Go Back   R/C Tech Forums > Company/Manufacturer Forums > Fantom Racing
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Thread Tools Rate Thread
Old 06-18-2009, 11:38 PM   #1
Default Question on 40c 5000mah Lipos
Hello,
2 quick questions for you;
1. Are your 40c 5000mah lipos in stock?
2. What charge rate do you recommend? Can these cells handle 2c?
Thanks!
Overtorque is offline   Reply With Quote
Old 06-19-2009, 04:44 AM   #2
RCHavoc's Avatar
I always charge mine at 5A. They provide enough power that you shouldnt risk damaging them by charging them at a higher rate. I keep them balanced at all times as well...
RCHavoc is offline   Reply With Quote
Old 07-02-2009, 02:20 PM   #3
Company Representative
Fantom Racing's Avatar
Originally Posted by Overtorque View Post
Hello,
Thanks!
Hello,
Thank you for your message. Sorry for my slow reply, but our business computer has been down the past week due to a lightning strike.
Regarding your questions, yes we do have them in stock, and we recommend charging them at 1C for longevity and safety.
Thanks again,
Jeff
Fantom Racing
Fantom Racing is offline   Reply With Quote
Old 07-03-2009, 09:05 PM   #4
rcmark24's Avatar
If your planning on attending any large events like ROAR you won't be allowed to charge over the recommended charge rate. Plus the 40Cs have plenty of power.
Fantom Racing-B&L Hobbies-Team Sweeno-AE B4-T4-SC10
rcmark24 is offline   Reply With Quote
Old 07-14-2009, 10:37 AM   #5
EJ20's Avatar
Default Balance adapter
Hi, just want to know I have a Checkpoint/Ice Charger, what type of balance adapter should I choose? Align or Hyperion?
THANKS!
EJ20 is offline   Reply With Quote
Old 07-14-2009, 10:51 AM   #6
THANKS!
Hi EJ20,
Thank you for your inquiry.
From what I can tell with my research, your charger does not have a balancing feature, which means that you need to purchase a stand-alone balancer, that you will insert inline between your charger and battery while charging. I recommend the Hyperion and you can purchase it online at rclipos.com Here is the link: http://www.rclipos.com/HP-EOS10A.htm
Once you have this balancer, you will either need our FAN26111 adapter for a 2 cell pack or FAN26113 for a 4 cell pack.
Hope that helps.
Take care,
Jeff
Fantom Racing
Old 07-14-2009, 11:52 AM   #7
EJ20's Avatar
Originally Posted by Fantom Racing View Post
Hi EJ20,
Hope that helps.
Take care,
Jeff
Fantom Racing
I'm sorry about I should ask I have a checkpoint balancer instead of the charger.
THANKS!
Old 07-14-2009, 12:03 PM   #8
THANKS!
In that case, I don't think the Checkpoint balancer is compatible with any brand Li-Po batteries that have balance taps like our packs do (external plug type). The Checkpoint balancer only works with Li-Po's with bullet style balance holes. If you want to use Li-Po's like ours, you will need to purchase a separate balancer such as like the Hyperion one I recommended previously.
Another option would be to contact customer support at www.rclipos.com and see if they can make a special adapter for you.
Jeff
Old 07-15-2009, 03:01 AM   #9
RCHavoc's Avatar
THANKS!
Actually, the checkpoint balancer is exactly the same as the Great Planes Equinox. The only difference is the Equinox will do 5 cells and the Checkpoint will only do 2. Here is a link for the tap you would need to charge your Fantom 40c packs through a Checkpoint Balancer
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSEK0
Us this one if you want to charge your packs over 3 amps.
http://www3.towerhobbies.com/cgi-bin...?&I=LXSEK4&P=7
Hope this helps!
Forum Jump
Yeah Racing 5000mAh 25C HARD CASE Li-Po Dan/Ultraline Electric Off-Road 308 10-12-2009 01:58 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
