thanks guys.... we have put alot of time and effort into making this track nice. There have been a lot of people that helped along the way. There are still more improvements that will happen. We will be adding a second 1/18 and smaller sized track in the extra space we have in the north end of the Rink. The power is ALMOST done, with all but 4 of the outlet boxes run. I started on the pit spaces last night, but I beleive I am going to redo what I started to make them a little shorter. We will be added some lights to the pit area, still working that out.
The track offically closes at 10, so you have 30 minutes to clean up. If you dont, It gets VERY DARK.
The Practice night has been organized to 20 minutes Electric Only, 20 Minutes Gas only, and 20 minute open track. This seemed to work well last night.
MDI will start organized racing racing pretty soon. We still have some items to sort out before we move to the next step of racing. We will also be starting the club in the next month or so. Still a bit to do...
Thanks again to everyone that has donated time and money, everyone in the area apreaciates it. I have seen a bunch of new racers, so anyone that sees a new racer, offer to help them out, and don't be afraid to point out whats good and bad.
Thanks again...
Clean Title & Escrow |p3|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|
Does anyone have a base setup for a 200mm TC (nitro), tires (shore and diameter), ride height, springs (stiff, soft), etc...? How is the traction? I know the track has a different type of surface than just smooth asphalt, how does it affect the tires?
I am very excited about this track. It looks great. Good job Tim.
stock springs
30wt oil
45 deg front swaybar
7 front / 1 rear droop
6mm ride height
62 or smaller tires (try 40's)
really good traction, too soft and you'll traction roll. very very minimal tire wear too.
Thanks for stepping with the suggestions Jarrod. I have not run my own nitro car at the track yet, so I would not want to make any suggestions. When the track is prepped is high to very high traction in the line.
Jag, thanks, alot of people have put alot of time in to make this happen.... It is nice that people are enjoying it. We still have alot to do, and I am sure we will feel some growing pains, but we will get there...
You can run out there with your car on the weekend, The track is not prepped, so I would bring your blower. MDI will be running racing, hopefully within a month or so. We will be racing Saturday afternoons/early evening to start.
We still have some loose ends to tie up before racing starts in earnest.
Sounds good. Is there a time when a group of people are out there on the weekends? I assume that the timing system is the biggest item left to complete?
There is a group of guys that goes out on the weekends, just not sure when, I have been there on Saturday, and saw them in the afternoon. I have dropped by the track, all hours all days, and there generally is someone there running.
