Go Back   R/C Tech Forums > North American Regional Forums > Georgia Racing
Old 05-12-2011, 07:32 AM   #1
Trader Rating: 32 (97%+)
Default Help setting up 12th scale?
Would someone mind helping me set up my 12th scale. I dont know how to balance it, or check the tweak or any of that. I would appreciate it very much if someone would show me how and help me get the gearing done. Its an Xray XII. Ill buy who-ever helps me lunch.
Camber and toe are set I think. All the electronics are in an mounted. Has grey rear's and black fronts (pretty worn down, will pick up new if need be)
Hotshot Rc Raceway
kikcaffine is offline   Reply With Quote
Old 05-12-2011, 12:11 PM   #2
LMRacing's Avatar
Trader Rating: 27 (100%+)
I can help you with tweek if you bring it to the shop with you some time.. Im about useless with setup on anything though
LMRacing is offline   Reply With Quote
Old 05-12-2011, 12:20 PM   #3
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Tweak and balance are easy. You just need some balance buttons and 2 pennies(to check tweak, not for balancing) to sort it. I am sure Adam can show you the 2 techniques I am thinking of quite easily.
As for setup, you are on your own.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 05-12-2011, 03:58 PM   #4
hairy's Avatar
I will be at HotShot's friday night and saturday if you would like for me to help you set it up.
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 05-13-2011, 05:49 AM   #5
Ok cool.
Should I pick up new tires also?
Hotshot Rc Raceway
Old 05-13-2011, 07:10 AM   #6
hairy's Avatar
wouldn't hurt.
MERLIN RACING
Old 05-13-2011, 07:13 AM   #7
Ok, Im going to pick up a 37t pinion also to try to drop motor temps. I also will have my laptop with me with the Tekin software on it to start cranking boost on the esc.
Hotshot Rc Raceway
Old 05-13-2011, 09:43 AM   #8
hairy's Avatar
I should be there about 3pm
MERLIN RACING
Florida Indoor RC Complex FLINDOORRC Florida Racing 9594 05-20-2014 12:06 PM
Is it time again for 1/10th scale pan cars? outrunner25 Electric On-Road 325 10-21-2012 07:00 AM
12th scale wiring help, tekin rs! dirt_oval Electric On-Road 12 04-12-2011 05:10 PM
