Suggestions on 1/18th scale jumps?
#33
the lanes on the blue carpet are 6' wide but the jumps we use alrdy are 4' wide. So i would say if you make some just make them 4' wide so we can use them anywhere on the track some lanes are a bit narrower or wider Plus then we can use this jumps on the back track also when it gets done.
#35
Will do Chad. This boat carpet is very thin. More for traction than it will be for cushion. I'll leave a couple inches of overhang for a transition. I'll try and make a table top. The material is same as peg board, just without the holes. Should make for fairly light jumps.
#36
thanks randy for your suport we need and thank you. if you want to build some jumps thats ok me and chad thank you for any help and info you can give. the off road is going to be spectackular.if we get a lot of racers then we will pit on the on road track providing we take car of the ozite carpet.
#39
chad i am puting in windows to better light up the track and the PIT SPACE to better serve the racers. i hope they are apreashetive.
#41
cant wait to have this up and going. if i could ever catch a break from work, i'd be up there throwing what i could at that track. hoping to make it out there this sat for at least touring.........
#42
Well Chad I wanted to show ya what I've come up with so far. Keep in mind, I've only had a hour after work to tinker.
I'm shooting for a basic tabletop. So far this is what I have. Pretty light frame. Take off and landing are the same angle but I can change that if it doesnt work right. Its just short of 4' wide, and 36 or so inches long. Trying to fix it so its easy to change. I covered it with corplast and its makable pretty easy with what little takeoff room I have. Let me know if you have any suggestions.
http://rctech.net/forum/attachment.p...1&d=1194388763
