Indoor electric Summer point series
Announcing the Summer indoor point series race hosted by Newred hobbies and Holeshot Raceway.
This event will consist of 4 races, one per month without any drops. There will be prizes to be raffled off and each entry will receive a raffle ticket to win prizes! The first race is April 27 at Newred, so put the dates in your calender and lets bring the fun back into racing!!
See the attached flyer for more information, or you can contact one of the tracks. See you there!!
Last edited by Holeshotraceway; 02-20-2013 at 07:37 AM. Reason: Removing the second indoor, (typo)
Series update
You can now register for the first two point series races on RCsignup. If you do not register on RCsignup, you can still register at the track. Don't wait, put the races in your calender's! It's going to be fun!
See you there!
See you there!
Series update
Remember, the first and third races are at Newreds and the second and fourth races are at Holeshot Raceway. There is a little over 30 days till the first race on 4/27. See you there!
Almost here!
The indoor summer point series that is held at Newred hobbies and Holeshot Raceway is almost here! Take a look at the flyer for dates and put them in your calender. We look forward in having everyone attend!
Kris
Kris
we have just finished revamping our jumps, and recoated the entire track , so we are ready and it looks like kris has put in a bad ass layout, so we are ready. cya on the drivers stand
Yeah buddy!!
im all signed up for mod buggy and 4wd mod!!!
First point series race
The start of the Summer indoor point series race is right around the corner! Make sure you place the dates in your calender. We are giving away prizes and remember, there will not be any drops so all four races count. NewRed and I look forward on providing a great program and can not wait till this starts! See you there!
Practice starts at 7:00 and closes at 9:30. A quick drivers meeting and then the qualifying will start at 10:00.
Series tech inspection
This is a PSA for everyone. We will be teching all vehicles, mainly the stock classes for the series. Here is what we are looking for and is much needed across the board:
Myself and Billy Bruce will be completing a pre-tech inspection at each of the point series races.
We will be checking to see if your ESC is in blinky mode, legal rotors.. spec rotors only no mod rotors in your 17.5
Stator resistance will be checked and the numbers will be written down next to your name. This is done to see if anyone is pulling the wire or shortening the wire. Some suggestions, clean your motor. If you would like Billy to clean, lube and re-shim them the cost is $5 to him. If not we will return your motor the way it was given to us.
The motors will be sealed and screw holes filled in (you can still open them, you will be re checked if re-opened). There will be a table trackside for you to place your transmitter on with radio trim in neutral to properly check if your cars are in blinky mode. There will be a list of blinky rules and approved ECS's on hand for all to see.
There will be a voltage check before going on the track. If your battery is above 8.5 volts, you will need to get another battery. Charge your batteries properly! You can not charge in NIMH or Nicd mode, unless you have these batteries. No over charging, ITS NOT SAFE!
There will be a scale track side for everyone to weigh their vehicle. Here are the ROAR minimum weights:
2wd Buggy 53 oz
4wd Buggy 57 oz
Stadium truck 60 oz
2wd SCT 74 oz
4wd SCT 88 oz
Weigh your trucks now so you are not changing your setup at the track.
We are not trying to be difficult, this is something that needs to be done. If anyone has any questions, PLEASE feel free to contact us. We all have an open door. Also Billy's motor will be teched by myself and Tom.
Kris
2wd Buggy 53 oz
4wd Buggy 57 oz
Stadium truck 60 oz
2wd SCT 74 oz
4wd SCT 88 oz
Kris
Inspection times are 7:00-9:00. Please do not wait till the last minute! Practice times are 7:00-9:30 with qualifying starting at 10:00 permitting everyone is inspected.
Kris
Kris
Kris and Billy, let me be the first to thank you guys for taking the time to do tech the right way. Is there a reason for the 8.5 instead of ROAR 8.44v?
One other possibility is to set up a tech schedule by class/car type. Perhaps we can order it in a similar way as the rounds will be run? just some food for thought.
I would like to thank you guys for teching like this, Makes me want to run stock buggy now.
