purchased from the organizer for each driver.
c)No control tyre, but only rubber tyre(width 24mm-26mm) will be allowed.
d)Total weight of the car must be 1350 grams or above.
3.Sport Class
a)Control ESC and Motor will be used during the race. The Hobbywing CLUB-STOCK ESC with STANDARD PROGRAM and Hobbywing 11.5T sensored brushless motor will be handed off when the drivers come to register. No modification allowed on the ESC and motor except the wires and plugs to the battery on the ESC.
d)Four-door and two-door touring car bodyshells both can be used.
e)Total weight of the car must be 1350 grams or above.
4.Formula Class
a)Only 2WD (rear wheel drive) 1/10 formula chassis allowed.
b)Only 11.5T or above brushless motors allowed and must not higher than 3200KV.
c)Foam tyres must be used,the maximum width is 30mm(front) and 45mm(rear) .
d)Formula 1 style bodyshells must be used.
e)Total weight of the car must be 1000 grams or above
Entry Fee
1.Open Modify Class : 150 RMB
2.Stock Class : 280 RMB (Including one Control motor)
3.Sport Class : 280 RMB (Including one Control motor)
4.Formula Class : 100 RMB
Drivers with no AMB personal sensor need to pay additional 20 RMB for renting the sensor. If the renting sensor is lost or broken by the driver, 1500RMB will be charged for the compensation.
Entry Form
Send your entry form to the following email address:
[email protected]
Name:
Country:
Class:
Frequency:
AMB number:
Contact info:
sizheng is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
The Formula One / Mini RC Club oldskul Manila Racers 9272 10-13-2016 06:14 AM
