Turtle Trax, Sat. Race 7/11
#62
I haven't even got to run the buggy yet and I already have a leaky shock... I pulled it apart and notice that one of the seals was torn up. When you push the shock in oil shoots out the bottom. So I need to get a rebuild kit.
Also when I was mounting the tires in seamed like there was way to much foam. It is getting scrunched up inside of the tire and making it uneven. Should I cut it down some?
#65
Yeah, I'm back and just catching up on this thread. Hey, my wife and I did ride up on my bike last weekend and found the place. Got lost on the way out, but that's just me - I'm planning on coming up and spanking you Saturday.
#66
#67
Track opens 8AM. Sign ups til 1. Racing at 2.
#68
#69
pst.......hey mac.........can i get a shot before the main?
#70
I used a little berring oil when I inserted my shafts into the shocks, this kept the rubber seals from catching and tearing. You also need to put a little berring lube on all the seals before you insert them into the shafts to keep them from tearing. This is just somthing I picked up from working on cars and knew before I ever touched RC. some things convert over and others do not. but Rubber seals will always go bad when you grind unlubed metal agenst them.
As for the tires, yes you need to cut the foams to fit inside the tires.. Some people dont and get away with it. but it takes a lot more patience than I have. most people will cut them down to fit (a 45 degree angle in the edges of the tire that touch the tire, leave the edges that touch the wheel square) Then press the foam into the tire untill you get it worked into the tire so that its flush with the bead of the tire and insert on wheel
If you'd like some help with it show up to the track early and Im sure someone will be able to help you mount the tire. if you get your shock rebuild kit there in time same for that, bring it to the track and I or someone else will help you put it togeather and show you an easier way of doing it
We all had to start somewhere and get helpful tips along the way.
#71
Thanks for all the help guys. The seal tore on the inside which is kind of wierd. I put shock oil on the seals but any ways I'll go up to hobbytown and get a rebuild kit. Also how do I get the seals and all of that back out of the shock body?
I can't make it to the track this weekend. We are leaving for hitlon head on saturday. I have most of this stuff figured out and know how it works. The shocks are the only things given me problems. Im going to order my electronics mid way through the week that way they will be here when I get home.
#73
So be sure to slime your o-rings!!
To remove the o-rings and spacers you installed. Use the same black plastic tool you assembled the o-ring and spacers on to push the damaged o-rings out from the other side. Slide the tool into the shock body (from underneath) at an angle and push. The square clip holding everything in should pop right out.
#75
