B4 - Motor/ESC connection?
#16
Yeah that one should do. If you don't feel comfortable doing it just get all your wires measured and cut and one of will be more than happy to do it. Main trick is to tin the wires completely that way when it melts to the solder tab you won't have to add any more solder and won't have to get it too hot.
#17
dont forget a good flux! I recommend this stuff: http://www.radioshack.com/product/in...ductId=2049774
#18
Most good solder already contains flux. There's really no need to double flux a solder joint if you're using quality solder.
Anybody planning to run any Mod 4WD/2WD on Saturday?
#21
Wow you guys need some ritalin. This went from a soldering motor wire thread to a whos racin' mod thread. While we are on the subject I will have a 4wd to run for the charity race
