My Lipo battery won't balance
I'm charging an Orion Race Spec 3800 30C 2s pack with a Protek 106B+. I always balance charge just cause I can.
One cell is always .15-.25v lower than the other. I have dischgarged and charged at 1 and 2 amps., but they never match up. Any suggestions? This is an older battery with hundreds of cycles, and I am the second owner.
Its most likely toast
Suspended
Just some FYI. I had a Turnigy 5000 30C Lipo do the exact same thing a couple of days ago.
It got out of balance with one cell at 4.20 and one at 3.9.
The pack did'nt swell, so I discharged it and charged it at 1 amp about 4 times.
They almost got back in balance with one at 4.2 and the other at 4.1.
I decided to run it. Bad idea, it ran good for about 2 mins then just stopped.
I took the pack out and it swelled like you won't believe. So much it started to pull the hard case apart.
Discharged it on the charger and into a bucket of salt water. TOAST!
Don't risk it. One battery is not worth your RC ride, real car, house etc. etc.
