Off-Road 1/10 2wd Buggy?
#16
... you could spend about $50 more and get a baseline B4 kit and upgrade it as you see fit.
Tower has the base kit for $169.98 (http://www3.towerhobbies.com/cgi-bin...&I=LXDAX9&P=SM) and you can use a promo code for a $20 discount which puts you somewhere in the realm of $160 shipped.
I will also check out the for sale area for some steals.
Thanks for all the great input.
Originally Posted by kikcaffine
2nd- Why are you not at hobby hangout on Thursday's racing that slash with us indoors? There were 7 or 8 last week! Its an absolute blast!
#17
I have a used B4 I'll let it go to a good home.
It needs
servo mounts+ screws
servo arm and ball stud
battery hold down
slipper cover+ screws
motor,ESC, RX and servo
I suggest rebuilding the shocks
Body and wing
It has aluminum front A-arms and rear hub carriers
Several spare wheels and some used tires
I'll throw in a NEW carbon fiber chassie
$60.00
It needs
battery hold down
Body and wing
$60.00
#19
#20
Eric: Are you going to TT this Saturday? That is a tempting offer, thanks.
rcbo: Thanks for the offer, I will have to take you up on that. Thanks, on the vid....Sorry the resolution was not that great.
#21
I want to but I'm going to run my 1/8 E at VRP Sat. Next weekend if there is a race.
#22
A Main has the xxxcr in stock and on sale for $204.
http://www.amainhobbies.com/product_...-2wd-Buggy-Kit
and use one of these codes.
If Your Order Totals: You Save! Refer to Coupon#
$100.00 - $149.99 $5.00 JJDCPP95
$150.00 - $249.99 $12.50 JJDCPP912
$250 or more $25.00 JJDCPP925
#23
Chris I wish Tower sold losi but that would make life to easy.
So what is a good brushless system. I was thinking about going with the losi system because it has a card to progam the esc with, which would be useful at the track. Also are the tires that come in the cr kit any good or should I buy different ones?
#24
#26
http://www.amainhobbies.com/product_...tal-Gear-Servo
Is this a good servo for a buggy? Also does the buggy come with a servo horn that works with jr servos?
Got another question. Can I use the coupon codes for a main multiple times? I am thinking about splitting my $670 order into 2 that way I can save $50.
#27
You can only use each coupon onnce.
#30
Loganville. I'm doing the GCS. If I wasnt in the middle of this series I'd go to TT. Do you think you want the B4? I'll save it for you if you want, otherwise I'll let it go to someone else.
