Go Back   R/C Tech Forums > Company/Manufacturer Forums > Fantom Racing
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Thread Tools Rate Thread
Old 07-02-2009, 02:12 PM   #16
Company Representative
Fantom Racing's Avatar
Originally Posted by nick84 View Post
How Rare is this?
Nick84,
I'm guessing this is from around 1990 to 1994.
Jeff
Fantom Racing
Fantom Racing is offline   Reply With Quote
Old 07-06-2009, 06:31 PM   #17
dgdcustoms's Avatar
Trader Rating: 46 (100%+)
Well I need to buy another new motor and it needs to be a Fantom.But I cant find anyone who has the 13.5 instock.Does Fantom themself have them instock?O r does anyone know where I an get one befor Friday?
KYOSHO RT5/Tekin RS/Fantom
KYOSHO RB5 SP/Tekin RS Pro/Fantom
KYOSHO ZX-5FS/Tekin RS Pro/Fantom
_____________________________________________
FantomRacing.com_DGDCustoms_BLOCK HEADS_XTREME HOBBIEZ_Team Slant EyEys
dgdcustoms is online now   Reply With Quote
Old 07-06-2009, 08:23 PM   #18
Emlyn's Avatar
Hey mate try Fantom's website..www.fantomracing.com
Its the BLUE 13.5 TURN ION SPEC PRO BRUSHLESS MODIFIED MOTOR
FAN28201...
Hope this helps,
Emlyn
b44- LRP sphere-6.5
T4- LRP sxx comp'-17.5
fantom 40c LiPo's
fantom BL motors
Emlyn is online now   Reply With Quote
Old 07-07-2009, 10:52 AM   #19
dgdcustoms's Avatar
When will the new Ion2 10.5 and 13.5 be out?
Old 07-07-2009, 04:15 PM   #20
EJ20's Avatar
Default Rotor size?
Hi, Just want to know the size of the rotor in Fantom's DUO 13.5? (?mm). Asking because I have 1 right now it feels like a lot more toqure than Express Motorsports's. And I've seen there are different sizes rotor are selling at Stormer hobbies. Want to try some other sizes rotor to get little more RPM.
THANKS!
EJ20 is offline   Reply With Quote
Old 07-07-2009, 06:47 PM   #21
Default Rotor size
It comes Stock with a 12.5mm Rotor. If you go to a 12mm rotor it will give you more RPM but it also takes away some torque. If you put the 13mm Rotor in it the Torque goes throught the roof and it seems to run COOLER the best series of Fantom Motors to work with is the ION 1 series. As a Arizona Team Fantom Driver the ION 1 Has Proved itself in a Very HOT enviroment. In my B4 i run a 13.5 ION 1 with the 13mm Rotor. but i can run a 36/78 and after a 6 minute heat with a 2 minute warm up it only comes off at 135 degrees. the same way with my T4. My B44 i run a 10.5 ION 1 with the 13mm Rotor and i can run a 32/78 after a 10 minute heat and a 15 minute main i come off at 145even when it is 109 degrees out side.
If you Have any More Questions, Please ask, Thats why we are here to help with questions and setups.
Happy Racing. " COWBOY "
HOT BODIES - PANTHER PRODUCTS - BOCA BEARINGS - FANTOM RACING - UPGRADE-RC - CLINE HOBBIES - TEAM TERRIBLES - COWBOY'S PAINT WORX
Az-Cowboy is offline   Reply With Quote
Old 07-07-2009, 11:40 PM   #22
EJ20's Avatar
Thanks.
Old 07-12-2009, 02:14 PM   #23
ovalnator's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to ovalnator
Thumbs up
Fantom Brushless Motors and Lipos have been the hottest selling items in their category for the last 6-8 months at Redneck RC. Fantom sells a very high quality product; always have and always will. Regardless of who manufactures their lipos, I can tell you there are no complaints here in Central NY!
www.redneckrc.com
ovalnator is offline   Reply With Quote
Old 08-07-2009, 10:56 PM   #24
I have been having a look at the ION2 series of modified motors and it seems to be a case of a rebadged Vortex motor.
Is this the case?
What is the standard rotor for these motors?
Are there tuning rotors?
Do the have the mini impeller?
Cheers.
FlyingFoxRC Team Twister Hobbies
Fantom Team Wave
Dragonfire is offline   Reply With Quote
Old 08-08-2009, 02:11 AM   #25
Emlyn's Avatar
Cheers.
Hey mate I've got both in front of Me they do look similar but are quite different.
b44- LRP sphere-6.5
fantom 40c LiPo's
fantom BL motors
Old 08-08-2009, 04:13 AM   #26
If you have both can you compare them a bit for me? I know the end plate is different but the rest looks very similar. What size rotor? Does it have an impeller? Does it look like it has many winds like a SP motor or few winds like an LRP?
Cheers.
Fantom Team Wave
Old 08-10-2009, 12:44 PM   #27
dgdcustoms's Avatar
Hey fantom got a quick question for yas. Are you or plan too, come out with a Lipo that takes 4mm bullet connectors? Im not a real big fan of ANY connector but If i cant hard wire it Id rather use the bullet connectors.
I realy want to try out your batteries, but this is kinda holding me back.
Old 08-10-2009, 01:50 PM   #28
rcmark24's Avatar
I'm not a big fan of the bullet type connectors myself. Since I went Lipo I've been using the Deans and no problems at all. I always hardwired before but this makes charging and running so much easier. You love these batteries!
Fantom Racing-B&L Hobbies-Team Sweeno-AE B4-T4-SC10
rcmark24 is offline   Reply With Quote
Old 08-10-2009, 01:52 PM   #29
ovalnator's Avatar
Switch to Deans, it will be well worth it. The difference in resistance, if any, is so small that you will not be able to tell the difference.
www.redneckrc.com
Old 08-10-2009, 02:44 PM   #30
dgdcustoms's Avatar
Yeah I been thinking about that. But I also dont like the balance plug on the battery. I already had to take my smc pack apart becuz the wire broke. they just dont seem to be all that flexible. I like the idea of the plug and balancer staying together also. Just seems less of a hassle. And I dont have to worry where the kids put it when they were done. Its allways on the plug. It sucks my LHS doesnt carry Fantom so I realy dont know if there balancer wire are more flexable or not.
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
