ShortCourse Saturdays at TRCC "Da Track"
#46
#47
#48
i just bought an associated scb10 rs rtr and a reedy 17.5 spec motor BEFORE i read that you use novak club 17.5s. Will my buggy pass tech inspection?
#49
Unfortunately no, its the only class to have any rules in our race program. But there was some buzz about a mod scb class any spec combo no timing, if you plan on racing in the points series then its the Novak 17.5 combo, but you can still come out and race jus not going count because it is a ruled class. Come check us out on sundays play/practice is a run-what-u-brung deal.
#50
Sounds Good to me! I'll order my Novak and see you next race! Looking forward to racing with you guys. I came out this weekend and was really impressed with you guys. Mahalo
#51
Also, can you explain the tire rule for SCB spec class? Thanks
#52
the rules for spec class any shortcourse buggie 1/10 scale any short course tire and only novak club spec 17.5 ecs/motor combo and thats it you can modify everything else and run whatever gearing you want and the to go in depth about the tire rule as long the tire was designed for the shortcourse truck its all good you cant put the 17mm adapter to run buggy rims and tires and i suggest calibers 2.0 med but with the 17.5 it really doesn't matter
#53
revised schedule nite race, March 16, May 18, July 20, Sept 21, Nov 16. if any changes ill let u guys no wen gets closer to race day. sorry gang got lazy on the first post.
#54
Any of you guys running the associated scb tell me what gear ratio your running with the novak club combo? I don't want to burn mine up. My plan is 75 spur 28 pinion.
#55
Watch the temp. Also, if you're still running the stock rear tires you should look for some wider offset rims.
#56
does that mean you don't recommend that ratio?
#57
#58
Time to get ready for some racing under the lights!
#59
#60
2:00 start time??
